Old 04-05-2007, 05:51 PM   #41 (permalink)
TajMan's Avatar
Drives: 93SOHCMTX
Trader Rating: (25)
TajMan is an unknown quantity at this point
Default Re: Timing chain kit
Before Mitsu moved to the 4G63T and 6G72TT the Starion G54B 2.6L four used a single overhead cam and timing chain. The new designs in 88 89 90 were an upgrade.
I'm dealing about a StarQuest right now. Engine was rebuilt and started. Timing chain had been stretched in rebuild process, needs replaced now.
Some rock solid SOHC workhorse motors can go a long time with them, but 2 valves per cylinder & don't rev high. High output & high top end motors move to belt systems.
Wiki: timing chains:
"While chains and gears may be more durable, rubber belts are quieter in their operation (In most modern engines the noise difference is negligible.), are less expensive and are mechanically more efficient when compared with a gear or chain system."
And in that context ONLY more durable on a SOHC engine with a short chain, not revving too high. DOHC high revving motor and its no question, the belt is the upgrade.
Something just needs to be upgraded about our tensioneer system.
former 3/Ss: '92 R/T, '94 3KGT, modded '92 R/T TT
current vehicles owned that are down for builds:
'93 Stealth
'77 Lancia Scorpion
'79 Yamaha XS11
TajMan is offline   Reply With Quote
Old 04-06-2007, 05:40 PM   #42 (permalink)
Verified Asian
Sean3S's Avatar
Drives: 94 TT
Trader Rating: (37)
Sean3S Level 1Sean3S Level 1
There's a guy selling solid tensioners right now, well pre-selling them.
'94 RT/TT
13T's | PTE FMIC - PPE Pipes | 560's | Supra FP w/ 8ga Hotwire | MAF-T 1.37 & LT1 Blow-Through | E-Manage Blue w/ Boomslang Harness | HKS DLI | Stillen Downpipe | Gutted Rear Pre-cat | Borla Catback | Tial BOV | AEM FPR & Rob Beck Adapter | DejonTool Intake Pipes | PWR Radiator w/ IPS Pipes | FAL Fans | MP Motor Mounts | 99 Lash Adjusters | Clevite 77 Rod & Main Bearings | Leatherseats.com Dk. Graphite w/ Red Center Seats | Sparco Flash 5 Black w/ Red Alcantara | Spec Stg. 2 Clutch & 3SX Clutch Line | 3SX Crank Pulley | Bob's SS Shifter & All Solid Bushings | eK2 EGR Blockoffs, Fuel Line Loop, Injector & Harness Cover | PST 1 Pc. CFDS | Volk LE37T | Falken FK452 | Megan Racing Coilovers | Adj. Rear Control Arms | Slotted Rotors w/ Hawk HPS Pads | GReddy Profec B | AEM UEGO WB | GReddy PWH Boost, EGT, GReddy OP, FP, Temp | Hybrid Logger | McColluch 5300K HIDs | Shaved '99 Bumper & Turns | PRM Style Hood
295.7 AWHP / 310.3 TQ @ 1 Bar - BPU @ TX04
Collecting Dust - Setrab Oil Cooler, Snow Stage 2 Meth, Brake Lines, Solid Diff Bushings
Some Day - ABS Delete, Ducting
Sean3S is offline   Reply With Quote
Old 04-06-2007, 06:02 PM   #43 (permalink)
Member in good standing
Jim Floyd Level 2Jim Floyd Level 2Jim Floyd Level 2Jim Floyd Level 2
Thread or Link?
Jim Floyd is offline   Reply With Quote
Old 04-06-2007, 06:43 PM   #44 (permalink)
H to the izzO
Hannibalzero's Avatar
Drives: Recklessly
Trader Rating: (56)
Hannibalzero is an unknown quantity at this point
http://www.3si.org/forum/showthread.php?t=369934
Old 04-07-2007, 05:08 PM   #45 (permalink)
Damage Control
Stealthee's Avatar
Drives: 1994 Stealth
Trader Rating: (144)
Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3Stealthee Level 3
The dumbshit hasnt been on since Feb 5. Hes been around since Nove 04 and has 21 posts. I dunno why anyone is wasting their time in this thread. LOL People have already posted why a timing chain is a bad idea on a high revving dohc.
Old 04-08-2007, 08:50 PM   #46 (permalink)
I kill brakes
Highboosted's Avatar
Drives: Other People Around
Trader Rating: (29)
Highboosted Level 1Highboosted Level 1
Ummmm....BMW would disagree with you on that:
Good enough for 8,300+ with a warranty.
But, too expensive and pointless to do on these motors as a retrofit.
pıdnʇs 'ɹǝʌo ǝɯ dılɟ
Official member of the "I upgraded everything in my car and now it's slower than stock" club.
12.8@107, 13 psi @ NG09.
Highboosted is offline   Reply With Quote
Old 04-09-2007, 10:52 AM   #47 (permalink)
BlackFastRT is an unknown quantity at this point
Yeah german cars also make you hold the wheel while you put the bolts through it....
I'm sure they'd agree those are better too....
I'm sure they'd also agree to making cars with an odd bolt pattern for no good reason
I don't support germans...
BlackFastRT is offline   Reply With Quote
Old 04-09-2007, 12:13 PM   #48 (permalink)
Tbone's Avatar
Tbone is an unknown quantity at this point
I want some of you people arguing for timing chains to hold a timing chain and a kevlar belt in each hand, think of all the difference even a few pounds of rotating mass makes in an engine, then tell me that a timing chain is better.
Red 91 3000gt vr4
Installed: 3.5l 6G74@8.5:1 Compression, Gt28rs Turbos, MAFT w/GM MAS, JE Pistons, APR Head Studs, Custom Intake Hard-pipes w/ FMIC, Tein lowering springs, Adjustable control arms, 1000cc Injectors, Dual walbro fuel pumps, Full custom 3" exhaust w/no cats, Custom downpipe, RPS Stage III Clutch, K&N dual intakes, 3sx aluminum crank pulley, Greddy Emanage, HID headlights, FNOIR-C wheels, Trinet drilled and slotted rotors, Carbon ceramic pads, Netami racing seats, Pioneer AVIC-D1
All through a stock 18 spline o/s!
Tbone is offline   Reply With Quote
Old 04-09-2007, 03:01 PM   #49 (permalink)
Regulator...
mikes2nd's Avatar
Trader Rating: (34)
mikes2nd Level 1mikes2nd Level 1mikes2nd Level 1
exactly... dumbest idea ever... is everyone smashing valves? If you are you didnt build your engine correctly... or you let your timing belt go too long.
mikes2nd is offline   Reply With Quote
Old 04-10-2007, 09:31 AM   #50 (permalink)
VR4 owner since 1993
JD-01's Avatar
JD-01 is an unknown quantity at this point
Retrofitting a 6g72 with a chain? Probably not worth it the hassle... but...
TBelt > TChain for a DOHC engine? Uh, no...
Each design has advantages, but there are many DOHC Tchain based OEM engines out there... for example, I've been considering an M45 which has a VK45 engine...
http://www.nicoclub.com/engines.pdf
-JD
John Davidson JD's VR4s Mem#0092
2006 Liquid Platinum Metallic M45 Sport
1993 Caracas Red 3000GT VR4 (JD-01)
All factory options. Apexi SAVC-R, Greddy BOV, 17x9 Volk Challenge wheels (Chrome w/Black Diamond lip), Firehawk SZ50 275/40 zr17 tires, Porsche/Brembo 993 "Big Red" 4-piston front calipers - OEM Porsche pads, '94+ 2-piston rear calipers - Porterfield R4S pads, '94+ Porterfield Cryoed/Crossdrilled rotors, SS brake lines, K&N Intake, Borla Exhaust, Cusco rear strut-bar, Custom TEC front strut-bar, battery relocation kit, Snake Eyes Mod.
-In the works: Boost,A/F,Twin EGT gauges, customized cockpit layout, stereo upgrades, alarm upgrades, downpipe, precat/cat removal, cool air intake?, AEM?, Air/Liquid Intercooler?, CFDS?, etc.
Previous Autos:
1995 Yellow 3000GT VR4 Spyder (former JD-02) Customized
1999 Dark Toreador Red Clearcoat Metallic Ford Expedition (AWD too!) Eddie Bauer 4x4
1992 Sandstone Gray Metallic 3000GT VR4 (former JD-02)
1989 Black Nissan Maxima SE
1977 Black Pontiac Trans Am
JD-01 is offline   Reply With Quote
