Originally Posted by rush6432
Well, i kinda see a problem. belt stretching SLIGHTLY does cause cam timing events (peak lift on lobes) to be EVER so slightly off from crank optimum stroke at TDC, and this does screw with making OPTIMUM power if your really anal about getting every ounce of HP out of a motor. i think it would be a great idea for the chain system but the slack issue in anything is a concern. yes i know im talking about fractions of power here but for the avid gear head i think it definatly makes a diffrence. you gotta pay attention to all the details..... im talking about cam/crank degreeing here..
you do know that chains stretch right? Chains also break.
I use the Kevlar belt, it don't stretch or at least it isn't supposed to
I am pretty sure there are 7 second imports that run a belt and do just fine.
Personally, and this is just me, I think this would be a very complicated and unecassary way to fix a problem that doesn't exist.
