Re: Techy questions on timining and adjustable cam gears
I understand the advancement of exhaust cam but if dealing with the 1g cam/crank sensor why are you messing with the intake cam? Certianly those with 2g's or the divorced cam/crank sensor rewire, could utilize the retardation of the intake cam. All you'd end up doing is delaying your ignition timing sequence.
I need to do my own research on this subject.
Cam gears however are cheap. I found a slighty used set from Ebay for almost 70% off new ones. Hell, they appear only to be mounted as a display and were never moved from "0" position.
But yes, what are offset keys? Crank woodruff keys? I'm having trouble imagining offset cam dowel pins.
John
1992 VR4 Garage Mistress
1993 VR4 Sold 2-14-09
1994 VR4 Parts Car
