#11 (permalink) | |
On everything else in any car, proper fluid level brings the fluid level just to the bottom of the seals. |
#12 (permalink) | |
Smooth and Fast
Negative, it has the correct amount of fluid in it. We discovered this after a day at the track. We'd get home and find the t-case 2/3 of the way empty from spec levels. We had new seals, not any big signs of oil on the drive shaft, so we refilled the t-case, installed a camera under the car and went back to the track. To our surprise at high speeds the overflow nipple was where it was coming out. With this reservoir in place it gives it somewhere to go, then can drain back into the t-case. Erron S.
Want to see a hot lap of my Stealth?
http://3svideo.vidiac.com/video/acfd...6e012f3f5d.htm Or, drag racing... http://3svideo.vidiac.com/video/c07a...b801720019.htm www.stickyvinylgraphics.com Custom vinyl and yes, now accepting aps for 2009 sponsorships! (Cars, Planes, and Bikes) More pics of my car... http://profile.imageshack.us/user/Blueveloscity/ |
#13 (permalink) |
3STech decimates all
So you don't store extra oil in the reservoir, correct? You just let it 'blow out' up the tube into the reservoir and then drain back.
I like it and will install one on the race car and maybe my street car too as she occasionally sees triple digit speeds.
![]() Maddog Performance Engineering - - - Home of the 13T Record Located off of I-294 near 127th St. and Rt. 83 For a sales rep, please call 630-890-5033. Special this month: Ridiculously high shipping and handling charges are waved now that we've bought Vipers for everyone on the staff. Notice: We've discontinued use of our over-hyped and never-raced shop car so that our customers can test all of our products. We've done so much for 3S owners, that you should just trust us. |
#14 (permalink) | |
Smooth and Fast
I love your sig pic too, that's killer. Erron S. |
#15 (permalink) |
Good idea with the vent, seems the way to go. I`ll be re-sealing mine anyway, may opt to fill it higher than stock.
JDM GTO TT, Emanage Blue - 450`s Hotwired Walbro - K&N - Blitz SSBC Port Methanol Injection - E85 - 12.4@115 |
#16 (permalink) |
Interesting. I will keep an eye on mine for fluid loss out the breather. I wouldn't imagine that much fluid would come out up there, but if you're saying your resevoir is getting fluid into it, and then is pouring back down, there would be a substancial leak out of that breather for sure, and then the obvious problem results.
I am very anal about cars leaking fluids. All but one of my cars leaks a drop a week if any at all, and I keep it that way. |
#17 (permalink) | |
*Insert Evil Laughter*
#18 (permalink) |
Weekly checking of the t-case oil is tough. I work at Jiffy Lube and still have a hard time checking my fluids. But one thing that might make it easier is to just go to a jiffy lube and make them check it. We check and top off fluids for free all day. It doesn't take too long either.
#19 (permalink) |
I have yet to have gone to a "jiffy lube" and Not had them mess something up. No offense as I would feel fine about having a fellow member like yourself do it... but 99.9999% of those places don't give a flying fuck about you or your car, and will only do what is totally convenient to them. Overtighten drain bolts. crossthread.. install wrong oil. overtighten oil filters. Do a totally different job then the one I asked for. Joyrides. Hell they couldn't even drive my car into the garage.. they kept killing it so I had to do it. And did you see that news video about them?
It's been a long time since anyone but me or my friend and fellow member Rick Pierce have touched my car. sorry about my off topic rant.. but seriously.. that is terrible advice |
#20 (permalink) |
We can make it better!
can I just put something out there on this one...are we 100% certain that filling the transfer case to the very top is what mitsubishi intented? do other transfer cases run the same way?
where I'm going with this, is if you over fill it, is it going to be spinning fast enough at these high speeds to be frothing up the oil and that's why it's being pushed out the overflow cap? anyone with the CAD drawings on the transfer case know exactly what level the oil would be at when filled with exactly what mitsubishi recommend? I love the whole fluid level sensor, that's uber, even better would be level and oil temperature, going even further how about tempteratures on ALL the oil places..(gear box...rear diff, trans etc etc) you might need to "shape" a spot for your sensor though so as going around corners does not give false empty's...
