Old 09-28-2007, 02:30 PM   #1 (permalink)
keithmac Level 1keithmac Level 1
Default Remote oil resevoir for TC?.
Having just read the thread on a destroyed transfer case due to lack of lubrication, and the amount of TC`s that seem to let go; plus the official recall from Mitsubishi it seems something needs to be done to prolong the life of the TC.
Checking the oil weekly is a good idea but it`s a pain in the arse to do, plus due to the small amount of oil in there even a minor leak can be fatal to the TC in a short period of time.
I`ve been thinking along the lines of a remote tank to allow more oil capacity, and be a lot easier to check the level on. You could run a fill (and vent line) into the engine bay and have it relatively easily accessible for checking, plus if the system held 1l of oil there would be less chance of a minor leak wreaking the TC.
Other option is to have a fill and vent line tapped into the gearbox, so the TC is supplied with gearbox oil, same again 2.5l oil in system is a lot better than only 300cc..
Anyone have any ideas on this?.
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - Gutted MAS - K&N
Blitz SSBC - Aquamist Water Injection
keithmac is offline   Reply With Quote
Old 09-28-2007, 09:14 PM   #2 (permalink)
9B's Try me in 3rd!!!
ES 3000TT's Avatar
Drives: ES 3000TT
Trader Rating: (25)
ES 3000TT is an unknown quantity at this point
Default Re: Remote oil resevoir for TC?.
what im wondering is how do we stop the transfercase from over filling itself if we incorporate a reservoir in the engine bay.
ES 3000TT
Soon something else!!
2 of 2 in the US!
ES 3000TT is offline   Reply With Quote
Old 09-29-2007, 05:42 AM   #3 (permalink)
twinblown's Avatar
Drives: Sole Survivor
Trader Rating: (9)
twinblown is an unknown quantity at this point
What we would need here is a TC low level warning indicator. I just don't see how that could be acomplished but if anyone has ideas post.
twinblown is offline   Reply With Quote
Old 09-29-2007, 01:15 PM   #4 (permalink)
Low level indicator would be nice, bit I don`t know how you`d be able to do that, as for the oil level being higher up I`m going to have a look into that, if the vent was also higher you could effectively fill the TC case (don`t know if a full TC is good or bad idea though) and vent into the resovior.
It`s just an idea to pick over at the moment.
Old 09-29-2007, 01:35 PM   #5 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (27)
John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7
I have a low oil level indicator. I just don't have a good way to mount it in the transfercase. IT is an electronic sensor that when it is not covered in oil it makes a warning buzz or lights a light.
The threads on the oil drain an fill is something weird like 18x1.25MM?? You can put a banjo bolt on the drain plug and a straight fitting on the fill hole and you now have an way to hook up a remote reservior
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/
For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings
http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/
John Monnin is offline   Reply With Quote
Old 10-01-2007, 12:14 PM   #6 (permalink)
Stealth Aficionado
Drives: 1995 Stealth TT
Trader Rating: (33)
OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7
The biggest thing would be limiting oil flow into the TC so it wouldn’t overfill.
Tony M.
1995 Dodge Stealth R/T Turbo - 12.46@115.77
2007 Dodge Ram 1500 4x4 - 15.2 mpg
OwnGTP/WantRTTT is offline   Reply With Quote
Old 10-01-2007, 05:43 PM   #7 (permalink)
Wrenchmonkey #839
Drives: crappy SHO
Trader Rating: (27)
You have to keep the reservior the same height as the transfer case.
Old 10-02-2007, 06:48 AM   #8 (permalink)
Stealth Aficionado
Trader Rating: (33)
Yes you would, but that would sort of defeat the purpose of it being easily accessible. It could still be more accessible than the TC itself though. Maybe locate it on the front cross member . . .
Old 10-06-2007, 01:39 PM   #9 (permalink)
Had a poke about under the car and it would be a tight fit to run the lines, can be done though, also found I`d lost 100ml (a 3rd!) of the TC oil, it`s Shockproof Heavy as well so quite thick..
Never noticed any red oil stains at work or home where I park it.
Also noticed the fill and level bungs aren`t that far off height wise.
Old 10-09-2007, 03:22 PM   #10 (permalink)
Smooth and Fast
Erron Spalsbury's Avatar
Drives: E-Mod Race Car
Trader Rating: (13)
Erron Spalsbury Level 2Erron Spalsbury Level 2Erron Spalsbury Level 2
I've had a reservoir on my TC for years. One thing to note, over 120~ish in these cars will start to empty the TC. I installed a reservoir in the engine bay, connected it with some AN line and fittings. I can pull of the track and find ounces of fluid in the res, it then drains back into the t-case.
Erron S.
Want to see a hot lap of my Stealth?
http://3svideo.vidiac.com/video/acfd...6e012f3f5d.htm
Or, drag racing...
http://3svideo.vidiac.com/video/c07a...b801720019.htm
www.stickyvinylgraphics.com
Custom vinyl and yes, now accepting aps for 2008 sponsorships!
More pics of my car...
http://profile.imageshack.us/user/Blueveloscity/
Erron Spalsbury is offline   Reply With Quote
