Old 08-23-2008, 03:17 PM   #1 (permalink)
Damn It!
3startuna's Avatar
Drives: Without Traction
3startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 73startuna Level 7
Default The OEM parts limitation thread
Goal: The Idea behind this thread is to list the limitations of various OEM parts, and provide a rough estimate as to when we need to upgrade.
Reason: To prevent owners from spending money getting aftermarket parts that are actually a lower quality than OEM. The idea is to share the information collected by the bigger 3S guys, so future tuners can make better decisions when building so that we can continue to advance the platform
Who can post: Anyone! please feel free to post pictures of failed parts, and a brief description of how you think the part failed. Also please feel free to correct any mistakes. Where ever possible please quote your sources I would like this thread to be as accurate as possible
What will I do: As we reach a consensus for determined a generally accepted limit for the part, I will edit this post, to show that limit.
Rules: NO FLAMING, no retarded posts like "FWD tranny good for 5whp" , or "the rod broke because its cheap crap" Please keep the discussion serious.
So lets Start:
Stock Rods:
Stock crank: Good for low 9s, 1000whp
Bearings:
OEM head bolts: Good for 30psi to maybe 32psi and low 10s better than ARP
Factory head gasket: Good for 30psi to maybe 32psi with no head fixing(pinning/o ringing). Best option other than copper
Factory block: No limit reached
Valvetrain- in this section the purpose is to determine how high we can rev our engines before parts start failing. Also to determine what cams we can run safely on our factory valvetrain.
Stock Heads and cams Highest hp recorded so far 707AWHP 620AWTQ on E85 and 30psi and probably more
Factory Valves:
Factory valve springs:
Factory Lifters:
Drivetrain
Clutch FWD:
Clutch AWD:
FWD Axles:
Front AWD Axles:
Rear AWD axles: Good for 600-800 whp
FWD diff:
AWD Front diff:
Transfer case: Good for 1.3 60 fts and 9 sec passes
OEM Driveshaft:
AWD rear diff: No limit reached
FWD trans:
5 speed Getrag: Good for 9sec passes with Bell housing reinforced
6 speed Getrag: Good for 9sec passes with Bell housing reinforced
Factory flywheel bolts:
96 3000GT FWD TT -Rebuilt 2 bolt 8:1 block, balanced stock internals, valve job, 99 Lifters, Maximal Performance Motor mounts and valve cover!! Quaife LSD, ACT Max Extreme 6 puck, RPS flywheel, Greddy emanage Ultimate, custom fuel system i designed my self, profec B spec2, walbro 255lph, stock turbos, Braided steel upper and lower radiator hoses, KNN FPIK, FMIC, FM oil cooler, cusco Oil catch can, stillen DP, IPS 3" single, Full AC delete, stripped interior, Corbeau Forza 2 seat, 2 inch harness, ALL Greddy electronic gauges, brakes: 4 piston calipers from Yogurts TT, Hawk pads, Valvoline DOT 4, Russells steel lines
Coming soon:
Thats right 12G72TT
3startuna is offline   Reply With Quote
Old 08-23-2008, 03:40 PM   #2 (permalink)
Damn It!
3startuna's Avatar
Default Re: The OEM parts limitation thread
Headbolts
their has been some discussion that these are actually stronger than ARP. I plan to test this theory. At my school we have a tension tester, I am going to ask my teacher if I can load a factory bolt in it and stretch it to see where it breaks. IF anyone has a ARP bolt they want to donate for a comparison please pm me. I am willing to buy the bolt. This will be my contribution to the platform.
Here is a sample way to document failed parts in this thread. Please try to follow a similar format.
Part: FWD Diff
Miles at time of failure: 110,000 miles
Mods at failure/ approx hp: Intake, testpipe, maximal performance solid mounts, MSD plug wires
What were you doing at time of failure: I was driving at 35 mph to pick up my then girlfriend, when I heard a loud BANG. I pulled over and saw gear oil leaking.
Pictures of failure:
notice the missing tooth. it broke lose and shot a hole through the casing.
Theory: One of the teeth on the spider gears broke lose and shot through the bellhousing. This seems to be an issue with these trannies, as the FWD turbo DSMs that also use our trannies and diff have failed in the same way.
Source:
Personal experience
Back up evidence: The Quaife Automatic Torque Biasing Differentials
They have documented this issue with the DSMs
Their theory:
The number one reason people end up getting a Quaife differential in a FWD Eclipse. Wheel hop kills the stock diff. Once a piece of the stock little spider gears breaks off, the spinning diff housing droop kicks right through the bell housing and into the clutch. Ouch.
If you are making good power in a FWD Eclipse, you can get a Quaife before or after you make this mess.
Wheel hop in an AWD will break the spider gears in the stock center diff also. MOST of the time the broken gear pieces will stay contained with in the center diff housing. This gives you the option of welding it solid (cheap fix, loss in around town drivability) or buying a center LSD. Again... before or after you break it if you are making big power and getting ANY wheel hop.
Hp Limitation:
Unknown, it seems to fail due to wheel hop, I dont think I was making enough power to blow it up
Old 08-23-2008, 04:17 PM   #3 (permalink)
brutten's Avatar
Drives: 91-VR4 95-Spyder-VR4
Trader Rating: (25)
brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7brutten Level 7
+1 for keeping the stock spark plug wires
brutten is offline   Reply With Quote
Old 08-24-2008, 04:53 AM   #4 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7DCIV Level 7
I am going to add that if you do post in this you need to have better post then this. Why stock plug wires, experiances you have had with aftermarkets, which ones, and why.
Coop
To many mods to list.
Old 08-24-2008, 08:52 AM   #5 (permalink)
Damn It!
3startuna's Avatar
Coop
Exactly, we need more information as to why stock wires are better than aftermarket.
Old 08-31-2008, 03:34 PM   #6 (permalink)
Yank in Yorkshire
bjmsam's Avatar
Drives: 94 Stealth TwinTurbo
Trader Rating: (12)
bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7bjmsam Level 7
Thumbs up Re: The OEM parts limitation thread
Better yet, update the wiki.
...and stock ignition coils
Jim's Stealth in the Bavarian Alps, 2001Jim Matthews - Yorkshire, England, UK
Team3S, 3SI #30, GTOUK #155
http://www.the-matthews.com/stealth.html
Jet Black '94 Dodge Stealth R/T Twin-Turbo AWD AWS 6-spd
Active Suspension Damping, Active Exhaust Delete, 5300K HIDs
Ek2MFG dual-flex downpipe, Zorstec custom SS cat-back dual
A'PEXi SAVC-R Mk-I, MHI TD04L-13Gs, K&N FIPK, IPS SS Y-pipe
A'PEXi SAFC 5-knob, 450cc Black Tops, MirageCorp Logger, DSM SMICs
Mobil 1 & Redline fluids, Hotwired Denso 1020 Pump, IPO/SX AFPR
SCE 332x32/322x28 cryoed StopTechs, Wilwood proportioning valves
Winter: stock alloys 17x8.5-46, Hankook Icebear W300 235/45VR17
Summer: Enkei RPM2 17x9-40, Yokohama AVS ES100 245/45ZR17
Track: Enkei RPM2 17x9-40, Yokohama A-032R Hcomp 275/40R17
My reliable daily driver since Feb 1997!
bjmsam is offline   Reply With Quote
Old 08-31-2008, 05:40 PM   #7 (permalink)
brutten's Avatar
Trader Rating: (25)
Coop
If you are building a race car with crazy boost and HP numbers then you would likely be better served with ultra low resistance wires and NON resister plugs. For the 98% of us that are not attempting single digit 1/4 time slips the stockers are fine.
1.) OEM Wires are built they way they are for a reason. The aftermarket wire distributors only care about short term performance and will sacrifice quality and longevity in order to sell their product.
2.) If you search many users have solved misfire issues by going back to the stock wires.
3.) Easy to test them them for the correct resistance as acceptale ranges are in service manual
4.) You will NOT gain performance unless your stock wires are bad.
4.) My stock wires have 80K on them and work perfectly and until I see that my stock wires start to bleed voltage or arc, I am sticking with them.
If you want replace them with aftermarket get the MSD 8.5mm or anything else with the OEM style boot.
Old 08-31-2008, 09:06 PM   #8 (permalink)
Вanned
i3igpete's Avatar
Drives: GoPigGo v2.0
Trader Rating: (80)
i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7i3igpete Level 7
stock injectors are good for 11's
stock turbos are good for 11's
stock intercoolers are good for 10's
stock fuel pump is good for 12's
HOLY COW I'M TOTALLY GOING SO FAST OH FUCK
give him the stick DONT GIVE HIM THE STICK.
i3igpete is offline   Reply With Quote
Old 08-31-2008, 10:38 PM   #9 (permalink)
Isnt this a CAR SITE?
1Forest1's Avatar
1Forest1 Level 31Forest1 Level 31Forest1 Level 31Forest1 Level 3
I suppose this doesnt fit in your layout request, but as you are looking for solid info, here is a bit about the wires discussed above.
Sourced from Jeff Lucius. PM me if you want deleted as seems we are already getting off topic.
* MSD Ignition 8.5mm Super Conductor (40-50 ohms/ft)
* Accel Thundersport (150 ohms/ft)
* Taylor 8mm Spiro Pro (350 ohm/ft)
* Aurora ignition wire set (400 ohms/ft)
* Vitek Performance Cables (their web site does not mention resistance, but John Monnin measured them at about 800 ohms/ft; the label under Vitek's braiding says "Magstar Gold 8mm High Performance S-4 Stainless Steel Mag Wire" - thanks John!; Magstar wires are manufactured by Wiretec)
* Wiretec Magstar Gold (800 ohms/ft as measured by John Monnin)
* NGK Resistor Spark Plug Wire Set (2600 ohms/ft)
* Mitsubishi factory wire sets (3000++ ohms/ft)
* Car Quest brand wire sets (3000++ ohms/ft - Thanks to Bret for measuring these wires.)
* Magnecor KV85 (6000++ ohms/ft)
1Forest1 is offline   Reply With Quote
Old 09-01-2008, 08:02 AM   #10 (permalink)
never a dull moment
DCIV's Avatar
Drives: 92 VR4
Trader Rating: (12)
I am going to add onto petes a little
Stock intake mani good for 9's
Stock fuel rails good for 10's
Stock fuel system, minus the fuel pump, good for 10's
Coop
