Re: OBD II ----> Hybrid ECU swap
Well folks, no go. The 95TT cali spec ecu I put into my 97 does not log as is. The ecu plugs directly in, the car starts and runs fine, but it will not log. In looking at my friends 95 VR4, the connector itself differs by one connection. There is one connection the diag port has on his car that my diag port does not have. This is NOT a connection that lines up with one of the four pins from the hybrid logger cable. The diag port obviously has atleast one physical difference. I am at a loss at this point. The only difference between his car and the ecu I put in is his fed spec and my new ecu is cali spec. There must be a difference in the signals going to the diag port. I appreciate any info.
EDIT: I forgot this ecu had the 8065 overclock; its been a long day. Just got done talking with shiver, and he seems confident thats the reason it wasn't working with a friends hybrid logger that is NOT modified to work with the overclock.
