Old 05-28-2009, 04:41 PM   #21 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Drives: 1992 3000GT VR4
Trader Rating: (13)
SkortchGT Level 1SkortchGT Level 1
Default Re: My Evo 8 Maf conversion!
Originally Posted by DCIV View Post
a tuner could do this in about 2 pulls. I am sure the stock mas does bottle neck some but its no where near 400whp.
Coop
I don't know at what point the stock MAS becomes an outright bottleneck for power (there are a bunch of posts arguing this), however a bigger MAS that flows more then stock definitely provides gains over the stock MAS at any power level.
I've read a bunch of threads throughout the years (mostly on the ARC2), where people have switched to the ARC2 & bigger MAS option, and immediately noticed gains over the stock mas. There was even one about a near stock car with 9bs showing gains. Others were everything from 13gs up to TD05 flavors. I've seed the MAFT guys reporting the same gains.
From everything I've read, it seems as though you can't go wrong & gain a bit of power when getting rid of the stock MAS, regardless of your power level.
1992 3000GT VR4
--Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579
--First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, cat back & CFDS, time for another dyno run soon)
--Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, PST 1pc CFDS, Borla Catback, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, engine dress up kit, Bigtyla ground wire kit, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset.
--Waiting for me to install: ARC2 w/ 92mm MAS
--Daily Driver: 2000 Malibu, 6cyl, auto
SkortchGT is offline   Reply With Quote
Old 05-28-2009, 05:57 PM   #22 (permalink)
Please change my username
DSM Performance's Avatar
Drives: Black 91 TT
Trader Rating: (8)
DSM Performance is an unknown quantity at this point
Coop
Like I said earlier it is not about the flowing capacity (the size) but about the reading capacity in Hz, the Evo 8 Maf is to be more accurate over 2000Hz.
Woah my DSM turbo gave birth to a pair of twins!
DR16Ts, DR Boost cooler stage 2, PTE580cc, 5Zigen GN+, 13'' Stoptech, 2G rear brakes, new OEM shortblock, Evo 8 MAf conversion, PST CFDS + New driveline (rebuilted tranny/Tcase/rear diff), RPS max street clutch, Dejon' SMIC, 3'' custom quad tips catback, new leather seats heated, SAFC, S-ITC, HKS Twin power...
On the shelf : DR Stage 3 heads (for sale to buy DR750s), Denso 660cc, 3SX poly mounts...
DSM Performance is online now   Reply With Quote
Old 05-28-2009, 06:22 PM   #23 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
Your exactly right. Bigger mas is going to let more air in and most 99% of the time provide more power. My argument is 400whp is a horrible number to say the stock mas is the bottle neck. As we have seen time and time again ppl with big turbos make great power with stock mas and be over 400.
I guess the only way to really prove how big one would be is to go a mas run with a set up and then switch to speed density and see how much you gained. I do look forward to seeing back to back runs or some sort of evidence that this evo 8 maf will make more X amount more power is all.
Coop
To many mods to list.
DCIV is online now   Reply With Quote
Old 05-28-2009, 07:52 PM   #24 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
Coop
I agree, 400whp isn't touching any limitations of the stock mas. I'd also like to see back to back runs showing the EVO8 maf having an edge over the stock maf.
Old 05-28-2009, 10:04 PM   #25 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
I never said the Evo 8 maf will flow more air, just said that the reading capacity of the Maf (in Hz) is more accurate pass 2000Hz.
Old 05-29-2009, 11:52 AM   #26 (permalink)
Fidel Cashflow
SkortchGT's Avatar
Trader Rating: (13)
That's pretty cool though, nice work you did fitting it in the stock tubing and wiring.
Old 05-29-2009, 12:19 PM   #27 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
Thanks for the positive comment. I just wanted to share my experiment if it may help someone.
Old 05-29-2009, 03:24 PM   #28 (permalink)
Drives: 1997 TSi AWD 6 Bolt
uhlig is an unknown quantity at this point
The physical size of the MAF isn't the problem, the EVO MAF actually looks smaller. Anyhow, (I think) the argument of this thread is compensating for injector size by manipulating Karmann data- the Evo MAF is capable of flowing more air before hitting fuel cut (when the stock ECU runs out of fuel maps and just shits out).
I think it's a great idea since using a GM MAF will result in poor tune reliability. More so in the colder parts of the U.S. than the south, you will constantly have to retune them around here.
1997 TSi
6 bolt
272's
E85
33PSI
Daily driven transmission eater.
uhlig is offline   Reply With Quote
Old 06-08-2009, 06:19 PM   #29 (permalink)
Stealth Aficionado
Drives: 1995 Stealth TT
Trader Rating: (40)
OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3OwnGTP/WantRTTT Level 3
Exactly. And perhaps it isn't to the point of hitting fuel cut (i.e. "maxing out the MAF") but at the very least providing better resolution with what looks to be a more acceptable correction factor than the stock MAF. Anything that can be done to minimize the amount of correction to run larger injectors on a piggy back is helpful due to timing and response/tip-in settings.
Nice work DSM.
Tony M.
1995 Dodge Stealth R/T Turbo - 12.46@115.77
http://www.rickperry.org
OwnGTP/WantRTTT is offline   Reply With Quote
Old 07-28-2009, 10:03 AM   #30 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
I just talk with Mellon, he's on evolutionm.net too, and he's running a 700WHP evo (so far) with stock MAF (and stock ECU).
So if ECM tunning delivers this fall the EPROM conversion package, anyone could do that EVO 8 Maf conversion and run, for example, a twin E3 16G set-up (and similar) and keep the stock ECU/stock MAF!
I've ran speed density, GM MAF and stock MAF on my DSM and for me running stock ECU (with DSM link) with stock MAF is what I preffered hand downs for my all season daily driven car.
