Old 05-27-2009, 01:38 PM   #1 (permalink)
Please change my username
DSM Performance's Avatar
Drives: Black 91 TT
Trader Rating: (8)
DSM Performance is an unknown quantity at this point
Default My Evo 8 Maf conversion!
For those who didn't knew, they are compatible for our platform with a little help!
I decided to share my experience, so it may help some other people. (Bare with me that english is my second language).
As you know our stock MAF is pretty maxxed around 400WHP, which is not so hard to reach with a TD04 upgraded turbo and some boost. I didn't want to remove some honeycomb or go with a MAFT and I decided to go ahead and try a Evo 8 maf (3G eclipse maf). I bought one from a guy who went for a AEM EMS.
I received the Maf and saw that the outlet was circle instead of oval, and the connector was different too. So I had to buy a connector since we cannot order that single part new.
In order to do that, I used a hockey puck that I've cutted with a jigsaw to add some volume and give the same oval shape that fit into the snorkel of ours :
Added some epoxy :
So it fitted very well :
The connector is different but they share the same number of wires and the pinout is in the same exact order, I added the new connector on the wire, left the stock connector in case it went bad, so I have 2 connectors now :
For the tunning, some compensation are needed, one of my friend gave me this link and I was suprised to find that the DSM world allready knew about that viable option :
evo8mafsettings [ECMTuning - wiki]
Freq Adj
50hz 31%
150hz 29%
250hz 25%
400hz 24%
800hz 19%
1200hz 20%
1600hz 19%
2000hz 19%
2400hz 19%
I only have a S-AFC and S-ITC, so the compensation is done per RPM and not Hz, but I did it pretty simple with a friend of mine, 50hz is the idle, 150hz is about the cruise...
So if you have a -34% compensation on all the RPM (about what I had with 580cc). The 1000 rpm is now -3% (-34% + 31%), the 2000 rpm is now -5% (-34% + 29%) the WOT 4-8000 rpm is now around 15% (-34% + 19%).
I just put those numbers into my SAFC, I started the car and it was running like I never touched it! No knock, everything perfect at 10psi (16Ts), so we raise the boost up until 20psi and did only some light adjustement, still we had to remove some timming in the upper range. But the car was running so great, even smoother then before, very linear!
At 20psi we felt that the stock catback was pretty much restrictive and so I'm now waiting on IPS new exhaust to go on the dyno to fine tune that!
Evo 8 Maf are easy to find and not so expensive on Mitsubishi Lancer Evolution | Reviews, News, Parts, Owners - EvolutionM.net or other Evo forums, they usually go with AEM EMS and can sell their old MAF (with connector).
Woah my DSM turbo gave birth to a pair of twins!
DR16Ts, DR Boost cooler stage 2, PTE580cc, 5Zigen GN+, 13'' Stoptech, 2G rear brakes, new OEM shortblock, Evo 8 MAf conversion, PST CFDS + New driveline (rebuilted tranny/Tcase/rear diff), RPS max street clutch, Dejon' SMIC, 3'' custom quad tips catback, new leather seats heated, SAFC, S-ITC, HKS Twin power...
On the shelf : DR Stage 3 heads (for sale to buy DR750s), Denso 660cc, 3SX poly mounts...
DSM Performance is online now   Reply With Quote
Old 05-27-2009, 02:49 PM   #2 (permalink)
broke joke
Drives: 6spd 92'
zba857 is an unknown quantity at this point
Default Re: My Evo 8 Maf conversion!
This is awesome! It just doesn't look like it would flow more.. Not saying it doesn't. In my mind it looks like the stocker has more area for air flow
zba857 is offline   Reply With Quote
Old 05-27-2009, 02:54 PM   #3 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
It's not about the honeycomb area size, but about the reading capacity of the MAF, it can read about 20-30% more Hz.
Old 05-27-2009, 03:07 PM   #4 (permalink)
broke joke
Drives: 6spd 92'
ohh i see! (for the record.. your english is great!)
Old 05-27-2009, 03:08 PM   #5 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
For example, I made 16xxhz, but with a -15% correction on the SAFC, so the signal from the MAF was around 1900hz (1900 -15% = 1615Hz).
A stock untouched MAF is good for about 2000Hz... +/- 200Hz depending of the Maf.
I'm allready on the verge to max the stock MAF, 1900Hz on 2000Hz capacity. Just adding a catback, tune the car and raise the boost a little and then my MAF saturated!
Old 05-27-2009, 03:09 PM   #6 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
Thanks I try!
Old 05-27-2009, 05:01 PM   #7 (permalink)
never a dull moment
DCIV's Avatar
Drives: 93vr4 & 92vr4
Trader Rating: (13)
DCIV Level 1DCIV Level 1
please elaborate on how our stock mas are maxed out at 400whp? There are plenty of tdo5 cars that have way more then 400whp and have stock mas. Heck like you said alot of tdo4 cars have it and it sure isnt the mas thats holding them back.
Coop
To many mods to list.
Old 05-27-2009, 05:12 PM   #8 (permalink)
keithmac is an unknown quantity at this point
I`ve seen over 3100hz on the stock MAF with td04-16g`s, all the screens in..
AOL`s stolen my picture!.
JDM GTO TT, Emanage Ultimate - 780`s, E85
Hotwired Walbro - 13g`s - K&N - Blitz SSBC
13g`s - 12.4@115
TD04-16g`s - 12.5@117 (work in progress!).
keithmac is offline   Reply With Quote
Old 05-27-2009, 06:18 PM   #9 (permalink)
Drives: Black 91 TT
Trader Rating: (8)
Well, most of my info came from the DSM world. It may me higher, depending on the MAF, but it can differ from one to another.
Here are my other sources :
I asked to Steve from 3SX and he was talking that we can get close to 500WHP but it was pushing the limits and the effiency would be compromise :
Have Questions? Get answers from the experts at 3S Motorsports
And I asked to MaTT too, because I bought the turbo from him and I'm running the same turbo as his DD (16Ts), and he told me :
''With a stock un gutted MAS my car would not even make more then 19psi of boost with the boost controller maxed out. Gutting/porting the MAS as the only changes I can spike as high at 27.''
So in my book, those 2 are reliable source, my DSM experience showed me about the same and 2 very good local tuner confirmed that too. So instead of gutting mine I decided to try a Evo 8 maf.
Old 05-27-2009, 07:09 PM   #10 (permalink)
never a dull moment
DCIV's Avatar
Trader Rating: (13)
I would love to see some back to back info to support your theorys. It shouldnt be hard as the mas is an easy thing to switch.
Coop
