Old 11-21-2007, 10:50 AM   #71 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
Trader Rating: (16)
linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
Im in if it will work for the 99.
Project: Conqueror
Commence countdown
linchpinjoe is offline   Reply With Quote
Old 11-27-2007, 09:34 AM   #72 (permalink)
Let-luse's Avatar
Drives: 99VR4-93NA-CLS-H2
Trader Rating: (19)
Let-luse Level 3Let-luse Level 3Let-luse Level 3Let-luse Level 3
Thumbs up Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
Oh it works... and it works GREAT!!!
I tried version 2.0 on my 99 Saturday night. Did many third gear pulls and it worked like a charm. It logged knock and the sample rate was around 80/sec...
I wanted to check if the knock sum values were accurate so I put about one gallon of regular fuel on the car, lowered the boost to 7 psi and did a couple of third gear pulls and I got about 10 to 14 counts of knock! (So much for those saying that it's OK to run regular gas on a stock car!)
Then I filled up the tank with premium gas and at the same BP of 7psi, I didn't get any knock. Then I cranked up the BP gradually up to 13-14 PSI (spike to 14 PSI then 13 up to 6K rpms) and no knock whatsoever on WOT pulls (13GS with stock injectors).
So I guess the knock readout is accurate!
However, I am still getting some part-throttle and throttle-transition knock (10 to 14 counts). I think that it's because I am running a hotwired Supra pump with the stock FPR. I am gonna put back the AFPR and see if that solves the problem.
I just LOVE this thing and highly recommend it to anyone with an OBD-II 3S. This thing just opens up a world of possibilities to us OBD-II owners who have been deprived of a useful logging solution for too long.
It is loaded with features and my favorite one is the custom warning trigger that you can set to whatever you want (ex: you can set the trigger to RPM>3000, Throttle>60% Knock>7 so if you are at more than 3000 rpm with the throttle opened more than 60% and you get more than 7 counts of knock, it will warn you).
The graph readout is also excellent and you can load 2 logs to compare the data. I am still not done exploring all the features but SO FAR SO GOOD.
I have the cable hooked up to a Tablet PC (a sort of mix between a pocket PC and a laptop) so it's very convenient to use. I just tuck it between the passenger seat and the central armrest/glovebox.
I will post some logs and screenshots later.
BIG THANKS TO THE OP AND TO TOMMY FOR HELPING US FIND THIS GEM!
Reda/
P.S: The only thing I found that is not working 100% is DTCs. I have a CEL (Code P0400 EGR) that the SM3 shows. Evoscan picked it up too but also displayed a Baro DTC (SM3 doesn't show that and I don't think that I have an issue with Baro) and it couldn't clear the codes (CEL is still on).
However, full DTCs support should be available with next release. Come on guys, the more of us will buy this the more support we will get.
Cuz 99s are cooler than 98s... :P Im not going to add fuel to this fire, so im just gunna go outside and hump my combat wing.
93 NA - 99 VR-4
Let-luse is offline   Reply With Quote
Old 11-27-2007, 09:41 AM   #73 (permalink)
oohnoo's Avatar
Trader Rating: (128)
oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5
AWESOME NEWS!
I have one also but just haven't had the time to hook it up and test it.
oohnoo is offline   Reply With Quote
Old 11-27-2007, 10:24 AM   #74 (permalink)
Let-luse's Avatar
Trader Rating: (19)
Originally Posted by oohnoo View Post
AWESOME NEWS!
Indeed!
Now quit slacking and go try it out!
I forgot to add, if you have an innovate or a zeitronix WB, you can also log it with Evoscan!
I have an LC-1 but I haven't tried this feature yet (can't find the damn terminator plug!). I guess I'll just have to do with logging ONLY knock for know... LOL!!
Reda/
Old 11-27-2007, 10:39 AM   #75 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (16)
tfw a-ok Level 1tfw a-ok Level 1
AWESOME NEWS!
Hook yours up and try it Bob. I'm having a problem with this version and cannot connect. Need to know if you can or not. Keeps telling me to turn off the ignition then back on again to connect. Something simple I'm sure but just querious if you can connect with your '97 and cable variation.
Originally Posted by DomGT View Post
For some reason I idolize Tommy Williams. Maybe it's his perfect example of a 3000GT. I haven't been on the board in about a month, can somebody fill me in?
I have a new cellphone number, had to change it. 516-491-9004, call anytime for random 3/S funfacts.
tfw a-ok is offline   Reply With Quote
Old 11-27-2007, 03:53 PM   #76 (permalink)
Drives: 99VR4
Trader Rating: (16)
Ima poop my pants, srsly !
Old 11-27-2007, 06:58 PM   #77 (permalink)
rbaney's Avatar
Drives: 94 stealth,94 Bronco
Trader Rating: (10)
rbaney is an unknown quantity at this point
So does anyone know when a version will be avialable that will clear the SRS light? I am interested if this comes through.
1994RT Luxury Comming soon Knight M90 supercharger and DEFT 575 hood
rbaney is offline   Reply With Quote
Old 11-27-2007, 08:11 PM   #78 (permalink)
Stealth Like A Ninja
Darksurfr's Avatar
Drives: '91 Stealth TT
Trader Rating: (14)
Darksurfr is an unknown quantity at this point
oh man. what fun it would be to find out why my ABS light is still on. I think the pump is shot because its a big rust ball but who knows. and the SRS light is on but im thinking it might be the clock spring. I guess in time i might be able to diagnose things like at school with the TEC stream for the Toyotas.
ECG 2005 / Attended ECG 2006 / Attended
ECG 2007 / Attended ECG 2008 / Attended
NEG 2005 / Attended
NEG 2006 / Attended NEG 2007 / Attended
Member of 3SNJ
Darksurfr is offline   Reply With Quote
Old 11-27-2007, 08:27 PM   #79 (permalink)
Drives: 99VR4
Trader Rating: (16)
So would something like this be able to clear CEL codes right before i take it to emissions?
Old 11-28-2007, 07:13 AM   #80 (permalink)
CI Member
The Twins's Avatar
Drives: 96 VR4
Trader Rating: (9)
The Twins is an unknown quantity at this point
i bought this but i am waiting for my cable, how long did it take to for some ppl on here to get theres?
www.controlled-insanity.net
The Twins is offline   Reply With Quote
