LinkBack (1) Thread Tools
Old 10-02-2008, 12:16 AM   #431 (permalink)
eri536's Avatar
Drives: 1997 pearl white vr4
eri536 is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
does anyone have any problems with the cable being able to measure the rear o2 voltage?
97 white vr4
Current car
96 white vr4 - RIP
2000 eclipse gt - biggest p.o.s ever
eri536 is offline   Reply With Quote
Old 10-06-2008, 09:03 AM   #432 (permalink)
comm4nd3r's Avatar
Drives: a black vr4
comm4nd3r is an unknown quantity at this point
Jumping on this thread. I have a 96 VR4 and looking for a datalogger that can monitor knock.
This is an extremely long thread so i apologize if these questions have been asked before.
Are there any connection issues with the 96 ECU?
Also, does the software work OK with windows Vista?
1996 VR4 --- Mods Done: Stillen Air Intake Kit --- Greddy Type-RS BOV (recirc) --- 3SX Stainless Steel Downpipe w/ rear precat eliminator --- Joe P MBC
On Order: ACT MB2-HDG6 Clutch and RPS Billet Segmented Flywheel
comm4nd3r is offline   Reply With Quote
Old 10-06-2008, 12:03 PM   #433 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
Originally Posted by linchpinjoe View Post
I'm still a big nub when it comes to this tuning stuff, but I do recall someone from GTpro telling me and some other people that the 99 ecu is flashable. Is that the same concept as what the wrx's have as a kind of "learning" ecu?
My open atmosphere hks made my car run like shit for about a week, and it seemed to correct itself, and the car runs perfect ever since. {2 years ago}
Nah, two different things.
A learning ECU will basically take volatile, short term memory to learn to adjust things slightly to try to hit a target A/F, etc. When the battery is unplugged, it's gone from memory. You also can't overwrite or change any of this; it's the way the ECU handles the actual map settings it's receiving from the tune itself. In your case, since the car was probably almost stalling constantly from running VTA, it will try to adjust A/F in that load area, until it stops or reduces the stalling. But, if you disconnect your battery for a few minutes, it should go right back to running like crap.
IIRC the 99 ECU IS indeed flashable, but is very cost prohibitive since they are so small in number and would require special software as well. A flashable ECU will let you adjust timing, air/fuel ratio, idle rpms, fan speed settings, and more. The flashable evo ECU has been hacked to even add no-lift-to-shift (NLTS), a valet mode (RPM can't exceed a specific user-set value), etc. It completely eliminates the need for a piggyback system; think of it as almost an AEM built into the car.
Now, that said, it's what I know based off the flashable EVO ECU; but I'm relatively sure it would be the same for the 3S world (or any other platform).
Originally Posted by lazyasianboy View Post
I have a 1995 3000GT Hybrid, which cable do I need to buy? cable + price? And would I be able to clear SRS Light with this? I don't feel like reading through 43 pages of posts to find my answer if it was asked previously. Thanks alot.
Originally Posted by eri536 View Post
this cable does not clear the srs light
Correct, it won't clear any CEL (that I'm aware of). The framework is there in the software, but isn't functional last I heard.
Numerous people have connected to 96 ECU without a problem, as it is OBDII, and what EvoScan was designed to natively support.
I have been able to use it to connect to my evo under Vista without any issues.
Selling my 95VR4 coupe.
http://www.3si.org/forum/f10/95-3000...10-xxx-439661/
Bought a spyder.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 10-06-2008, 02:51 PM   #434 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7linchpinjoe Level 7
Thanks for the info, I'm looking into so sites and even more info regarding flashes for the 99.
"The Journey To Perfect, And To Conquer It's Definition"
linchpinjoe is offline   Reply With Quote
Old 10-06-2008, 06:38 PM   #435 (permalink)
Low and Slow
kywhitelightning's Avatar
Drives: 98 vr-4
kywhitelightning Level 1kywhitelightning Level 1
That would be great if you can get someone to flash ours.
Current: Blitz DSBC, Blitz FATT, 3SX poly mounts & lightweight crank pulley, RPS clutch & flywheel combo, K-Sport coilovers tastefully lowered w/ 3SX camber arms, IPS quad tip.
Going in now!!!!: 19t's, MAFT Gen 2, 550's, Walbro 255, FMIC, W/M injection and Tial 50mm.
Later on: new shorty.
kywhitelightning is offline   Reply With Quote
Old 10-06-2008, 07:06 PM   #436 (permalink)
Drives: 99VR4
A GM master tech was talking to me sat night at a car show, he has a wrx, he was saying there's a good chance that we may have a similar ecu as the eclipses that proceeded us after 99. And that there should be a flash that will work, im trying to get some answers on openecu.org
Old 10-06-2008, 07:33 PM   #437 (permalink)
Low and Slow
Drives: 98 vr-4
Keep up the good work and keep us posted because I'm very interested in this.
Old 10-06-2008, 07:45 PM   #438 (permalink)
Drives: 99VR4
Id easily pay 500 dollars for something that would work for the 98/99
Old 10-07-2008, 02:23 AM   #439 (permalink)
Low and Slow
Drives: 98 vr-4
Agreed!
Old 10-07-2008, 10:43 AM   #440 (permalink)
Paid Member
jba3's Avatar
I'm not sure what a 99 ECU sells for, but you'd have to add that to the price of the flashing software / hardware. Not to mention, adding in a flashing port (where the white part of the tactrix cable would plug), and, IIRC, the 99 ECU has a slightly different pin config (at least for wiring an AEM?) than the previous years. There's something like 287 authentic 99's out there ... a VERY small market to say the least.
If the cost approaches AEM territory, I think an AEM would be better as it has individual cylinder management, 2-step launch control, etc that the stock ECU isn't capable of.
However, I'd love to see some tech advances for the platform.
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f42/mitsubishi-mut-ii-mut-iii-datalogger-395561/
Posted By For Type Date
Norcal3s.com :: View topic - Updated (((Mitsubishi MUT-II/MUT-III Datalogger))) This thread Refback 04-10-2008 12:24 AM
