#31 (permalink) | |
Sorry about the misunderstanding - 25.00 isn't alot.
![]() 1999 VR-4 K&N Intake * Greddy FMIC * 2.5" DP (No PreCats) * 3" Exh * Walbro 255 * AEM TruBoost * AEM EUGO * Prosport FP |
#32 (permalink) | |
Wow that's pretty cheap if it does work.
![]() 12.935 @ 106.58 - 1.911 60' - I/E/MBC@15PSI - Daily Driver Last edited by TwIzTeD_3kGt : 11-07-2007 at 09:33 PM. |
#33 (permalink) |
Volunteer FireFighter
yes the MUTT II protocol is embedded into the cable and software transfer. this will work.
i cant wait, definitely worth the money.
![]() Mods- 4" Intake, Modded Throttle Body, Re-Grind Cam Shafts, Big Tyla's Ground Wire Kit, Eibach Pro Kit Lowering Springs, NGK Copper Plugs, Accel Thundersport 300+ Red Spark Plug Wires, 6000k HID Kit, 99 Garnish, Prosport Gauges, Evolke 17" Wheels, Hella Optilux Fog's, Custom Exhaust, Clear Corners |
#36 (permalink) |
Ahh ok.
Just realized last night, if this works, I need a laptop now I might have one laying around in a closet somewhere at my 'rents house. I know I used to use one for school, don't remember what happened to it. |
#37 (permalink) |
There are two cables:
The EvoScan 1.4E USB OBDII DataLogger Cable The EvoScan 1.3M USB OBDII Datalogger & ECUFlash Reprogramming Cable BOTH have the PIN 1 grounded but you should get the 1.4E as our ECUs are not flashable. There is a discussion on the possibility of flashing 98-99 ECUs but even if they were, there is no support and it would be useless since it would be limited to 98/99s which are the most rare VR4s so chances are we would have to start from scratch and would have next to no one to turn to for advice or map sharing so I'd take an AFC over flashing ECUs anyday. I received my cable today. I am gonna try it over the week-end on my 99 VR-4 and I'll post results ASAP. Hopefully, I'll be able to see knock!!!!!!! If it does show knock that will be the most groundbreaking advance for us OBD-II guys! CAN'T WAIT FOR FRIDAY NIGHT!!!!! Reda. |
#39 (permalink) |
its a big step in data logging for us 3s'ers. hybrid guys the most as this software is 3x the cost anywhere else.
accompanied with the service manual cd combo i just bought. any problem will be easy .. |
#40 (permalink) | |
FWIW: I ordered the 1.3M cable because it said (in the description) it did everything the 1.4E did plus be able to reprogram (which is currently limited to Evo's). |
