Old 07-08-2008, 01:14 AM   #331 (permalink)
Low and Slow
kywhitelightning's Avatar
Drives: 98 vr-4
kywhitelightning is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
Is this fact? 98-99 VR-4's can be reflashed. Anybody done it or even tried? Very interested.
Current: Blitz DSBC, Blitz FATT, 3SX poly mounts, K-Sport coilovers tastefully lowered w/ 3SX camber arms.
Future: 15G's, MAFT Gen 2, 550's, Walbro 255, FMIC, new shorty, IPS quad tip
kywhitelightning is offline   Reply With Quote
Old 07-08-2008, 06:36 AM   #332 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (19)
tfw a-ok Level 2tfw a-ok Level 2tfw a-ok Level 2
I downloaded the 2.4 version lastnight. Hamish said there were some additional bugs that got into the 2.3 release candidate that had to be addressed. No biggie!
Anybody else running the 2.4v or had problems with the 2.3 ?
tfw a-ok is offline   Reply With Quote
Old 07-08-2008, 06:45 AM   #333 (permalink)
Let-luse's Avatar
Drives: 99VR4-93NA-CLS-H2
Trader Rating: (20)
Let-luse Level 3Let-luse Level 3Let-luse Level 3Let-luse Level 3
Yes they can be reflashed in theory. However, last I checked the EVO 4/5/6 ECUs which also have H8 based ECUs couldn't be reflashed since no one was able to come with the H8 flash initialization code. A this point it's read only which means you can download the ROM and even modify it but you can't flash it on the ECU.
EVO 4/5/6 owners got around that by switching their ECUs to EVO 8/9 ones.
Reda/
Originally Posted by linchpinjoe View Post
Cuz 99s are cooler than 98s... :P Im not going to add fuel to this fire, so im just gunna go outside and hump my combat wing.
93 NA - 99 VR-4
Let-luse is offline   Reply With Quote
Old 07-08-2008, 08:59 AM   #334 (permalink)
Low and Slow
Drives: 98 vr-4
Thanks Reda I know I can always count on solid advice from you.
Old 07-08-2008, 09:08 AM   #335 (permalink)
Let-luse's Avatar
Trader Rating: (20)
Anytime buddy!
Old 07-08-2008, 06:04 PM   #336 (permalink)
eri536's Avatar
Drives: 1997 pearl white vr4
eri536 is an unknown quantity at this point
98 and 99's CAN be reflashed its just that there are so few 98's at 231 and 99's at 287 that there is no aftermarket support for doing so
97 white vr4
Current car
96 white vr4 - RIP
2000 eclipse gt - biggest p.o.s ever
eri536 is offline   Reply With Quote
Old 07-08-2008, 09:24 PM   #337 (permalink)
Healther Stealther's Avatar
Drives: '91 Stealth R/T TT
Healther Stealther is an unknown quantity at this point
Will this work on '91 Stealth RT/TT?
Healther Stealther is offline   Reply With Quote
Old 07-15-2008, 08:16 AM   #338 (permalink)
prop7459's Avatar
Drives: 95 RT/TT
prop7459 is an unknown quantity at this point
It has been a month and I still have no cable. I wish Hamish had a better contact method besides email.
For your 91 RT/TT, I would use the MMCD software. Its free and you can use a palm PDA for logging.
prop7459 is offline   Reply With Quote
Old 07-16-2008, 09:49 AM   #339 (permalink)
Drives: 1996 VR4
Dunshster is an unknown quantity at this point
Where can I get version 2.4, and also where do you get the "Serial Number" when I'm installing the software. It neither came with the emails sent when I purchased the cable, nor did it come with the cable itself.
Dunshster is online now   Reply With Quote
Old 07-16-2008, 10:56 AM   #340 (permalink)
is drifting WAY too hard!
Deathsled's Avatar
Drives: only in 1st gear
Trader Rating: (20)
Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7Deathsled Level 7
damn late to this thread, but this is just what I need! Finally something that can read at high speed and log knock on 96+ ecus!
96 VR4: 13Gs + 10:1 compression + JDM final drive = well beyond BPU
Deathsled is offline   Reply With Quote
