LinkBack (1) Thread Tools
Old 07-01-2008, 07:52 AM   #321 (permalink)
Master of the Universe
ulrich's Avatar
Drives: with head out window
Trader Rating: (9)
ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7ulrich Level 7
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
Originally Posted by ulrich View Post
Did I get the wrong cable or something? I have a 1.3b (ordered a 1.3u) and it has an extra dongle thing to hook into another port besides the OBD2 port.. I thought this was only on OBD1's?
If not, where do I plug it in? It's obviously not getting a response from my car when I plug it in.
When I select Hybrid DSM/3000gt/Eclipse I get some data. OBD2 is greyed out, with "Mitsubishi" it keeps reconnecting.
Works now.. I have to select "EFI" from the drop-down menu. Choosing "OBDII" does not work.
-uli
1997 3000GT VR4
ulrich is offline   Reply With Quote
Old 07-01-2008, 08:03 AM   #322 (permalink)
Paid Member
jba3's Avatar
Drives: mitsu's stock up ^_^
Trader Rating: (16)
jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7jba3 Level 7
The small white plug is for the ECU writing port available in some cars such as the evo. The OBDII port is read only, but the small white one is writable.
If my posts have been helpful or informative, or even entertaining, rep is appreciated.
Old 07-01-2008, 12:51 PM   #323 (permalink)
Drives: 1996 VR4
Dunshster Level 3Dunshster Level 3Dunshster Level 3Dunshster Level 3
Originally Posted by Ray View Post
Interested in buying for my 1996 3000GT VR-4 that was produced in June 1995 will this "EvoScan StandAlone LCD ECUDataScan Display v1.0 (1994-2006 Mitsubishi" work like the stand alone cable and also allow me to hook it up to my laptop? It is like their answer to the Scanmaster. I have noticed that the cheaper 1.4E cable is no longer available was that for marketing purposes so that we have to buy the more expensive 1.3M cable we do not really need? Sorry if this has been covered. Thanks for your help, Ray
Also interested.
Dunshster is online now   Reply With Quote
Old 07-03-2008, 02:43 PM   #324 (permalink)
prop7459's Avatar
Drives: 95 RT/TT
prop7459 Level 1prop7459 Level 1
How long does it take for the cable to get here?? I have been waiting 11 days and didn't receive a tracking number yet
prop7459 is offline   Reply With Quote
Old 07-04-2008, 07:43 AM   #325 (permalink)
am385's Avatar
Drives: Black 99 VR-4
am385 is an unknown quantity at this point
its comming from new zealand, mine took about 2 1/2 weeks
ANDREW
AIM: Imanandydick
Black '99 Mitsubishi 3000GT VR-4
First one off the assembly line
Mods
Performance: RPS Stage II Street Clutch, K&N FIPK, HKS SSBOV,Turbo XS DSMBC @ 15 psi, Gutted Precats, 3SX Downpipe, 3SX Test Pipe, 3SX Light Weight Crank Pulley, 3SX Adjustable Control Arms, Shorter Throw Shifter, Custom Dimple/Slotted Rotors, SS Brake Lines, Hawk HPS Pads.
ICE: Alpine head, MB Quart 5.25 and tweeter 2 way in back replacing the 6X9s, Eclipse Co-Axils in the doors, no tweeters in the dash right now, Eclipse amp for components
Show: Itallian Leather Shift and E-Brake Boots, Chrome Mitsubishi Emblems, Momo Sphere Shift Knob
am385 is offline   Reply With Quote
Old 07-04-2008, 11:46 AM   #326 (permalink)
Ray
Ray
Ray's Avatar
Drives: 1996 3000GT VR-4
Trader Rating: (19)
Ray is an unknown quantity at this point
Originally Posted by Dunshster View Post
Also interested.
Can anyone out there answer this question or have we shut down the thread on this logger?
Ray is offline   Reply With Quote
Old 07-04-2008, 06:36 PM   #327 (permalink)
prop7459's Avatar
Drives: 95 RT/TT
It will work on your car. Tommy the tread starter has an 96 with a 95 build date also. I will read knock on Hybrids and OBOII cars. The more expensive cable are meant to reflash cars such as 98-99 Vr4's and 03-07 EVO's. Its has an extra pin for that on the cable not a huge price difference though.
Old 07-05-2008, 01:53 AM   #328 (permalink)
Trader Rating: (28)
Agent|99VR4 is an unknown quantity at this point
Luckily I grabbed the cable when they were all the same price...
If your not a 97+ there really is no need for the reflasher cable, its still very unchartered territory, and until something solid happens, Im glad I have it just incase.
Still doing the poly type mounts!
99 VR-4 Back to Life: Here
------------Family of 2 99 VR-4's----------
#185 of 287 R71
#189 of 287 W75 n-->
Agent|99VR4 is offline   Reply With Quote
Old 07-07-2008, 02:46 PM   #329 (permalink)
Ray
Ray
Ray's Avatar
Trader Rating: (19)
EvoScan StandAlone LCD DataScan Display v1.0 for 1994-2007 Mitsubishis
Now you can display your live vehicle parameters on your dashboard without a laptop, via the 16pin diagnostic connector and MUTII protocol. You can get the same display items as EvoScan. The dimensions of the display unit is 13cm by 5cm, and has a cable to plug into your diagnostic port. Default Parameters available are, RPM, Speed, Knock Sum, Coolant Temp, Battery, Air Flow Freq, Injector Pulse Width, Injector Duty Cycle, Ignition Timing, Throttle, O2 Sensors, Intake Temperature, ISC Step, Atmospheric Press, other parameters for your vehicle available on request. You will still want a Laptop for hardcore tuning, reflashing and datalogging, but this is great being able to monitor temperatures, o2 sensors, and knock data right on your dashboard. $279.00
Just making sure this is it for a 1996 built date 1995 3000GT VR-4. Does the cable it comes with replace the need for the 1.3U cable or do we have to buy that cable also and of course the software? Thanks in advance.
Old 07-07-2008, 02:50 PM   #330 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (21)
tfw a-ok Level 5tfw a-ok Level 5tfw a-ok Level 5tfw a-ok Level 5tfw a-ok Level 5tfw a-ok Level 5
Just a display - The software is what matters. If you get the latest version then yes, you will display knock sum etc. Use the hybrid option for 94-96.
tfw a-ok is offline   Reply With Quote
« E85 Powered VR4? | - »
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f42/mitsubishi-mut-ii-mut-iii-datalogger-395561/
Posted By For Type Date
Norcal3s.com :: View topic - Updated (((Mitsubishi MUT-II/MUT-III Datalogger))) This thread Refback 04-09-2008 11:24 PM
