Old 03-07-2008, 02:24 PM   #221 (permalink)
Hardline3G is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
The flash cable has two plugs, one the 16 pin OBD-II plug, and the other is the 12 pin MUT plug. They both have to be plugged in. The single wire remaining when activated, instructs the computer to listen for commands on the data bus, and the data bus is accessible by the OBD-II port.
Hardline3G is offline   Reply With Quote
Old 03-07-2008, 07:08 PM   #222 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
got it fixed he gave me tools to reprogam the cable and that worked.
but i still cant reset my cel light. and im a 1gen
markoverclock is offline   Reply With Quote
Old 03-08-2008, 11:24 AM   #223 (permalink)
ceki's Avatar
ceki is an unknown quantity at this point
Thanks 3G.
I'll leave the concept to modify/adapt R-VIT iColor so I can get data (up to 29 values) from ECU. It is quite clear that Mitsu has/had different concept.
I have decided that will take 3 signals through Blitz SBC i Color + A/F signal over special port of BC.
Please confirm importance or give your opinion:
1. A/F 2nd signal
2. Knock sensor signal
3. IPW signal
Remains additional port for fuel pressure or temperature.
Regards,
Ceki
Winter GT
ceki is offline   Reply With Quote
Old 03-17-2008, 07:52 PM   #224 (permalink)
Drives: 93 VR4
mike88 is an unknown quantity at this point
This is gonna sound really dumb but I have a 93 VR4 and I'm getting a time put error so just to make sure I'm supposed to plug the cable into the diagnostic port on the drivers side left kick panel or do I need to get 2.0v instead of 2.1v which I'm running right now?
mike88 is offline   Reply With Quote
Old 03-17-2008, 10:56 PM   #225 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
2.1 works fine for me i just cant reset the cel light for some reason, i also had to reflash my cable ( didnt work when i got it just got a error) he gave me the software to do it and instructions.
Old 03-26-2008, 04:25 PM   #226 (permalink)
i is back!!!!
97redvr4's Avatar
Drives: 40 mph upside down
97redvr4 is an unknown quantity at this point
so i got evoscam vs2.1 and it didnt work, then i sent him a email and he sent me vs2.2.the same thing happend.
so, if any of you have vs2.0.can you sent it to me at
supraguy_20@yahoo.com
thanks
97 base:sold, i miss her.
97 vr4:R.I.P
97redvr4 is offline   Reply With Quote
Old 03-26-2008, 06:49 PM   #227 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
thanks
did you try to reflash your cable that worked for me he sent me the software.
Old 03-28-2008, 09:47 AM   #228 (permalink)
SeekNStrike's Avatar
Drives: 96 3000Gt SL TT
Trader Rating: (20)
SeekNStrike is an unknown quantity at this point
Bump having the same thing, I have ver 2.2 Anyone found a fix?
Originally Posted by Schank View Post
Just got my cable in the mail and I'm having trouble connecting to both of my cars! =/ It keeps timing out and asking me to turn off/on the car. Is there something I'm forgetting that's causing this? It seems as though people have had success on both '94's and '97's so I'm thinking it's something I'm doing wrong and not the program.
Also, don't know if it matters but both cars, annoyingly, are Cali-spec. Didn't see anything about cali and fed spec in the thread so im just throwing it out there.
ATX to MTX cov, TT cov. TT longblock,forged 3sx rods,wiseco pistons,oem crank,supra pump,ground wire kit,blitz sbc,aem wideband,
fuel rail loop,spec stage 3, lsd s-afcII,turbo timer, autometer gauges.
SeekNStrike is offline   Reply With Quote
Old 03-28-2008, 05:49 PM   #229 (permalink)
Trader Rating: (20)
can someone send me ver 2.0 ?
Old 03-28-2008, 06:03 PM   #230 (permalink)
oohnoo's Avatar
Trader Rating: (137)
oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7oohnoo Level 7
Damn impatient aren't we. I sent it, I sent it
oohnoo is offline   Reply With Quote
