LinkBack (1) Thread Tools
Old 03-05-2008, 07:36 PM   #211 (permalink)
Hardline3G is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
Sorry to hijack this thread, but would anyone be willing to share their rom files? I am working on trying to "hack" the vr4 rom to be applied to a 3rd Generation Eclipse. I am aware that the code is different due to different processors, but the data is still transposable. Thank you for helping.
Hardline3G is offline   Reply With Quote
Old 03-05-2008, 09:11 PM   #212 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
markoverclock is an unknown quantity at this point
tried to unistall the framework 2.0 and reinstall it. but it still doesnt logg anything get the ftdi timeout error. someone please help with the horrible/no tech support or even email support datalogger. this is really irretable.
markoverclock is offline   Reply With Quote
Old 03-05-2008, 09:36 PM   #213 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
[quote=tfw a-ok;4672632]You can always send Hamish an email [evoscan@limitless.co.nz] and he can respond directly to your queries.
hopefully the email i sent him will help me get connected. we will see
Old 03-06-2008, 12:40 AM   #214 (permalink)
Meet the twins
maddux317's Avatar
Drives: 98 VR4 and 92 FWD TT
Trader Rating: (23)
maddux317 is an unknown quantity at this point
Did you ever find version 2.0 of EVOScan? Version 2.1 is pretty much garbage and doesn't work at all...... if you need version 2.0 just hit me up with your email and I'll send it to you
If you're looking for modded rom files there aren't any for the VR-4. Only 98/99 models can be written, but noone has done anything with them. As soon as I get some kinks worked out of my 98 I'm going to try and mess around with the factory ROM. I can provide you with the factory flash once I start messing with it if you'd like that........
1998 VR4 - Red - 1 of 231
15g's | PTE 550's | Walbro 255 | Apexi SAFC w/ Boomslang Harness | Maximal Performance Solid F/R Mounts | Stillen Downpipe | MSD Superconductor 8.5s | JIC Y-Pipe | Old school ProBoost MBC | EVOScan Logger (logging knock on OBDII baby!) | Kazera KZ-A 18x8.5's | Yokahoma AVS ES100 Tires
1/8: 8.1 @ 89 MPH, 1.9 60' (soft launch on stock clutch) - 16 PSI/rich tune & leaking stock y-pipe
coming soon: more runs with MORE BOOST!
1990 Mustang GT - not stock - Gone but never forgotten.....
1992 Mitsubishi 3000GT SLTT - Formerly the SLSC - My first love (15g 10:1 TT Conversion) - Parting Out
Old setup (worn 9b's, broken motor mounts, M&S tires, 6 psi) 1/8: 9.3 @ 85 MPH
maddux317 is online now   Reply With Quote
Old 03-06-2008, 01:27 AM   #215 (permalink)
ideffect is an unknown quantity at this point
So, will this product work properly for a 95 Hybrid ECU (specifically my 95 Stealth TT)? It seems like it will and is the correct cable the "16pin SSMII/MUTII/OBDII+12pin Evo Reflash Connector"? It looks like a very impressive tool!
Thanks you.
ideffect is offline   Reply With Quote
Old 03-06-2008, 03:30 AM   #216 (permalink)
ceki's Avatar
ceki is an unknown quantity at this point
Have '98-VR European version. Produced in 11/12 month in 1997. Is it OBDII compatible?
What is encircled in the picture?
Winter GT
ceki is offline   Reply With Quote
Old 03-06-2008, 05:35 PM   #217 (permalink)
Drives: 92 RT-TT
Trader Rating: (43)
[quote=maddux317;4755580]Did you ever find version 2.0 of EVOScan? Version 2.1 is pretty much garbage and doesn't work at all...... if you need version 2.0 just hit me up with your email and I'll send it to you
waiting on the 2.0 version
Old 03-06-2008, 08:53 PM   #218 (permalink)
That would be perfect. What I am interested in is just the stock tune. Thank you!
Old 03-06-2008, 09:04 PM   #219 (permalink)
The single terminal is the connection that is to be connected to the flash cable to allow firmware to be downloaded from or uploaded to the ecu. My Eclipse has the exact same connector.
Old 03-07-2008, 01:40 AM   #220 (permalink)
ceki's Avatar
Thanks 3G.
Does it mean that that flash cable has to connected to 7th pin of (OBD2) connector?
« E85 Powered VR4? | - »
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f42/mitsubishi-mut-ii-mut-iii-datalogger-395561/
Posted By For Type Date
Norcal3s.com :: View topic - Updated (((Mitsubishi MUT-II/MUT-III Datalogger))) This thread Refback 04-09-2008 11:24 PM
