Old 01-29-2008, 05:04 PM   #161 (permalink)
Trader Rating: (26)
Agent|99VR4 is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
From my understanding. The 3\S ECU's are not reprogrammable or flashable. So either cable will work, but the open port cable would be useless to us, Unless you have a buddy with an EVO :P
Still doing the poly type mounts!
99 VR-4 Back to Life: Here
------------Family of 2 99 VR-4's----------
#184 of 287 R71
#188 of 287 W75 n-->
Agent|99VR4 is offline   Reply With Quote
Old 01-29-2008, 10:49 PM   #162 (permalink)
Meet the twins
maddux317's Avatar
Drives: 98 VR4 and 92 FWD TT
Trader Rating: (22)
maddux317 is an unknown quantity at this point
Pretty sure the 98/99 ECU's are writeable, just nobody has attempted to do anything with them.
1998 VR4 - Red - 1 of 231
15g's | PTE 550's | Walbro 255 | Apexi SAFC w/ Boomslang Harness | Maximal Performance Solid F/R Mounts | Stillen Downpipe | MSD Superconductor 8.5s | JIC Y-Pipe | Old school ProBoost MBC | EVOScan Logger (logging knock on OBDII baby!) | Kazera KZ-A 18x8.5's | Yokahoma AVS ES100 Tires
1/8: 8.1 @ 89 MPH, 1.9 60' (soft launch on stock clutch) - 16 PSI/rich tune & leaking stock y-pipe
coming soon: more runs with MORE BOOST!
1990 Mustang GT - not stock - Gone but never forgotten.....
1992 Mitsubishi 3000GT SLTT - Formerly the SLSC - My first love (15g 10:1 TT Conversion) - Parting Out
Old setup (worn 9b's, broken motor mounts, M&S tires, 6 psi) 1/8: 9.3 @ 85 MPH
maddux317 is offline   Reply With Quote
Old 01-29-2008, 10:58 PM   #163 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
Trader Rating: (16)
linchpinjoe Level 4linchpinjoe Level 4linchpinjoe Level 4linchpinjoe Level 4linchpinjoe Level 4
orly
linchpinjoe is offline   Reply With Quote
Old 01-30-2008, 03:48 AM   #164 (permalink)
Meet the twins
maddux317's Avatar
Trader Rating: (22)
I did some research on the forums, but all I can find is people saying that it *should* be possible to reflash the 97-99 ECU. I found an old thread where shiver said he had looked into the subject of writing a program for flashing our ECU's ( Has anyone installed an S-AFCII in a 98/99 VR-4? ), so I sent him a PM about it. Hopefully he may chime in on the subject........ This would be a great option for us 3g people now that this cable is available.
Old 01-30-2008, 06:14 AM   #165 (permalink)
Trader Rating: (26)
Agreed. It would be nice to know.
And im sure its common knowledge by now that my understandings aren't always the truth :P
Also, would there be a way to back up the ECU default data incase you get too far into unchartered waters?
I'm trying to get this in by V-day. Hopefully my GF will come through, I will order the open port cable as well.
Old 01-30-2008, 11:52 AM   #166 (permalink)
The New Super Pimp
maddog's Avatar
Drives: FASTER THAN VIPERS
Trader Rating: (7)
maddog Level 1maddog Level 1
from what i remember you could only change code to adjust things like how long your lights stay on after you close the door, lights blinking when you use the security system, and some other small things. Supposedly dealerships could do this with their system. But if it turns out we can than theres more of a reason for me to buy that 98 vr-4
93 Sandstone VR4
11.66 @ 117.48mph with Maddog Performance Engineering 13T's
This weeks specials:
CUSTOM RUBBER INTERCOOLER PIPING AT 50% OFF!!!
28 HOUR ENGINE REBUILD ONLY $700
maddog is offline   Reply With Quote
Old 01-30-2008, 01:15 PM   #167 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7Dj4play Level 7
98/99 ECUS ARE writable. There is just not enough of them for me to deal with the software to do something for them.
AEM EMS INVENTOR TRAINED JEDI MASTER CERTIFIED TUNER
www.gtpro.com
Dj4play is offline   Reply With Quote
Old 01-30-2008, 01:47 PM   #168 (permalink)
Drives: 99VR4
Trader Rating: (16)
Will my sad face convince you of doing something for them?
Old 01-30-2008, 02:07 PM   #169 (permalink)
Supporting Vendor
Dj4play's Avatar
Drives: 3000gt x3
Trader Rating: (25)
sad face or not, if you look at the production numbers and the amount of money i have to spend to do it, i would lose money.
Old 01-30-2008, 02:46 PM   #170 (permalink)
Meet the twins
maddux317's Avatar
Trader Rating: (22)
I see where you are coming from on this. With just over 1,000 97-99 VR-4's that were produced, there can't be all that many of them still running the roads today and even less that are being modded. Still though, there are those of us that would like to be able to reprogram our 97-99 ECU's. This is more than likely going to have to be an open source kind of thing if it is pursued. I know I am definitely going to delve deeper into this subject....... Maybe the EVO guys can provide us with a little help.
