#131 (permalink) |
No, it is inaccurate. It is used to see if the pressure in the plenum changes when the EGR system is recirculating. If it dosent see a change then the system isnt workin or has been blocked and throws a code.
ANDREW
AIM: Imanandydick Black '99 Mitsubishi 3000GT VR-4 First one off the assembly line Mods Performance: RPS Stage II Street Clutch, K&N FIPK, HKS SSBOV,Turbo XS DSMBC @ 15 psi, Gutted Precats, 3SX Downpipe, 3SX Test Pipe, 3SX Light Weight Crank Pulley, 3SX Adjustable Control Arms, Shorter Throw Shifter, Custom Dimple/Slotted Rotors, SS Brake Lines, Hawk HPS Pads. ICE: Alpine head, MB Quart 5.25 and tweeter 2 way in back replacing the 6X9s, Eclipse Co-Axils in the doors, no tweeters in the dash right now, Eclipse amp for components Show: Itallian Leather Shift and E-Brake Boots, Chrome Mitsubishi Emblems, Momo Sphere Shift Knob |
#132 (permalink) |
Hmm never seen that. What is the MDP used for? Can anyone post a picture?
I've got a spare intake manifold of unknown origins that sports a quite large cast for a not bored port right behind the "ECI". I always wanted to know what thats for. Might just be the MDP... |
#133 (permalink) | |
Sleeper VR-4
Here's a not so clear picture of where it's mounted and what the sensor looks like. The plenum has a groove cut in with two mounting holes and in the bottom of the groove is a very small pin hole. I've heard that this sensor can also be rigged to work off of a vacuum connection. If you look carfully at my sig you can see that I also have this sensor. ![]()
#134 (permalink) |
thanks mate that helped. My plenum has the casting but neither the pinhole nor the threads are there. I guess they kept 96+ produced parts compatable for all 3s versions and as far as I know there were no ODBII ones outside the US.
So I assume my plenum came from a 96+ german version without MDP. Now the question is can you use the MDP sensor channel on non-ODBII cars for a boost sensor? |
#135 (permalink) | |
Sleeper VR-4
Not sure if you can add it or not if it's not wired into your ECU already. ![]() |
#136 (permalink) |
The stock one is inaccurate and just for emissions, I guess you could get a nice map sensor and mount it there, then yes you could. If you could put that plenum on a odbI
I just ordered my cable and software tonight. When it gets here ill see if it will log and find how off it is. |
#137 (permalink) |
shemale vids
just hooked mine up today. didnt have time to do any runs or anything as I'm supposed to be going to an xmas party, lol... but the data rate is 135+ per second. What's with my ANTI-LOCK light flashing now though?
![]() ![]() Who cares? He's obviously an idiot, there's no reason to get on the internet and talk about it [YellowES] Maddog Performance Engineering | We P in the B | Call for Rates |
#138 (permalink) |
Weird, have they fixed the bug that didnt let you clear SES lights yet?
Poly Motor Mounts for sale!! Low Price!
99 VR-4 Back to Life: Here ![]() ------------Family of 2 99 VR-4's---------- #184 of 287 R71 #188 of 287 W75 n--> |
#140 (permalink) |
Does anyone know if there will be support for UK and JDM cars?
There could be a lot of interest especially if it can support all MUT functions. Being able to do an AFR map trace would be very useful. Russ |
