Old 12-11-2007, 10:13 AM   #121 (permalink)
oohnoo's Avatar
Trader Rating: (128)
oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5oohnoo Level 5
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
I should have my zeitronix's hooked up real soon and then I'll be able to log wideband/boost/egt.
oohnoo is offline   Reply With Quote
Old 12-11-2007, 10:40 AM   #122 (permalink)
linchpinjoe's Avatar
Drives: 99VR4
Trader Rating: (16)
linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5linchpinjoe Level 5
Originally Posted by oohnoo View Post
At this moment the EVOscan doesn't clear DTC's, got some error when i tried this. Not worried as I'm sure he's working on it.
Funny but while sitting at a traffic light waiting to turn so I can get my car inspected my check engine light comes on damn P505 code) So I quickly connect my other logger and clear the code and then pull into the inspection station and get the car emission inspected. PASSED........lol
Um, where do I get what you have, I need to take my car in for emmissions and would like to clear my CEL from running no cats.
Project: Conqueror
Commence countdown
linchpinjoe is offline   Reply With Quote
Old 12-11-2007, 10:48 AM   #123 (permalink)
oohnoo's Avatar
Today's your lucky day.
http://www.pocketlogger.com/?pid=plobdii
I could use the palm if you don't need it as mine's on it's last leg
http://www.3si.org/forum/showthread.php?t=401153
Old 12-11-2007, 10:54 AM   #124 (permalink)
Drives: 1992 eurospec 3000GT
TiberiusTribun is an unknown quantity at this point
Originally Posted by Prime12 View Post
Considering the car isn't actually measuring boost correctly in the first place... I really doubt it.
The Evoscan screenshot says MDP after boost, I believe 4G63 engines have a Manifold Differential Pressure sensor.
I guess our ECU uses the same channel to show some different value since our engine doesn't have that sensor. Engine load maybe?
TiberiusTribun is offline   Reply With Quote
Old 12-11-2007, 11:07 AM   #125 (permalink)
Let-luse's Avatar
Drives: 99VR4-93NA-CLS-H2
Trader Rating: (19)
Let-luse Level 3Let-luse Level 3Let-luse Level 3Let-luse Level 3
You should really get an O2 sim and get rid of that CEL. I have one on my and I have installed a couple of resistors to get rid of the secondary O2 sensors altogether. So I have no cats and no secondary O2 sensors and NO CEL .
Reda/
Cuz 99s are cooler than 98s... :P Im not going to add fuel to this fire, so im just gunna go outside and hump my combat wing.
93 NA - 99 VR-4
Let-luse is offline   Reply With Quote
Old 12-11-2007, 12:23 PM   #126 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (16)
tfw a-ok Level 1tfw a-ok Level 1
1996 and above have Manifold differential Pressure sensors that sit on the back of the plenum at the top right near the throttle cable.
Originally Posted by DomGT View Post
For some reason I idolize Tommy Williams. Maybe it's his perfect example of a 3000GT. I haven't been on the board in about a month, can somebody fill me in?
I have a new cellphone number, had to change it. 516-491-9004, call anytime for random 3/S funfacts.
tfw a-ok is offline   Reply With Quote
Old 12-11-2007, 01:53 PM   #127 (permalink)
oohnoo's Avatar
I can check that easy enough if it works for '96+
Old 12-13-2007, 08:05 AM   #128 (permalink)
Super Asurada SA-01
Prime12's Avatar
Drives: 97 VR-4
Prime12 Level 1Prime12 Level 1
Wait, excuse my ignorance, but does this mean that it MAY be possible to measure boost?
Prime12 is offline   Reply With Quote
Old 12-13-2007, 08:31 AM   #129 (permalink)
Drives: 99VR4
Trader Rating: (16)
Reda/
Resistors eh? I have the O2 sims and it didnt do anything, can you pm me and let me know what you did to get no CEL? I would <3 you forever.
Old 12-13-2007, 01:35 PM   #130 (permalink)
Let-luse's Avatar
Trader Rating: (19)
Yeah the O2 sims only simulate the signal to the ECU. For some reason you still get a CEL for the heater circuit.
What you need to do is get two 82ohm 5watt resistors and simulate heater for each sensor with them. You cut out the sensors and use the connectors and wiring.
There are four wires on the connector. Heater +12V, Heater ground, Signal and Signal ground.
The resistor is wired between heater +12V and heater ground on each O2 sensor connector. For the O2 sim, I followed the instructions but I remember one of the +12 V heater wires was shared by one resistor and the power wire of the O2 sim.
Here are two links that I found very useful when I did this:
o2 simulator question
http://spdweb.net/index.php?option=c...d=13&Itemid=41
I have done this more than a year and a half ago and haven't gotten a CEL since then. If you are having any trouble I can check how I exactly wired everything next time I put my car on the lift (It's allright, I figure that the electrical tape that wraps everything would need to be changed anyways after all this time).
Reda/
