LinkBack (1) Thread Tools
Old 12-01-2007, 10:59 AM   #101 (permalink)
3000GT_Rider is an unknown quantity at this point
Default Re: (((Mitsubishi MUT-II/MUT-III Datalogger)))
I have an ELM cable already made by ELMSCAN. Do I need the special cable that I must order, or will my ELMSCAN cable work fine?
3000GT_Rider is offline   Reply With Quote
Old 12-01-2007, 11:18 PM   #102 (permalink)
Cool Name Here's Avatar
Cool Name Here Level 2Cool Name Here Level 2Cool Name Here Level 2
Question!
Why is so important to clear the SRS?
Now please be kind here, because data logging is new to me, but what makes this better than the HHH unit and will this only would on a lap top or will it indeed work on a hand held device?
Cool Name Here is offline   Reply With Quote
Old 12-02-2007, 05:54 AM   #103 (permalink)
Wrenchmonkey #839
John Monnin's Avatar
Drives: crappy SHO
Trader Rating: (27)
John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7John Monnin Level 7
Originally Posted by Cool Name Here View Post
Question!
It takes a $3000+ dealer tool to reset the SRS light.
The SRS light means there is a airbag system error.
The most common error is that the air bag system saw a very low power voltage. This is usually caused by battery going dead with ignition key on, like playing your radio unhtil battery dies. This is no big deal your airbag will work fine. But if anything else is wrong your airbag might not work when it could be needed to save your life. The only way to know for sure is spend $3000 on a MUT II or pay the dealer $100 just to hook one up to your car for 2 minutes.
See this thread to buy remote IAC mounting block:
http://www.3si.org/forum/f4/f-s-remo...bodies-416611/
For sale 3.5L 6g74 Swap modified oil pans and thermostat hosuings
http://www.3si.org/forum/f4/fs-6g74-...ied-3s-420690/
John Monnin is offline   Reply With Quote
Old 12-02-2007, 10:20 AM   #104 (permalink)
Sleeper VR-4
tfw a-ok's Avatar
Drives: Benz, 1996 VR4
Trader Rating: (21)
tfw a-ok Level 4tfw a-ok Level 4tfw a-ok Level 4tfw a-ok Level 4tfw a-ok Level 4
John - I had a local service station clear my SRS light a couple of years back. I'm sure they used some generic odbII scanner. They didn't charge me anything and it was done in seconds.
tfw a-ok is offline   Reply With Quote
Old 12-02-2007, 12:26 PM   #105 (permalink)
Volunteer FireFighter
jpyounis1's Avatar
Drives: 95' 3000GT/86' IrocZ
Trader Rating: (7)
jpyounis1 is an unknown quantity at this point
or besdies the free obd tool test.
u can do this: takes 5 min a phillips head screw driver and a hand.
remove cluster. take out srs bulb. smash it on the ground.
no more light
Mods- 4" Intake, Modded Throttle Body, Re-Grind Cam Shafts, Big Tyla's Ground Wire Kit,
Eibach Pro Kit Lowering Springs, NGK Copper Plugs, Accel Thundersport 300+ Red Spark Plug Wires,
6000k HID Kit, 99 Garnish, Prosport Gauges, Evolke 17" Wheels, Hella Optilux Fog's,
Custom Exhaust, Clear Corners
jpyounis1 is offline   Reply With Quote
Old 12-02-2007, 12:51 PM   #106 (permalink)
Stealth Aficionado
Drives: 1995 Stealth TT
Trader Rating: (34)
OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7OwnGTP/WantRTTT Level 7
no more light
THAT doesn't defeat the point of on-board diagnostics or anything . . .
Tony M.
1995 Dodge Stealth R/T Turbo - 12.46@115.77
2007 Dodge Ram 1500 4x4 - 15.2 mpg
OwnGTP/WantRTTT is offline   Reply With Quote
Old 12-02-2007, 01:26 PM   #107 (permalink)
Wrenchmonkey #839
Drives: crappy SHO
Trader Rating: (27)
But it does prove that Darwin was on to something....
Old 12-02-2007, 02:53 PM   #108 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7wraith Level 7
Does this tool let you cycle the ABS motor when you want to bleed the system and clean out all the old brake fluid?
Sam
wraith is offline   Reply With Quote
Old 12-02-2007, 04:39 PM   #109 (permalink)
jpyounis1's Avatar
Trader Rating: (7)
yea but i meant to add. if you know what its on for...then do it..haha
Sam, ill be buying this in a week or 2. when i get it, if u want i could come by we could test it.
JP
Old 12-02-2007, 05:38 PM   #110 (permalink)
resident evil
wraith's Avatar
Trader Rating: (15)
JP
thanks...but I was asking out of curiosity more then anything else since I run an AEM EMS right now. I have been thinking on/off about putting mine back to original condition which is why I asked.
LinkBacks (?)
LinkBack to this Thread: http://www.3si.org/forum/f42/mitsubishi-mut-ii-mut-iii-datalogger-395561/
Posted By For Type Date
Norcal3s.com :: View topic - Updated (((Mitsubishi MUT-II/MUT-III Datalogger))) This thread Refback 04-09-2008 11:24 PM
