#262 (permalink) |
ok i gave in and purchased the cable and software.
Installed it just for kicks and now im getting a "EvoScan has encountered a problem and needs to close. We are sorry for the inconvenience." Its V2.2. Or does it just not run without the cable, and being plugged into the car? EDIT: FIXED I had .net framework 2.0 but when I tried to install a service pack, it says my install had missing files. W\e, so I installed .net 3.5 and all is good to go incase anyone else has this problem.
99 VR-4 Back to Life: Here
![]() ------------Family of 2 99 VR-4's---------- #184 of 287 R71 #188 of 287 W75 n--> Last edited by Agent|99VR4 : 05-05-2008 at 01:10 PM. |
#265 (permalink) |
Senior Member
Has anyone with an overclocked ECU tried this? I would be interested to see if it would work as it is definitely different with Mirage Corps (Shivers).
Thanks, Dean
1994 Black 3000GT VR4 w/only 38,500 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
#267 (permalink) |
Sleeper VR-4
Hamish tells me an updated version in near completion. It will even have support for my 96 OBDII car which is different from all other OBDII years since it was the first version. I hope to get a pre release real soon after he stabilizes it. It will also have a number of bug fixes resolved since the last release which incorporated multiple developer updates that didn't coexist very well.
Cheers, Tommy
#268 (permalink) |
sweet deal
![]() ATX to MTX cov, TT cov,MSD coils, MSD wire's, MP soild motor mounts, spec stage 3 clutch, S-afcII ,aem wideband auto meter boost, egt,water,oil temp,oil pressure,Greddy turbo timer,96 tt ecu,egr block off plates, front + rear pre-cat eliminators, single shot exhaust |
#269 (permalink) |
Awesome.
What was the average delivery time of this thing? Its been about 12 days, I understand its coming from overseas, but where from so I have a better idea? Also did it come to your doorstep or mailbox? THX |
