#11 (permalink) | |
I was wonder if it had a effect if any, if it did maybe some numbers across the board would shed some light as to just how much of a effect there is. Either way your numbers would be nice with and without meth at the TB.
His - Red 93 RT/tt
Mods: Hallman's MBC @ 16 psi psi, turbo XS type H BOV, stillen dp, custom exhaust, Spec stage 2 clutch, RPS FW, 3sx lightweight crank pulley, BCP7RES-11 @ .030 gap, autometer gauges, slightly gutted mas, dsm SMIC's, ACPT 1 piece CFDS, Tein S springs, pte 580 inj's, safc neo/SITC, 13t's, hotwired walbro, maximal performance solid motor mounts, DR plenum spacer. Hers - BPU Green 94 vr4 |
#12 (permalink) | |
Racing
92 Dodge Stealth R/T AWD/TT (TD05) converted ( 11.894 @ 120.56 - 18 psi -> Video )
![]() Twin TD05H EvoIII 16G's - Garrett FMIC - PTE 680cc - IPO Propane Injection - Maftpro - SouthBend DXD-F - PST CFDS - Northbend OS - Kaaz LSD - Cianci Victory Hood - Cianci Novara Bumper - Forged Internals 1mm over - and MUCH more.. |
#13 (permalink) | |
Driving While Ukrainian
so, that temp number that datalogger gives you is temp at the MAS?
I noticed it hotter at idle and colder when engine under some load. and I'd say its about 10-20 deg diff between outside temp and cruising.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff:Free_boost, cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, 0.025'' gaped spark plugs, Datalogger, S-AFC. Working on: Driver mod, Clutch, 560cc, AEM TruBoost. E85 powered VR4 coming soon... Wanted: Wideband A/F, A-Pillar Gauge pod. Dream car: F40 (LM) Quote:
#14 (permalink) |
Here's a log I did back in Oct 2007. Ambient temp was about 65*....
http://mysite.verizon.net/ermora/OBDII_04.xls Hope this is useful...
![]() 1999 VR-4 K&N Intake * Greddy FMIC * 2.5" DP (No PreCats) * 3" Exh * Walbro 255 * AEM TruBoost * AEM EUGO * Prosport FP |
#15 (permalink) |
We can make it better!
Guys, can people please include if they are doing C or F...
This thread will rawk, you see I've been bitterly complaining about all these stupid air filters that sit in the engine pay pulling air from IN the engine bay...(pod filters) with the HHH Logged I've seen from 26 C on cold nights up to 67 C on warm days, at 67 C the car has MUCH less power (Hate to imagine how much the timing is being pulled)... I'd love to see stats on what temperatures you really need to achieve to make what power keep it going guys, I'll dump some spreadsheets here over the next few days.
#16 (permalink) |
rock on, yeah rock on
i've got a bunch of old logs from when i was bpu, and right after putting the phantoms on. can't remember if i have any with the stock airbox on or not. one thing that i always found interesting, the longer you stay on the throttle, the air going into the mas actually rises in temp, even as you increase in speed. graphed with temp as the Y axis, and time as the X axis, it sorta looks like a U, or a check mark. i could post up some of that if it would help at all. it was so long ago that i can't remember any exact temps outside, but could guestimate based on date logged and time of day (night, winter, in ohio, etc).
and i don't have my car here in florida yet, but will soon. and i know i have the stock airbox still. it wouldn't be much to do a couple pulls back to back with the different filters once it's all here. stock hood though (which i know is what you're looking for).
Dyno Collection Thread
1993 Dodge Stealth ES, White, April 2002 - April 2005, SOLD 1 of 53 1993 Dodge Stealth TT, Black, Since April 2004, 1 of 5 ever made more rarity info currently getting rebuilt at IPS Motorsports 2003 Subaru Forester 2.5X, Blue, Sept. 2005, Daily Driver with 165 HP of Fury! At least it's AWD. ![]() ![]() ![]() 13.02@104.67 (9bs, dp, fipk, 15.5 psi, bov, no cats, streetmax clutch, 1.77 60', decent conditions, full weight (even spare tire/jack) 13.09@105.08 (1.80 60', same conditions as above) 305 awhp, 325 awtq(BPU minus full catback exhaust)Mods at that time Beyond BPU: (meaning upgraded turbos/fuel/etc)Mods at that time 12.38@113.00(20 psi, 110 octane, massive knock above 6k rpms) 12.41@115.10(ditto) |
#17 (permalink) |
Super Member
If you are measuring at the mass the thread should probably be called under-hood temps, not intake temps. To me intake temp implies the actual charge temp going into the engine, which most of us measure at some point close to the intake manifold (via ait sensor). Low underhood temps are good if you have an efficient intercooling setup... a crappy intercooling setup will still result in high intake air charge temps regardless of under-hood temp
Quaife Front LSD for AWD
Ksport Suspension Kits Specializing in 3/S Suspension, Billet Transmission Shift Forks, 300M Output Shafts, Front AWD and FWD LSD, Transmission Rebuild Parts, STOPTECH Brake Kits, Big Reds, and Custom Brake Upgrades! More Products to Come. 1993 3000GT-VR4: AEM EMS, etc 663 awhp, 607 tq (retired tdo5-e16g's) 10.835@132.69 -26psi |
#18 (permalink) | |
Just my by MAS its as much as 100 degree difference entering the system. On a cold night I can see 3x degrees at the MAS and on a warm day like today its in the 13x at the MAS. That 100 degree difference has a impact at the TB. If you lower the intake temps at the MAS you are lowering the intake temps down the line too because the IC's don't have to work as hard. I mean they are air to air aside from Xwire, there is only so much they can do in the microseconds that the air spends traveling through the intake. I wish someone with a cold air wall, or one of those ram air hoods (victory,575), and even purely vented hoods like the evo could give numbers. You always hear of but dynos and even some comment of their times and top end improvement. Now lets get some numbers as to why. |
#19 (permalink) | |
Racing
Like I mentioned before though, when I initially put the Victory hood on my car, it lowered the underhood temps enough to lower my Intake temps at the TB by 10-15* F |
#20 (permalink) |
Warning: I'm an asshole
Awesome, it's about time we have a serious discussion on this.
I have one question, has anyone ever driven their VR4 with the hood off? It's like a shot of adrenaline. Cooler temps entering through the intake/MAS = more power. I really wish there were more hood options that place emphasis on this. Maybe an Evo style hood, but for a 3/S, with a vent and an induction right over the filter area in addition to the screening holes in the center. I know GTPRO made an Evo style hood for the 2nd gen guys a while back, but never heard anything about 1st gen hoods.
1992 3000GT VR4
![]() ![]() --Completely rebuilt 5/06-4/07. Everything new. For a list see: http://www.3si.org/forum/showthread.php?t=372579 --First time on dyno: 364AWHP@16psi with a 10.3AFR (now tuned at 11.4-11.6 with timing control, time for another dyno run soon) --Mods: DR Stage I heads, 3rd gen lifters, TD04L 13Gs, DSM SMICs, PTE 550s, Apexi SAFC, Apexi SITC, Walbro FP, IPO hotwire, Robbeck adapter & AEM FPR, 3SX underhood fuel gauge, 3SX fuel rail loop, DN Y-pipe, HKS SSQ BOV, K&N FIPK, Greddy Profec Spec S, AEM WB02, Autometer C2 boost, egt, oil press & water temp gauges, MSD wires, NGK BCP7ES's, TEIN FLEX coilovers, Maximal performance control arms, solid engine mounts & powdercoating, RPS Streetmax Clutch, RPS Flywheel, NBT Tranny (cryotreated OS, shift forks & rails), updated speedo gear, solid shifter bushings, full 2nd gen brake conversion, 3SX SS brake & clutch lines, Carbotech Panther+ pads in the front & Bob Cats in the rear, 3SX clutch vac delete, EGR delete, vac reduction, Ebay DP, gutted pre cats, Bronze FN01RCs 5Zigen 18x8.5 + 30 offset, Pirelli P-Zeros, engine dress up kit, Bigtyla ground wire kit. --Daily Driver: 98 Malibu, 4cyl, auto |
| Thread Tools | |
