#21 (permalink) | |
Corn Its whats for boost
Crank Case-----> Vac Pump (pulling from Crank Case and pushing into Catch Can -----> Catch Can (has filter for release to atmosphere)----> Atmosphere
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#22 (permalink) |
*Insert Evil Laughter*
I think the catch can should go in front of the pump.. since it wasn't designed for oil vapor we might want to keep as much of it out of there... but either way would work.. slightly better vacuum your way IPO it would seem
#23 (permalink) |
actually it does still act like a spring. I have read so much on this lately
![]() Excessive Crank pressure impedes the movement of the piston. Relieving it frees up power. Plus helps with blow by, oil in combustion chamber. Too much vacuum, you are correct, it can and will pull too much oil out of where it belongs. A simple Needle valve placed in line fixes that. |
#27 (permalink) | |
Banned from Classifieds
I am really liking the idea of this pump, and don't get me worng, I won't complain if I pick up 40AWHP, but I'm not holding my breath ![]() |
#28 (permalink) | |
I have no idea if 10PSIg is realistic or not, just an example ![]() |
#29 (permalink) |
wow.. math is kewl
![]() I'm definitely going to hook up a boost/vacuum meter to the crankcase as well something just occurred to me though. Yes you have this force pushing up on pistons trying to come down.. but it is simultaneously pushing on the ones on their way back up.. so maybe it is merely removing some of the air resistance.. rather than a pressure thing Last edited by Eric_VR-4 : 02-12-2005 at 04:38 PM. |
| Thread Tools | |
