#101 (permalink) | |
Corn Its whats for boost
I am thinking maybe an MBC working in reverse.
AEM Factory Trained Tuner
![]() 91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#102 (permalink) |
That's exactly what I was thinking.
The thing too, would be nice if you could put it where the rear valve cover hose goes to the intake. Therefore, you could still pull in some fresh air to clear out the old air in there while you are using vacuum. But if your vacuum pump cant keep up you will spew oil out of there.
#103 (permalink) | |
#105 (permalink) | |
Not that it couldn't be done, but simple mechanical control in my opinion is easier and less prone to fault. |
#106 (permalink) |
exactly.
The only problem i see with the "fully open" filter on the rear cover is it could possibly cause too much air to be drawn in and if the pump can't handle that extra CFM, then it won't hit 14". So possibly putting a needle valve in the hose there, or restricting the size of the hose to a very small diameter may help. I guess it all depends really on how much this pump can do. |
#107 (permalink) |
I'm also wondering about an electric pump going full bore on a street car. I know in your case it doesn't matter, but I wonder how quick these things will die.
The drag cars use the mechanical pump off the main belt, and it is only good for 300 or so passes before it needs rebuilt. That is a big no-no for a street driven car. So maybe the elec ones are more reliable. A controller might be needed so you can have a lower voltage at idle and peak it up to + 14v at WOT. Hell, you could do this with a simple switch that is boost activated to switch from a voltage divider on the +14v source to the full B+ voltage....exactly like our fuel pump does. This will preserve the motor, because I don't think you need the full 14" at idle. |
#108 (permalink) | |
Ahh, but stock it's the same way. The rear cover is the PCV systems fresh air source, it's nothing more than what I am doing with a small filter on the rear valve cover, except it is using the car's much larger air filter. Same air inlet. I don't think there will be an issue. |
#109 (permalink) | |
Buick 82 Skyhawk-J 82- 85 Skylark-X Pontiac 85-86 6000 82 J2000 82-84 Phoenix-X Chevrolet 84-86 Celebrity-A 82 Caprice-B 82 Cavalier-J 82-85 Citation-X Cadillac 82 Cimmaron Oldsmobile 86 Cierra-A 82 Firenza-J 82-84 Omega-X Others 93-95 Z-28 and some 96 BOP Caddy's in 90-96 Ford Escort & Mercury Lynx diesel cars They all used a vac pump for brake booster since the car's couldn't provide enough vac on thier own. And they last for years. http://www.hardtail.com/techtips/vacuum-pumps.html |
#110 (permalink) | ||
OMGOMGOMGOMG
Jake - 91 VR-4
![]() ![]() Last edited by J-Ville VR-4 : 02-15-2005 at 04:51 PM. |
| Thread Tools | |
