Old 07-29-2004, 09:16 AM   #1 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
Default ECU Fuel trims.
At the local meet last night another owner and I started atlking aobut he ECU's fuel trims and what they mean. I have some basic information that is from the TMO FAQ and is copied to the pocketlogger FAQ(http://www.3si.org/plhelp/data.html) But, their were some details we just had questiosn about.
Given at lease two people here are working on logging software this seems a good place to ask.
The ECU has 3 trims (LO,MID,HI) the its question is lo,mid, hi what? RPM? Throttle? MPH?
Do the trims have any effect on how the engine runs at WOT(closed loop?)?
I may have other question if these get answered.
Thanks.
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 07-29-2004, 02:11 PM   #2 (permalink)
no speed limits here
BLACK94TT's Avatar
Drives: A109E
Trader Rating: (20)
BLACK94TT is an unknown quantity at this point
Default Re: ECU Fuel trims.
Working with the MAFT has made me pretty familiar with this topic. The fuel trims are related to the amount of airflow (in HZ). Low<88hz, mid 88-180hz, high180-~500hz. Above ~500hz the ECU goes open loop. Fuel trims are taken out of the mix in open loop mode.
Steve
BLACK94TT is offline   Reply With Quote
Old 07-29-2004, 06:29 PM   #3 (permalink)
Ready... Steady... GO!!!
Internexus's Avatar
Drives: 92 Stealth RT/TT
Trader Rating: (54)
Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7Internexus Level 7
Precisely stated, all trims come down to HZ ratings, once you reach your specific range you jump into one of the 3 or go into WOT.
-Sean
I'm not A.D.D., I'm just . . . Hey look, a Squirrel!
Internexus is offline   Reply With Quote
Old 07-29-2004, 08:22 PM   #4 (permalink)
Resident mad scientist
TurboBob's Avatar
Drives: 86 GN 91 RT/TT
TurboBob is an unknown quantity at this point
High trim is used at WOT. I have data to support my statement.
Bob
TurboBob is offline   Reply With Quote
Old 07-29-2004, 08:27 PM   #5 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7
yes, it is all based on airflow.
And yes at WOT the car relies on the high trim.
SHiVeR-91VR4 is offline   Reply With Quote
Old 07-29-2004, 08:44 PM   #6 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Not to throw in a wrench, I have always read that the three settings were speed related. Can't remember the numbers but something like 0-45, 45-80, 80+. I will se if I can dig up the websites.
This is from Pocketlogger
1g Tech Article on Fuel Trims:
Fact 1:
Fuel trims are used as a 'modifier' to the fuel map lookups to get the A/F Ratio at part throttle (closed loop) to where the ECU wants it. They are not used in open loop mode.
Fact 2:
The ECU has a 'window' of adjustment. (Range of 60 to 140% for 91+ cars, 80 to 120% on 90's) If your trims are within the window (whether lean or rich, but not maxed), the ECU has corrected for any problems and should have an A/F ratio just as the ECU is expecting it to. Theoretically, as long as the trims are within the window, you really don't need to adjust your fuel delivery because the ECU is compensating.
Fact 3:
If a trim is maxed, the ECU cannot adjust the fuel enough to fix the problem and you are running either leaner (FT maxed high) or richer (FT maxed low) than the ECU wants. This why Todd says he gets better gas mileage when his trims are maxed lean...because he is running leaner than the ECU wants. Leaner is less fuel. Less fuel used = more MPG (to a point...)
Fact 4:
A dead or slow O2 sensor will wreak havoc on your trims. High values for all three trims (indicating a lean condition) are a good indication that your O2 is dead.
During idle and part throttle, low boost cruise, the O2 voltage should cycle up and down in the range of approximately .2v to .8v. If it doesn't, this would again indicate that it's time for a new O2 sensor.
An abnormally high Low Fuel Trim is a good indication that the heater in O2 sensor is dead. Most of the time, during idle, the O2 sensor will stop cycling after sitting for a minute or so. This is a good indication that the heater is indeed dead.
These are guidelines only. An improperly set fuel control, hacked MAF, boost leak, etc. can cause all kinds of results.
Fact 5:
It is ok for the O2 to flatline at close to 0 volts during deceleration, even slight deceleration.
O2 Trim:
The Low/Med/High Trims we see are long term trims i.e. they are 'dampened' quite a bit (move slowly) and maintained between starts. They are derived from the trend observed from the O2 trim which is a short term trim (moves quickly). The O2 trim is derived from comparing the actual O2v to what the ECU thinks the O2 should be (stoichiometric). The idea is to keep the O2 trim right. If there is a trend (lean or rich) in the O2 trim for a period of time, it is corrected via the appropriate (high, med, low) trim. Which trim is adjusted is based on the current airflow. This will allow the O2 trim to go back to its midpoint because one of the other trims is making the fuel delivery correction.
Open Loop:
O2 values and trims are ignored during open loop mode. The ECU uses a preset amount of fuel, ignoring any trim corrections. O2 Volts will not cycle in open loop mode. There are really no 'good' values for O2s at WOT because they differ between cars and sensors. .9 and above is generally considered pretty save. For some unknown reason, '90s seem to read .1v lower. I've run as low as .7x on pump gas on my 90. I would not recommend this without other instrumentation like an EGT.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 07-29-2004, 08:54 PM   #7 (permalink)
0-125 Hz=Lo fuel trim band
126-175 Hz= Mid Fuel trim band
176+ Hz=Hi fuel trim band
Old 07-29-2004, 09:00 PM   #8 (permalink)
Member: Burned valve club
cbatters's Avatar
Drives: 91 Stealth RT/TT
Trader Rating: (12)
cbatters Level 2cbatters Level 2cbatters Level 2
Bob
please elaborate... time for me to get this straight if I have been misinformed about the role of trims at WOT...
Clint
Maint: Castrol 10W40 / Mitsu Filter / Rislone
Replaced: 2X clutch / 3X brakes / 2X front rotors / 2X ABS HU / 1X NGK Plugs / 1X Ball joints / 2X Antenna mast / 1X Active exhaust cable / 1X Windshield / 1X Fuel FIlter / 1X Struts / 1X rear rotors / 1X Front Head / VSS / 1X rear wheel bearings / 1X Transfer case (warranty) / 1x Tie rod end (drivers side)
Overhauled: Starter, IAC, BISS, CV Boots
Upgrade: SilverStar Headlights / ebay "Xenon" Fog Bulbs (no more yellow!)
A/F Gauge / MAP - Electronic Boost Logging / MMCd Data Logger
Pending Projects: Steering Rack
cbatters is offline   Reply With Quote
Old 07-29-2004, 09:29 PM   #9 (permalink)
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Our cars run 81% - 120%(edit: I know you just copied the FAQ. JUst pointing out where it and our cars to not match)
Old 07-29-2004, 09:32 PM   #10 (permalink)
That was Pocketloggers info, more DSM related
