#71 (permalink) | |
the car whisperer
I get the same thing, but 15 mpg
96 RT/TT
It lives again. major performance mods: DR1000's, FMIC, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, billet rails, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things. ................and 18" chromies........ |
#73 (permalink) |
the car whisperer
Well, when else are you supposed save gas? Cruising at 14.7. idleing at 15.0-16.0. And decelerating.
I have a rich idle I can't tune out. I got that 15mpg the same time I got the Maft-pro, big injectors, and an aftermarket FPR. Not to mention that when you step on the throttle, the car adds a 'squirt' of fuel extra to ease the transition from idleing/cruising to accelerating. So it could carry over that way. I'm just throwing a place to start looking out there. I don't know any more than you do. I still get shitty mpg. let's get back to the topic though. |
#74 (permalink) | ||
Driving While Ukrainian
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs. Working on: Driver mod. E85 powered VR4 For Sale: stock injectors and pump. Dream car: F40 (LM) Quote:
#76 (permalink) |
Points to remember when converting to E85.
-You need 30% MORE fuel for the same engine tune on E85. -Converter boxes will increase the injector pulse about 20%. The ECU will add the other 10% compensating for the lean condition. -The stock TT fuel pump can't handle the 30% more fuel demand. Great resource on fuel pumps. http://www.stealth316.com/2-fuelpumpguide.htm |
#78 (permalink) |
The E85 injector boxes will increase the injector pulse time about 20%. This will let about 20% more fuel into the system. When your ECU sees that the A/F ratio is lean, it will add more fuel into the system. When it is rich, it will shorten the pulse with and put less fuel into the system. Most fuel systems can +or - 10% to 15%. from the base line. If you add 20% to the base line you get around +35% to -5% from the old base. This will let you run E85 +30% to unleaded at 0% and still let you have + or -5% for other conditions because of the ECU. This will take about 1/8th a tank to adjust.
Remember you are still increasing the duty cycle of the injector and you can max them out sooner. Notice also that these boxes do no connect to the o2 sensor. The only thing they connect to is the injectors and a ground. Another way you could increase the fuel to the system is to add bigger injectors and tune with a piggy back fuel computer like a SAFC or even a piggy back ECU like a greedy blue or ultimate. To get a better tune, you will want to be able to adjust the timing curve also. 450cc injectors are about 20% over stock, so in theory you could use 450's and a bigger fuel pump and run it that way and be in the ball park or the +30% with the ECU compensation, but I don't think you could win at the track, but it should work around town. I would not attempt without a good data logger or A/F gauge. I notice you have 675's, but this gives you the idea over stock levels. Last edited by eldos1 : 11-16-2007 at 09:42 PM. |
#79 (permalink) | ||
red '91 VR-4
Of course, however, when I boost my AFR drops to ~11.5:1 to be safe.
![]() Quote:
#80 (permalink) | |
the car whisperer
Wow, I didn't know you could do that. Will do. |
