#51 (permalink) |
Yes, on a stock for stock car, e-85 is not worth the $$ unless you want to lessen your usage on fossel fuel.
As for flex-fuel vehicles, they did used to run a fuel sensor, but now mostly use the o2 and knock sensor to tune. The miles per cost was about the same also, but they did make slight power increse with the E-85, like a tenth less in 0-60. Ethanol is not a nearly as bad for the fuel system as methanol. E-85 does make less BTU's then Gas, but since you use more of E-85 it does make more power. Yes E-85 is an awesome 100 pump or ever 110 leaded replacement. I was paying over $5 per gal for 100 pump, but now $2.65 for E-85. If you use a wideband, you tune the engine just as if you were tuning with gas. You use the same numbers. Say 14.7:1 for idle and 11:1 for WOT. It shows those numbers because the wideband display is programmed to show the gas ratio's. I hope that makes sense. If you build a motor for E-85 a gas motor can't touch it, for power and fuel economy. That is why the flex-fuel cars don't really show any difference, not if they took a premium fuel car and made it flex fuel, it would be way better on E-85. E-85 likes timing and compression. I don't has a 3000gt, but my 4 cyl has 10.5:1 comp and will run 20 psi easily. I'll have to find the article where they converted a VW diesel jetta to run E-85 and it got awesome power and mileage. No matter what, street driven or raced, you will need more fuel and have to upgrade the fuel system. But on a stock car, I would say don't do it, it is not available everywhere, and harder to find than diesel at times. Then when you want to put gas back in you'll have to change it back. Also it is Federally illegal to convert a car to run E-85, but so is removing you cat ![]() |
#53 (permalink) | |
the car whisperer
I have one flexfuel car to my name and my family has another one. They both get worse mileage on e85. Lot's of good info. Thanks. I think I'm going to do this seeing as I already have the fuel system for it. --not daily driven though, for others who read this.
96 RT/TT
Currently missing an engine. major performance mods: DR650's, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things. Waiting to get put in---> DR1000s with .48AR and stage 2 blade |
#54 (permalink) |
NG '03 6th Floor Crew
[quote=cerevo;4601721
so to change back to 93 you would just change the tune back right?[/QUOTE] Correct.
Web log: http://apps.blackflagracing.com/Blog/
The Armada '93 Sandstone Gray 3000GT VR-4 2006 3SI Ride of the Year 2007 All Mitsu Cookout, 1st Place 1st Gen 3/S '92 Fiji Blue 3000GT VR-4 2004 All Mitsu Cookout, 1st Place 1st Gen 3/S 2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier. BLACK FLAG RACING '92 Emerald Green Pearl Stealth RT/TT 3.5L, 15Gs, AEM EMS |
#55 (permalink) |
Yeah, what I meant to say was if the motor was built to use E-85 in the correct way, high comp and more timing. Flex-fuel cars are designed to run E-85, but the motors are not built to make it efficient. If they did you could not run 87 octane in them.
#56 (permalink) |
GTOUK Member
I've heard other platforms in Europe just fit an adjustable FPR and then tweak that to compensate for the ratio when running different mixes of bio-ethanol. Typically they seem to raise from 43.5 PSI to 61 PSI when switching from normal gas to E-85. This doesn't cause issues with timing or requiring bigger injectors and controller, but it does need a bigger fuel pump on 3S, such a Denso Supra pump or Walbro 344.
#58 (permalink) | |
Driving While Ukrainian
my gas millage didn't get worst after using 50/50 or 40/60 mixes of 93 and e85. its stayed around 20mpg. no extra lights came on, so everything looks good for now.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff:Free_boost, cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, 0.025'' gaped spark plugs, Datalogger, S-AFC. Working on: Driver mod, Clutch, 560cc, AEM TruBoost. E85 powered VR4 coming soon... Wanted: Wideband A/F, A-Pillar Gauge pod. Dream car: F40 (LM) Quote:
#59 (permalink) | |
#60 (permalink) |
USMC
Hey, I have 560CC Evo Injectors (which really flow a little bit more than 560CC) and a 255Walbro and a PRO-M MAFTUNER (with no timing control).
SHOULD I SWITCH ![]() When you guys say upgrade your fuel system...what do you intend to include? Just pump and injectors? OR lines, too? Also, the people running e85, have you changed your fuel filter yet? If so, how often? What are the maintenance (fuel component related) to run this? I have a station in my town, so if you guys (no noobies) say it's good to go, I am going to try it. T
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//HKS Dual exhaust//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger Turbos: 13T @ 6 PSI Current Problem(s): Cherries in the rear view mirror In the Process: Nothing Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel... |
