Old 10-31-2007, 04:42 PM   #41 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
Default Re: E85 Powered VR4?
right now I'm running 50/50 mix so far so good. on stock fuel system. just normal driving. if something will go wrong I'll let you guys know.
1993 3000GT VR4.
________________________
Was bored, had to do stuff:Free_boost, cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, 0.025'' gaped spark plugs, Datalogger, S-AFC.
Working on: Driver mod, Clutch, 560cc, AEM TruBoost.
E85 powered VR4 coming soon...
Wanted: Wideband A/F, A-Pillar Gauge pod.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
Old 11-03-2007, 05:31 PM   #42 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
Trader Rating: (14)
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
on stock injectors you will be out of fuel at about 8-9 psi with e85.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. stock 14.56best ET 98 mph best trap
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G and everything else.
91vr4n00maxima is offline   Reply With Quote
Old 11-04-2007, 11:54 PM   #43 (permalink)
a2j
a2j's Avatar
Drives: Red Car
well, I never had fuel cut so far. but I'm not flooring it anyway cuz I need a new clutch.
Old 11-05-2007, 12:06 AM   #44 (permalink)
the car whisperer
runner4053's Avatar
Drives: 96 RT/TT
runner4053 is an unknown quantity at this point
Originally Posted by kihtay View Post
Just curious, did you have problems with the evo running/ starting in the winter when it got cold? I've been running my Eclipse on it for the past 4 months, but now it's getting cold and seems to hate life (issues with starting)
But yuh, the dummy answer is larger fuel pump and larger injectors. I went up from 650s to 750s for enough flow (single evo3 16g- dsm). It makes a huge difference with spooltime as well
This spools faster? I was always under the impression that e85 will lessen the power of a vehicle. I guess that only applies to NA cars though.
96 RT/TT
Currently missing an engine.
major performance mods:
DR650's, MAFT-PRO speed density, 720 cc, supra pump with hotwire, Fuellab FPR, ported heads, 1mm over intake and 1 mm over iconel exhaust valves. spec 3+ clutch, fidenza flywheel, 2 piece Al driveshaft, Supercar baffled oil pan, relocated battery, custom exhaust, reinforced bellhousing, 3sx poly motor mounts, intrax with GR-2, lots' of little things.
Waiting to get put in---> DR1000s with .48AR and stage 2 blade
runner4053 is offline   Reply With Quote
Old 11-05-2007, 09:18 AM   #45 (permalink)
Now with more 40D
leet's Avatar
Drives: a 92 in 6th gear
Trader Rating: (24)
leet is an unknown quantity at this point
yeah E85 burns faster then normal petrol, so you gain a little torque too
the local DSM shop that was near me when I lived in oklahoma used E85 in a ton of DSM's, 240's, and a bunch of other cars
on big laggy turbos they said they usually got about 200rpm or more faster spool
E85 will only lessen the power of a vehicle if it isn't tuned properly to run it
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 11-05-2007, 10:18 AM   #46 (permalink)
ver fer's Avatar
ver fer is an unknown quantity at this point
The decrease in spool is likely caused by the increase in fuel consumption.
more fuel = more exhaust
You can get more power if the vehicle is tuned to run on only e-85. Think alky drag cars.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces Falken GR Beta FK-451
ver fer is offline   Reply With Quote
Old 11-05-2007, 10:22 AM   #47 (permalink)
the car whisperer
runner4053's Avatar
Drives: 96 RT/TT
I've also been under the impression that E85 is seldom 85% ethanol. I've heard the mixture varies from pump to pump. Stock flex fuel cars compensate for this with a fast refresh rate on the 02s and I've also "heard" that there's a sensor which detects the ethanol percent before the fuel even reaches the engine. Is any of this correct?
Old 11-05-2007, 11:41 AM   #48 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (56)
lethal_vr4 is an unknown quantity at this point
Yes there are ethonal % sensors... but I imagine it would be hard to integrate with our currently available piggy back fuel controllers.
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
lethal_vr4 is offline   Reply With Quote
Old 11-05-2007, 12:04 PM   #49 (permalink)
the car whisperer
runner4053's Avatar
Drives: 96 RT/TT
So, if you can't guarantee what mixture you have in the gas tank, and we can't use a ethanol percent sensor, how could we ever have a consistent tune?
edit: I'm just trying to see if this is viable on a street driven vehicle. I like to get in my car and go. If I'm low on fuel, I just want to pump and go. Testing for composition would be a huge inconvenience.
Old 11-05-2007, 12:19 PM   #50 (permalink)
Now with more 40D
leet's Avatar
Trader Rating: (24)
85% in the summer and 70% in the winter
that's the only switch there is
