Old 09-10-2008, 05:49 PM   #351 (permalink)
ver fer's Avatar
Drives: a corn fed VR4
ver fer Level 1ver fer Level 1
Default Re: E85 Powered VR4?
It may. Have you hotwired you fuel pump yet?
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
ver fer is offline   Reply With Quote
Old 09-11-2008, 08:38 AM   #352 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j Level 1a2j Level 1
yes, I did. (its all in my sig)
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs.
Working on: Driver mod.
E85 powered VR4
For Sale: stock injectors and pump.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
I gave up...
a2j is offline   Reply With Quote
Old 10-09-2008, 01:05 AM   #353 (permalink)
a2j
a2j's Avatar
Drives: Red Car
what are the chances to over run stock fuel pressure? I mean, my IDC got lower with hotwire. should I worry about it?
Old 10-09-2008, 03:46 PM   #354 (permalink)
Pearl White 92 Stealth TT
mike92stealthtt's Avatar
Drives: 100+ IDC's
Trader Rating: (12)
mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7mike92stealthtt Level 7
I overrun my stock fpr by about 5 psi at idle with my hotwire.
mike92stealthtt is offline   Reply With Quote
Old 10-09-2008, 04:42 PM   #355 (permalink)
keithmac Level 2keithmac Level 2keithmac Level 2
I overrun mine as well causing rich idle, but with the E85 it negates that due to needing 20% more fuel..
JDM GTO TT, Emanage Blue - 450`s
Hotwired Walbro - K&N - Blitz SSBC
Port Methanol Injection - E85 - 12.4@115
keithmac is offline   Reply With Quote
Old 10-09-2008, 05:05 PM   #356 (permalink)
Boosted :D
Gushers248's Avatar
Drives: 4x4 dime + 91 VR-4
Gushers248 Level 1Gushers248 Level 1
I know dumb question, but if you ran e85 on a stock system could you run 10 psi because of 30% of 15 and 30% more fuel? I'm only set at 11 right now anyways.
91 VR-4
K+N fipk intake, polished y-pipe, Turbo xs RFL bov, HKS exhaust with custom tips, southbend ofe clutch, custom pressure plate, joe p mbc, 300m output shaft: 25 spline, lightweight crank pulley, Palm data logger, Solid motor mounts, 120k tune up with oil pump. Low mileage engine swap!
Old engine parts for sale
Gushers248 is offline   Reply With Quote
Old 10-09-2008, 05:14 PM   #357 (permalink)
You could but you`d have to ADD 30% to your MAS signal with a SAFC or similar which would kill the timing, not worth it really, plus your MPG will go down. You`d end up a lot slower?.
Old 10-10-2008, 01:24 PM   #358 (permalink)
Background Guy
Rogue_Ant's Avatar
Drives: '86 Porsche 944
Rogue_Ant Level 1Rogue_Ant Level 1
You could just swap in DSM 450cc injectors... it should be close enough that the Trims would bring it in.
-Rogue
'86 944 Turbo (951)
E-85 Fuel Convert
Powerhaus K27DR Turbo
MAF Translator Pro - MAP Conversion! With Knock Monitoring!
Motronic Enhanements Custom Chip By Hally!
Old Dyno Corrected: 390 RWHP, 417 RWTQ @ +5200ft
See my build-up here!
'02 GSX-R 750
Stock w/ Yoshi slip-on
Rogue_Ant is offline   Reply With Quote
Old 10-10-2008, 03:05 PM   #359 (permalink)
Good point, and a better pump at the same time.
Old 10-10-2008, 09:45 PM   #360 (permalink)
a2j
a2j's Avatar
Drives: Red Car
for some reason I think 450cc is not enough... if you need 30% more and 450cc can give you only 20%. I mean if you want to drive you car with stock boost (doesn't make scene to me using e85) than 450cc might be ok. but to max those 9Bs you'd need at least 550cc. this is from my own experience.
