Old 08-11-2008, 06:09 PM   #331 (permalink)
ver fer's Avatar
Drives: a corn fed VR4
ver fer Level 1ver fer Level 1
Default Re: E85 Powered VR4?
780's will work fine. It will be easiest to tune using the gas scale. The idle and low load and be tuned at the same a/f as as, but you will want to tune a little richer at wot.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
ver fer is offline   Reply With Quote
Old 08-18-2008, 12:33 PM   #332 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Got my dual pump installed with -8an feed. Should be doing some back to back 110 vs E85 runs soon.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 08-19-2008, 06:39 PM   #333 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j Level 1a2j Level 1
so AFR on e85 should be somewhere between 9-10? (at WOT), most gauges will show only 10.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs.
Working on: Driver mod.
E85 powered VR4
For Sale: stock injectors and pump.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
I gave up...
a2j is offline   Reply With Quote
Old 08-19-2008, 09:00 PM   #334 (permalink)
ver fer's Avatar
No 9 would be way too rich.
Old 08-19-2008, 11:30 PM   #335 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
Unless your wideband can switch to an alternate e85 mode, the easiest thing to do it tune for gas A/F ratio which will convert to the correct A/F ratio for e85 since they are both based off a lamda value of 1
9b 13.2 w/ 93 Pump
Originally Posted by Jeremy Clarkson
I am sorry officer, my foot must have slipped off the clutch!
Monster Stealth is online now   Reply With Quote
Old 08-20-2008, 10:33 AM   #336 (permalink)
coz
Drives: 3000GT
coz Level 3coz Level 3coz Level 3coz Level 3
That would be VERY interesting! let us know what you find please
(tune the ign. for both fuels... )
11,7 sec. with td04HL 16T 7cm2 (on e85)
xx,x sec. with twin Holset HX-35 (still on e85)
coz is offline   Reply With Quote
Old 08-20-2008, 10:50 AM   #337 (permalink)
she is already tuned for the 110, so I will do 110 runs, at XX boost then drain tank, put in E85 and run same boost and timing. I want just the fuel change difference. Of course I will add fuel to the AEM fuel map to hit the same AFR.
The Extra 30% fuel should prove to make more torque and boost should spool quicker.
-Chris
Old 08-20-2008, 01:40 PM   #338 (permalink)
coz
Drives: 3000GT
-Chris
I want a dyno too
My guess is that racefuel will give more BHP and that MBT timing is not the same with e85 because of the burn rate ("burn speed" or something... burnrate=förbränningshastighet in swedish)
You could try one pull with less timing to see if there is any difference.
Old 08-20-2008, 10:31 PM   #339 (permalink)
a2j
a2j's Avatar
Drives: Red Car
I just read that on one of the websites and decided to ask.
Old 08-22-2008, 10:49 AM   #340 (permalink)
Been trying to find E98 somewhere in drums. So I can mix my own and be sure it's 85% year around. Closest distributor I can find is Texas and it's $300 to ship it. twice the cost of the fuel.
-Chris
