Old 08-01-2008, 09:55 PM   #321 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Default Re: E85 Powered VR4?
dont buy a NEO yet
as for switching youre going to need an upgraded fuel pump and 450s to safely run E85
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
Old 08-03-2008, 02:26 PM   #322 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Well, I was going to start the E-85 testing/changeover this weekend but I went to the BRG instead. I may get to it this coming weekend.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 08-09-2008, 08:07 PM   #323 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider Level 1vr4_rider Level 1
Hey guys.
I want to run e85.
I have:
walbro 255 pump
780cc injectors
fuel pressure regulator
stock ecu
pro-m
can the stock ecu handle the 780cc injectors? e85 uses 30% more fuel, so will this be a problem?
T
vr4_rider is offline   Reply With Quote
Old 08-09-2008, 09:08 PM   #324 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
I dont see the injectors being 780cc being a problem, I do see you only list one walbro. 780cc injectors are going to require at least a 300lph fuel fump at what ever psi of boost you plan on running. I plan on running dual walbros and true dual -6an feed lines w/ 880cc injectors.
9b 13.2 w/ 93 Pump
Originally Posted by Jeremy Clarkson
I am sorry officer, my foot must have slipped off the clutch!
Monster Stealth is online now   Reply With Quote
Old 08-09-2008, 11:30 PM   #325 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
780cc req. at least 2 walbros? that's news to me...
can someone confirm? i don't have two walbros...booooo.
Old 08-10-2008, 09:15 AM   #326 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
whats the afr for ethanol? and how do i view it on my wideband? it only goes from 10-18....
Old 08-10-2008, 10:00 AM   #327 (permalink)
Forum user
Trader Rating: (25)
.780 *6 * 60 =280.8 lph at 100% IDC. A single walbro will only flow ~250 lph at 65psi. You may want to look into running one in tank and one inline. I know IPO did this on his daily driver build, and that configuration would be plenty for you.
Old 08-10-2008, 10:05 AM   #328 (permalink)
Forum user
Trader Rating: (25)
If your wideband doesn't have a setting for ethanol, you just want to tune for the same A/F ration as gas. All of them go off the lambda scale, so it will not matter.
Edit: Here is a link that may help you understand a little better.
E85 Mustangs.com - Tuning a Mustang for E85
Old 08-10-2008, 01:47 PM   #329 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
thanks guys.
Old 08-11-2008, 07:11 AM   #330 (permalink)
again, was going to switch to E85 this weekend, even got all the dual pump dual feed -8 feed fuel parts ready to install. Now a broken tow has hindered moving forward. Maybe next weekend. I will have back to back results once I get to it.
