Old 07-30-2008, 06:41 PM   #311 (permalink)
Whoa....
ABQTT's Avatar
Drives: 91 RTTT
ABQTT is an unknown quantity at this point
Default Re: E85 Powered VR4?
Just a thought, I read about fifteen pages back (which was as far as my eyes would let me read before I had to give in) that Ethanol loves high compression motors, and with the added octane you can push a moderate amount of boost without detonation. I am in the process of picking up a new project car and had a thought... Would a turbo'd N/A motor provide any sort of advantage over our lower compression TT set-ups, or would they even be able to handle it? Mind you this is a pure E85 set-up and using a mild turbo, 13g most likely. P.S. I'm a firefighter so I'm used to flames
LNF
ABQTT is offline   Reply With Quote
Old 07-30-2008, 07:59 PM   #312 (permalink)
ver fer's Avatar
Drives: a corn fed VR4
ver fer Level 1ver fer Level 1
I won't flame you, in fact I had the money I would build one.
Chris, another advantage of ethanol is it also burns much faster so less timing is needed. I had a graph of flame speed vs. afr for e-85 and gas.
I'll try to post it if I can find it. I don't know what kind of gas they used to compare with though.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
ver fer is offline   Reply With Quote
Old 07-30-2008, 08:16 PM   #313 (permalink)
USMC
vr4_rider's Avatar
Drives: 3/S
Trader Rating: (12)
vr4_rider Level 1vr4_rider Level 1
hey ver fer...
you have 13Ts and 680s...what are your IDC with e85?
I am on evo 560 on my 13Ts and I hit 87 IDC at about 15psi at stock fuel pressure...
I heard 680s might be too small?
vr4_rider is offline   Reply With Quote
Old 07-31-2008, 05:04 AM   #314 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
check it
Spark Advance vs. Fuel Efficiency & Gasoline vs. E85
Considering ethanol and likewise E85 has a faster flame speed than gasoline, the peak pressure in the cylinder would build faster and it stands to reason that all else being equal, E85 would like the spark to occur slightly closer to TDC (ie less advance) when compared to gasoline. The results showed about 5 degrees less advance in this case was optimal.
In summary, this test showed that E85 does indeed like slightly less timing for optimal efficiency when compared to gasoline. Additionally, in either case (E85 or gasoline) it is better to have slightly more advance than optimal compared to slightly less advance. Efficiency is lost rather rapidly with too little advance and affected only slightly with too much advance. Although efficiency gains can be realized by slightly reducing the timing advance when running E85, the effect is likely to be rather small - probably a gain of <0.5% and most surely <1%. In my specific case, given an optimal gasoline advance of ~43 deg BTDC to an optimal E85 advance of ~37 deg BTDC would net approximately 0.63% efficiency gain (ie 25mpg to 25.16mpg)
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 07-31-2008, 03:10 PM   #315 (permalink)
Smooth and Fast
Erron Spalsbury's Avatar
Drives: E-Mod Race Car
Trader Rating: (15)
Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7Erron Spalsbury Level 7
This may off topic to the current discussion, but thought I would share. I've ran e85 for over 2 years with a mostly stock fuel system. Upgraded pump, but lines, tank, filter, and rails were all stock. I upgraded the entire fuel system over the last month so it gave me a real insite to the deterioration properties of the e85 being in our cars. I can say without a doubt now, that our cars can take it. The race car is a 92 and I looked into the tank, cut out all the stock fuel lines and had a real good look at the rails and filter. I couldn't find anything at all that shows any corrosion. No rust in the tank, no particulates in the filter of steel or aluminum.
Erron S.
Want to see a hot lap of my Stealth?
http://3svideo.vidiac.com/video/acfd...6e012f3f5d.htm
Or, drag racing...
http://3svideo.vidiac.com/video/c07a...b801720019.htm
www.stickyvinylgraphics.com
Custom vinyl and yes, now accepting aps for 2009 sponsorships! (Cars, Planes, and Bikes)
More pics of my car...
http://profile.imageshack.us/user/Blueveloscity/
Erron Spalsbury is offline   Reply With Quote
Old 07-31-2008, 03:17 PM   #316 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
Erron, what size were/are you injectors and what if any correction factor were you using?
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 08-01-2008, 10:40 AM   #317 (permalink)
Smooth and Fast
Trader Rating: (15)
1000cc, no correction.
Old 08-01-2008, 06:51 PM   #318 (permalink)
Culzephyr's Avatar
Drives: 1992 3000GT VR-4
Culzephyr is an unknown quantity at this point
I bought the car when I wasn't married and now I am so I don't have a lot of spending money. We have a budget and extra money for the VR-4 wasn't part of it.
I need a not too expensive AFC that will allow me to switch back and forth between Pri Gas and E-85.
Is this a decent AFC Apexi NEO AFC Air Fuel Controller 401-A917
I found this one on e-bay. the bid has 4 days left but I could afford it if it doesn't go up to much.
Nick
Originally Posted by Monster Stealth View Post
So you are running 450 injectors and no AFC?? You need to stop driving the car if this is the case until you can get one installed. Change your oil asap as well. You are running insanely rich and I am surprised you have not spun a bearing or thrashed your engine already. If i misread your post and your are not, then ignore me . I would look into either a SAFC2, MAPECU, Greddy Emanage, or the MAF Translator PRO. SAFC2 being the simplest of all of them. A single hotwired walbro will be plenty big to supply enough fuel to those injectors. I assume you are staying with 9b's?
The Quest for speed is on!
Mods:
EGR Block Off plates, Stage II Clutch, Lightweight Crank Pulley, Adjustable Camber Arms, Turbo Timer, Y Down Pipe, 450cc Injectors, Custom Push Button Starter
Culzephyr is offline   Reply With Quote
Old 08-01-2008, 07:15 PM   #319 (permalink)
Drives: An AEM car in -10F
Trader Rating: (9)
MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5MustGoFaster Level 5
DO NOT BUY A SAFC NEO! There is a big thread somewhere around here with all the details as to why not.
~Ryan
92 Stealth R/T TT- Not exactly done- 93 RT TT- Not much of a car anymore.
"This is a solution looking for a problem." - Not me
MustGoFaster is offline   Reply With Quote
Old 08-01-2008, 07:31 PM   #320 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
I would not get the NEO. Look into the SAFC2. If you want to run dual maps to switch back and forth on the fly, look into the emanage blue or MAPECU. Again, if you are running 450cc injectors and no fuel control do not drive your car anymore, or you will have even less money.
Nick
Monster Stealth is online now   Reply With Quote
