Old 07-30-2008, 04:26 AM   #301 (permalink)
Corn Its whats for boost
Import Power's Avatar
Drives: Vicki Insane
Trader Rating: (210)
Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7Import Power Level 7
Default Re: E85 Powered VR4?
Originally Posted by ver fer View Post
Yeah that is a good place to start. You'll want to tune it a little richer than with gas. I shoot for around 11.6-11.2.
I don't know I you injectors will be large enough to though. I have 680's and 13t's with the fuel pressure at 50 psi my IDCs were over 100. I just turned the fuel pressure up to 55 psi and the IDCs are now around 90.
I have 1000cc inj and two pumps.
We shall see. Not looking for huge power. Stock heads will limit that.
Maybe 650awhp tops
I can also turn the pressure up to 55psi or so. It's going to be close according to the calculations.
AEM Factory Trained Tuner
91VR4-3.0L-Stock heads and Cams-762AWHP 747AWTQ 30psi E100 Daily Driver 10.63@121mph
T4 AWD 9.21 @ 154.98
T2 FWD 10.19 @ 140.31
T2-820FWHP 3.1L 27psi C16
91VR4 Red-17Gs w/supporting mods-sold
93SLTT/T2
91VR4 Pearl White-sold
91VR4 Black-sold
92VR4 Sandstone-sold
94VR4 Green-sold
93VR4 Pearl White-sold
NG09 Title Sponsor
3SX Performance
3SX Performance Service Email
Old 07-30-2008, 05:54 AM   #302 (permalink)
We can make it better!
Drives: 1996 GTO
MichaelMR2 Level 1MichaelMR2 Level 1
Fuel ........................ AFRst ........ FARst ....... Equivalence Ratio ... Lambda
Gas stoich ................ 14.7 .......... 0.068 ................ 1 ................... 1
Gas max power rich .... 12.5 .......... 0.08 ................. 1.176 .............. 0.8503
Gas max power lean .... 13.23 ........ 0.0755 .............. 1.111 ............. 0.900
E85 stoich .................. 9.765 ....... 0.10235 ............ 1 ................... 1
E85 max power rich ...... 6.975 ....... 0.1434 .............. 1.40 ............... 0.7143
E85 max power lean ..... 8.4687 ...... 0.118 ............... 1.153 .............. 0.8673
E100 stoich ................ 9.0078 ...... 0.111 ............... 1 .................... 1
E100 max power rich .... 6.429 ........ 0.155 .............. 1.4 .................. 0.714
E100 max power lean .... 7.8 .... ...... 0.128 .............. 1.15 ................ 0.870
Stolen from:
Converting to E85 (ethanol fuel) - Turbobricks Forums
MichaelMR2 is offline   Reply With Quote
Old 07-30-2008, 06:40 AM   #303 (permalink)
Stolen from:
6.975 max power rich?
That's odd, everyone here says tune for 11.2-11.6.
Which is it?
What I will do is start at WG pressure, 14psi, and work my way up until (if) I run out of pump/injector.
One thing I am really interested in is power under the curve. The 50 trims are laggy, and from what I have been reading the extra 30% fuel creates a nice increase in exh flow which makes turbos spool up faster.
I have enough runs at various boost levels with the dyno logging boost to compare boost/spool and power.
I will make a new thread when all the data is captured. I will start with no timing advance over what I run now to see what E85 does with just the 30% (give or take) fuel adjustments. And how much faster spoolup is. Then how much timing I can give it and the power increases. It will be a good comparison. Our dyno is very accurate/repeatable. A car can come back a month later and be within 1-2 HP. So comparison runs will be accurate data.
This is going to be fun.
Old 07-30-2008, 07:50 AM   #304 (permalink)
Background Guy
Rogue_Ant's Avatar
Drives: '86 Porsche 944
Rogue_Ant Level 1Rogue_Ant Level 1
That is the true AFR. However most people use the gasoline scale, since it is easier and familiar.
If you don't change the scaling on your WBO2, then shoot for 11.2-11.6:1.
-Rogue
'86 944 Turbo (951)
E-85 Fuel Convert
Powerhaus K27DR Turbo
MAF Translator Pro - MAP Conversion! With Knock Monitoring!
Motronic Enhanements Custom Chip By Hally!
Old Dyno Corrected: 390 RWHP, 417 RWTQ @ +5200ft
See my build-up here!
'02 GSX-R 750
Stock w/ Yoshi slip-on
Rogue_Ant is offline   Reply With Quote
Old 07-30-2008, 08:10 AM   #305 (permalink)
-Rogue
that's kinda what I thought...but then ti confused me
Old 07-30-2008, 08:48 AM   #306 (permalink)
NG09: The Comeback Tour
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7Alan92RTTT Level 7
Originally Posted by Import Power View Post
Found the closest E85 station (National Ethanol Vehicle Coalition) to me is only 23 miles away. Today's price is $3.69/gal and they allow Container/drum filling. I have an empty 55 gallon C16 drum.
Looks like a have a Project this weekend
I can get premium for 3.69 per gallon.
NG07 T-Shirts For Sale * NG08 T-Shirts For Sale
NG08 Stuff from Cafepress
Custom 12x18 poster/photo prints
Alan(3SI#601)alan92rttt@mi3si.org Michigan 3SI.
1992 Dodge Stealth RT/TT
My Snake Eyes, 13g Turbos, 450cc DSM injectors, Walbro 255 Fuel Pump, Autometer Boost Guage, Greddy peak/hold EGT, Apexi S-AFC, K&N FIPK, Clean Cats, 3rd Gen Lifters, JVC SX990 CD/MP3 Receiver, JVC CH-X200 12 Disc Changer.
1998 3000GT SL
Alan92RTTT is offline   Reply With Quote
Old 07-30-2008, 08:53 AM   #307 (permalink)
your point being?
My $3.69/gallon is E85 which is Race fuel (actually works better than race gas in most applications) not 93 octane pump.
Old 07-30-2008, 08:58 AM   #308 (permalink)
Alan92RTTT's Avatar
Drives: 1992 RT/TT
My point being E85 normally runs about 50 cents less per gallon from regular. I can probably get E85 for about $3.
I'd think that you shoujld be able to get a much better price than that.
Old 07-30-2008, 09:03 AM   #309 (permalink)
Regular is $4.00 here, some places are at $3.99.
NC has a higher Tax on fuel than any surrounding state.
Old 07-30-2008, 09:07 AM   #310 (permalink)
Alan92RTTT's Avatar
Drives: 1992 RT/TT
Ah, I'm just used to MI being on the higher side in the summer.
