Old 10-01-2007, 11:53 AM   #21 (permalink)
i love car
cerevo's Avatar
Drives: Dodge Neon
Trader Rating: (11)
cerevo is an unknown quantity at this point
Default Re: E85 Powered VR4?
where are you all getting E85? i dont think anyone around here sells it..
Three Diamonds
cerevo is offline   Reply With Quote
Old 10-01-2007, 03:35 PM   #22 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (56)
lethal_vr4 is an unknown quantity at this point
Local co-op found it through: http://e85vehicles.com/e85-stations.htm
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
lethal_vr4 is offline   Reply With Quote
Old 10-11-2007, 11:04 PM   #23 (permalink)
Mr. Cheese
92RT-TT's Avatar
Drives: 92 RT/TT & 94 SL
Trader Rating: (11)
92RT-TT is an unknown quantity at this point
I know you said that it should be safe on our cars because our fuel is 10 already... but what about my car, its 15 years old? About how much more boost can you run with everything else being stock besides the injectors, fuel pump, and afc?
92RT-TT is offline   Reply With Quote
Old 10-12-2007, 06:08 AM   #24 (permalink)
Now with more 40D
leet's Avatar
Drives: a 92 in 6th gear
Trader Rating: (24)
leet is an unknown quantity at this point
before I moved to europe I ran a 4:1 mix of 91/E85 for a good 2 years
that bumped up the octane enough to run 20psi on DSM 13g's and DSM SMIC's without knock, my fuel mods were 580cc injectors and a hotwired walbro
I also dynoed 343hp/356tq at 18psi, the car had WAY more left in it, long story short (24 bent valves ) I didn't have time to get it tuned very well before going to the dyno so I stayed fairly conservative
the stealth is officially for sale, PM for info
leet is offline   Reply With Quote
Old 10-12-2007, 06:10 AM   #25 (permalink)
Now with more 40D
leet's Avatar
Trader Rating: (24)
also the DSM shop that was near me when I lived in oklahoma made 650hp on straight E85 in a 1g DSM, and I think 575 on the 4:1 mix
it's good to see 3si finally starting to come around to E85, I remember when I first heard about it and started using it, everyone said I was going to damage my car and it wouldn't work and that it wasn't worth it, even though there were tons of people on other platforms (DSM's specifically) before me that used it no problem and saw huge benefits
Old 10-12-2007, 06:15 AM   #26 (permalink)
Now with more 40D
leet's Avatar
Trader Rating: (24)
oh one more thing, check out www.e85fuel.com they have a listing of all the stations around the country that sell it
Old 10-12-2007, 06:20 AM   #27 (permalink)
lethal_vr4's Avatar
Trader Rating: (56)
Your car can run on E85 perfectly fine, providing you have enough fuel pump/injector to provide the needed fuel. Ideally, I'd recommend a fuel controller that could control timing, unlike your SAFC.
As for how much more boost you could run it will vary car by car depending on modifications, but if you open up your exhaust by getting a downpipe/testpipe and gutting pre-cats you should be able to max out your current setup... then it is time to look into a better fuel controller, bigger IC's, and a larger turbo setup.
Think of it like this. Running E85 is like running 110 race gas. You can safely run significantly more boost without worrying about detonation.
Old 10-12-2007, 08:33 AM   #28 (permalink)
ver fer's Avatar
ver fer is an unknown quantity at this point
You won't be able to run e-85 on the stock set up. You will need larger injectors and fuel pump.
I am currently running ~30% ethanol mix (3gal 110/2gal e-85) and my IDCs hit the high 90's.
I ran e-20 (20%,91 octane) to the NG this year and did a few pulls on the way and had no knock up to 18psi.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces Falken GR Beta FK-451
ver fer is offline   Reply With Quote
Old 10-12-2007, 08:53 AM   #29 (permalink)
lethal_vr4's Avatar
Trader Rating: (56)
I think he has a pump and injectors. BTW you coming up to RA this weekend?
Originally Posted by ver fer View Post
You won't be able to run e-85 on the stock set up. You will need larger injectors and fuel pump. .
Old 10-18-2007, 08:26 PM   #30 (permalink)
1stStealthN/A's Avatar
Drives: 94 3000GT, 92 VR4
1stStealthN/A is an unknown quantity at this point
E-85 conversion kit: http://www.change2e85.com/servlet/StoreFront
I have blended an E-20 mixture for over a year on my SL with no problems.
It's 93 octane and I pay less than regular 87 octane prices.
I may buy the kit but mileage will drop at least 5 mpg.
1stStealthN/A is offline   Reply With Quote
