Old 07-27-2008, 12:09 PM   #281 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j Level 1a2j Level 1
Default Re: E85 Powered VR4?
whats the psi limit for e85? on 9b? on any turbo?
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs.
Working on: Driver mod.
E85 powered VR4
For Sale: stock injectors and pump.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
I gave up...
a2j is offline   Reply With Quote
Old 07-27-2008, 01:53 PM   #282 (permalink)
ver fer's Avatar
Drives: a corn fed VR4
ver fer Level 1ver fer Level 1
What ever you can run with out getting knock or running out of fuel. The same as any other fuel.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
ver fer is offline   Reply With Quote
Old 07-27-2008, 02:19 PM   #283 (permalink)
a2j
a2j's Avatar
Drives: Red Car
reason why I'm asking is, with 93 (pump gas) you getting know at 17-18 psi (thats what I heard). and with race gas you're not suppose to get any with 30psi or so. but e85 is ~105 oct. so just wondering if anybody had problem with 25+ psi.
Old 07-27-2008, 02:34 PM   #284 (permalink)
Senior Member
Drives: 1994 3000gt VR4
Trader Rating: (9)
1fastvr4 is an unknown quantity at this point
There are Evo's up here in the Denver area running 30psi+ on E85. Even though E85 is only about 105 octane it acts more like 114+. This is due to the extra energy of burning 20-30% more fuel. I am only up to 20psi so far but will be turning it up to 25-26psi within the next month or so.
Dean
1994 Black 3000GT VR4 w/only 39,800 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
1fastvr4 is offline   Reply With Quote
Old 07-27-2008, 03:17 PM   #285 (permalink)
a2j
a2j's Avatar
Drives: Red Car
thank you, thats what I needed to know.
Old 07-27-2008, 07:05 PM   #286 (permalink)
Forum user
Monster Stealth's Avatar
Drives: 93 VR4 & 99 A4 1.8T
Trader Rating: (25)
Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7Monster Stealth Level 7
You still have to remember 9b's fall flat on there face after 5k rpm's and anything over ~15psi is just going to blow hot air and offer no performance increase.
9b 13.2 w/ 93 Pump
Originally Posted by Jeremy Clarkson
I am sorry officer, my foot must have slipped off the clutch!
Monster Stealth is offline   Reply With Quote
Old 07-28-2008, 12:15 PM   #287 (permalink)
Culzephyr's Avatar
Drives: 1992 3000GT VR-4
Culzephyr is an unknown quantity at this point
I have read every post. It took a few days of free time, but I did it.
I want to make sure I have this right.
To upgrade my car to be able to run on E-85 all I have to is:
Upgrade my Fuel Injectors and Fuel Pump and get an A/F Gage or AFC (not sure exactly what that stands for).
My Fuel injectors already have been upgraded to 450cc form a Talon
So from what I have read I need a bigger Fuel Pump and a A/F gage.
The one other question I have is about the gas lines. I had heard that you had to replace them because the e-85 would eat away at the rubber and it could break or a piece could get caught in the fuel injectors. From what I have read that is not a issue with our cars. I just want to make sure that is correct.
So if all I need is a bigger flow fuel pump and a AFC what is a AFC?
Thanks,
Nick
The Quest for speed is on!
Mods:
EGR Block Off plates, Stage II Clutch, Lightweight Crank Pulley, Adjustable Camber Arms, Turbo Timer, Y Down Pipe, 450cc Injectors, Custom Push Button Starter
Culzephyr is offline   Reply With Quote
Old 07-28-2008, 12:49 PM   #288 (permalink)
Forum user
Trader Rating: (25)
AFC is Air Fuel Controller. WHat do you have controlling the DMS 450's now? You will need a wideband O2 gauge and sensor to monitor your air to fuel ratio. Stock lines should be ok, but you will need to change out your fuel filter a few times since ethanol cleans rather well and will likely dirty your fuel filter rather quickly at first.
Thanks,
Nick
Old 07-28-2008, 01:38 PM   #289 (permalink)
Culzephyr's Avatar
I don't have anything right now. I helped my buddy install the 450cc's when he had a problem with his stock injectors. I bought the car from him a few months later and have never got around to getting a AFC. I knew I needed a new computer but I had some other mechanical issues that I was working on and that just never made the list.
Does anyone have a recommendation for a good AFC, Fuel pump, wideband O2 gauge and sensor that wont break the bank?
I am somewhat of a car guy. I can do all the basic stuff like breaks, gas tanks, some body work but this my first performance car. I am still learning about all the mods and how they work.
Old 07-28-2008, 01:45 PM   #290 (permalink)
Forum user
Trader Rating: (25)
So you are running 450 injectors and no AFC?? You need to stop driving the car if this is the case until you can get one installed. Change your oil asap as well. You are running insanely rich and I am surprised you have not spun a bearing or thrashed your engine already. If i misread your post and your are not, then ignore me . I would look into either a SAFC2, MAPECU, Greddy Emanage, or the MAF Translator PRO. SAFC2 being the simplest of all of them. A single hotwired walbro will be plenty big to supply enough fuel to those injectors. I assume you are staying with 9b's?
