Old 06-30-2008, 07:50 AM   #271 (permalink)
Senior Member
Drives: 1994 3000gt VR4
Trader Rating: (9)
1fastvr4 is an unknown quantity at this point
Default Re: E85 Powered VR4?
No, crank. Not sure how accurate it is but I bet it's ballpark.
I've ran those numbers on Jeff's site also but I don't think that 440 awhp (assuming 20% drivetrain loss) would net a 122 mph traps. I could be wrong though.
P.S. That run was in Denver at 5800' elevation.
1994 Black 3000GT VR4 w/only 39,800 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
1fastvr4 is offline   Reply With Quote
Old 06-30-2008, 07:52 AM   #272 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (61)
Oh, shut up and find a dyno!
2002 WJ -- 1994 VR-4 -- Canon Rebel XTi
Originally Posted by Kenneth Ellis View Post
Every one of you are fools, each and every one.
Old 06-30-2008, 07:56 AM   #273 (permalink)
Senior Member
Trader Rating: (9)
I know I need to but I am flippin broke and I still need to install bigger injectors so I can turn up the boost and get some real numbers.
Old 06-30-2008, 09:47 AM   #274 (permalink)
Background Guy
Rogue_Ant's Avatar
Drives: '86 Porsche 944
Rogue_Ant Level 1Rogue_Ant Level 1
It is in the ballpark only if it is WHP. If 550BHP, then that is only ~440WHP or so at best. A 3900lbs car isn't going to trap 122mph with only 440whp.
Here is a couple of hp calculators that use WHP:
1/4 mi WHP Calc
1/4 mi WHP Calc
-Rogue
'86 944 Turbo (951)
E-85 Fuel Convert
Powerhaus K27DR Turbo
MAF Translator Pro - MAP Conversion! With Knock Monitoring!
Motronic Enhanements Custom Chip By Hally!
Old Dyno Corrected: 390 RWHP, 417 RWTQ @ +5200ft
See my build-up here!
'02 GSX-R 750
Stock w/ Yoshi slip-on
Rogue_Ant is offline   Reply With Quote
Old 06-30-2008, 10:05 AM   #275 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (61)
Very cool Rogue. Great links.
Those call for between 520-550 whp. That makes more sense I think.
Old 06-30-2008, 10:17 PM   #276 (permalink)
Background Guy
Rogue_Ant's Avatar
BTW did your injectors come in?
-Rogue
Old 06-30-2008, 10:37 PM   #277 (permalink)
mechanical engineer
golfer17's Avatar
Drives: 97 240SX SE
golfer17 is an unknown quantity at this point
I haven't read through this whole post, so I don't know if this has been posted yet, but the link below contains the best e85 faq I've seen so far. I now run a 25-30% mix on my sr20, mostly for an added safety factor, and I love the stuff.
E85 fuel FAQ - NASIOC
97 240sx- approx. 350whp, daily driven for last two years.
94 3kgt: sold
92 stealth: sold
golfer17 is offline   Reply With Quote
Old 07-01-2008, 04:53 AM   #278 (permalink)
Senior Member
Trader Rating: (9)
-Rogue
Yes, but I probably won't have time to put them in until after the 4th.
Dean
Old 07-03-2008, 01:50 PM   #279 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
I don't have any dyno numbers just track numbers.
11.65 @ 122 mph at 20 psi and 3900 lbs race weight on E85.
Dean
probably right around 500 awhp
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 07-04-2008, 11:57 AM   #280 (permalink)
Drives: 05 EVO VIII RS
Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7Fourdoor Level 7
Hey guys,
In my E-85 fueled EVO I only ran it for one winter on E-85 due to the cold start issues. I don't really need 500+ wheel HP on snow tires and slippery winter roads anyway, so I now run gasoline in the winter. I defenitly had alcohol smell in my oil change that spring, but I think that the oiling system in the EVO's is more robust than in the 3s cars, and that combined with no dyno runs or racing in the winter resulted in no damage being done.
If anyone is interested in parts for a high HP E-85 combination I will have a for sale thread after I am a "verified seller" (may take a while on a holliday weekend)... not going to go off topic or circumvent selling rules by trying to sell stuff in this thread.
Later,
Keith
Heavily Modded 05 EVO RS (550 wheel HP on Dynapack AWD dyno) on E-85 along with a 96 VR-4 Spyder.
Fourdoor is offline   Reply With Quote
