Old 06-07-2008, 05:52 PM   #261 (permalink)
coz
Drives: 3000GT
coz Level 3coz Level 3coz Level 3coz Level 3
Default Re: E85 Powered VR4?
Originally Posted by Hammer View Post
People are pulling as much as 20 more degrees of timing beyond best power
at 1,000 hp dyno pulls without detonation occuring.
Trust me, you cant ADD 20 degrees of timing and dont get headlift, atleast not on a 3/s turbo.
11,7 sec. with td04HL 16T 7cm2 (on e85)
xx,x sec. with twin Holset HX-35 (still on e85)
coz is offline   Reply With Quote
Old 06-07-2008, 08:57 PM   #262 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Originally Posted by UPP View Post
Hey guess what!!! I just found down -side to E85!!!
Since I'm in a bit of a colder climate (CO) and it was already mentioned that cold starts are much harder with E85 since it dosn't atomize and burn as well when cold.... Well if you continuously crank the hell out of your engine....you can wash down your cylinder walls! But that's not even the real problem. I just happened to check my oil the other day since I'm starting to bring this thing out more for summer, and it smelled ALOT like E85! Naturally I changed it, but I'm afraid that the winter cranking (then driving) damage has already been done. Spun a bearing today at the track. I was tweaking with it on the dyon earlier this week, making decent power, but had random unexplainable knock. Pulled a little timing, and thought nothing of it, it was still there so I figured it was the "phantom". Durring the second pass the oil press fell back to 50psi, and then ~15psi at idle after that.....and inevatibly...clank clank clank...
It's not really the E85's fault, it's mine. But E85 had a harder time starting the car, which initially caused the fuel in the oil, and ethanol is a little more corosive on the oil than regual gas would be.... But oh well....
I'm just going to throw in a $100 SL high compression motor for now, and see how long it lasts!
UPP
yesa hard start when cold is a downfall to ethanol. this is why most stations will go to an E70- blend in the winter.
as for the parts that came out of that tahoe.....ive pulled fuel pumps out of vehicles that looked much worse than the 1 he used for the gasoline example that were run on gas only.
for the record i agree with everything thats been posted lately and find it funny that i said pretty much everything about 15 pages ago.
meth is a crutch for an improperly designed fuel system/engine control. period.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
95 montero SR. factory rear locker. 3.5 DOHC
91vr4n00maxima is offline   Reply With Quote
Old 06-08-2008, 03:18 AM   #263 (permalink)
Hammer
Drives: 95 3000gt vr4 stock
Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7Hammer Level 7
Originally Posted by dlabonte View Post
They say it ran on E-85 when it was available, not 100% E-85. Run water-meth on that thing and the valves would look almost new.
The test vehicle can from an owner of an ethanol plan. What nobody is going to scream biased propaganda on this one?
You are really missing the bigger picture here. This engine did not have larger injectors for E85 nor did it have a fuel map for E85. It was setup to run on gas
and he just put E85 in it and ran it. And it worked quite well for him.
Lets take the reverse picture and assume the engine was setup and tuned
to run only on E85. And then he just went ahead and put gas in it and ran it that way without changing anything. Could he be saying the same thing?
Other than the cold start problem I think it is great stuff.
And for someone like me that only runs the car during the summer that is not
a negative at all.
P.S.
A buisness idea for you meth dealers to make some cash from E85.
Design an Ether starting helper for the engine for the winter time.
Something with a replaceable Ether can. That shoots in some Ether just for
winter starts. It could be run by a push button device that you could mount anywhere. Just give it a shot and instant cold start. You can then carry a spare can with you to reload when your current can goes empty.
Sell the kit with 2 cans in it to get the idea accross to always have a spare
with you.
Hammer is offline   Reply With Quote
Old 06-08-2008, 04:00 AM   #264 (permalink)
Hammer
UPP
Perhaps a high compression engine will start better in the winter.
If not you could try ether as a starting helper.
Did you use E70 winter blend during your hard starting problem?
Old 06-08-2008, 10:33 AM   #265 (permalink)
RogueValley's Avatar
Drives: 2006 GTO/92 Stealth
RogueValley Level 1RogueValley Level 1
I'm going to go with spun bearing. And the "phantom" knock, that really shouldn't have been there as conservative as my timing was..... Going to ALSO go with premature spun bearing, causing inaudiable knocking, that my KS was actually picking up.
In the last month I did notice a slighly lower oil pressure, just under 25psi as opposed to right at 25. Because it's been hotter I thought nothing of it. In hind sight, I'm looking at that as bearing wear due to the E85 in the oil, deteriorating it. This caused a "phantom" knock, which was actually my rod bearing bearly acting up. Then since I beat the piss outa it on the dyno, and even more so at the track, it matured into full grown rod knock.
UPP
So, UPP-Do you think doing some preventative work and adding an engine heater would help to minimize cylinder wall washing? Granted the heater may have to be on for a while before you tried to crank it. I'm just trying to think of a way to help get this project a little more off the ground.
RogueValley is offline   Reply With Quote
Old 06-29-2008, 03:46 PM   #266 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j Level 1a2j Level 1
I'd like to see (if there are any) awhp #s with E85 on 3/S.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump, DSM SMICs.
Working on: Driver mod.
E85 powered VR4
For Sale: stock injectors and pump.
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
I gave up...
a2j is offline   Reply With Quote
Old 06-30-2008, 08:32 AM   #267 (permalink)
Senior Member
Drives: 1994 3000gt VR4
Trader Rating: (9)
1fastvr4 is an unknown quantity at this point
I don't have any dyno numbers just track numbers.
11.65 @ 122 mph at 20 psi and 3900 lbs race weight on E85.
Dean
1994 Black 3000GT VR4 w/only 39,800 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
1fastvr4 is offline   Reply With Quote
Old 06-30-2008, 08:35 AM   #268 (permalink)
Here for the tuna.
lawdogg's Avatar
Drives: The Speed Limit
Trader Rating: (65)
Dean
Stealth 316 - Formulas for 1/4 mile ET & mph vs. hp & wgt
Looks like around 550 bhp.
94 VR-4: 11.8 @ 116, 17psi, pump, 13Ts
Old 06-30-2008, 08:42 AM   #269 (permalink)
Senior Member
Trader Rating: (9)
Is that wheel hp?
Old 06-30-2008, 08:44 AM   #270 (permalink)
Here for the tuna.
lawdogg's Avatar
Trader Rating: (65)
Is that wheel hp?
No, crank. Not sure how accurate it is but I bet it's ballpark.
