#221 (permalink) | |
Yeah I thought the same about the $7 for shipping a hazmat container full of fuel. I did not see the small print. Does anyone know if you can load the ultimate with multiple maps and have them available on the fly? One for pump and one for the e85? |
#222 (permalink) | |
#223 (permalink) |
Corn Its whats for boost
Basicaly that is what you can do with the AEM. You can use the Nitrous Timing and Fuel table. Then use the Nitrous Switch on input to turn those tables on or off. Cool shit.
AEM Factory Trained Tuner
![]() 91VR4 Black-5027s-3.0L-Stock heads and Cams- 770AWHP 670AWTQ uncorrected 33psi E90 Daily Driver SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold NG09 Title Sponsor 3SX Performance 3SX Performance Service Email |
#224 (permalink) | |
Senior Member
E85. I am using 780 injectors and alchy (similar setup) and I am pretty maxed out at about 20psi. I turned my base fuel pressure up to 53.5 so that I can squeeze another 3 psi to get me up to 23psi or so. My next step will probably be 1000cc injectors. The bigger DSMs that are on E85 are running 1200 to 1600cc injectors. Some shops have done tests switching from pump to E85 and when only changing the fuel to match the AFR they are seeing torque gains of about 30. That is without uping the timing that you can do with E85. Dean
1994 Black 3000GT VR4 w/only 39,800 miles: IPS thermal coated headers, o2 housings, and EVO 3 16g turbos, Dynamic Racing Stage 3 heads, Fidenza cam gears, UDP, RPS flywheel, Weisco forged and coated pistons, Dejon tool intake pipes. Alamo intercoolers (bigger than HKS), DN hardpipe kit, DN y-pipe and downpipe, HKS SSBOV, Extrude-honed upper and lower plenum, 780 PTE injectors, MAFT Pro in speed density mode, HKS Hotwired fuel pump, Kenne bell boost-a-pump, AEM FPR w/gauge, Greddy turbo timer, HKS 3" Super Drager Exhaust w/5" single tip, Greddy Profec A boost controller, ARM1 air/fuel gauge, ACT 2600 clutch, Eibach 1" lowering springs, Brembo front calipers, Greddy peak hold white faced gauges including boost, water temp, oil pressure, (2)EGT's, and oil temp, PLX300 wide band, SMC Alcohol injection system. PST 2 piece Carbon fiber drive shaft.
#225 (permalink) |
FastVR4:
I'm just going off of what the tuner said. I'm not an expert on the matter as this is all new to me. Although I was told there was no way that I'd be able to run 680cc injectors and tune with a SAFC2 by several places and the tuner was able to do it with great results even though I also was doubtful. I'll be first person to say whether or not it was or wasn't possible. I was told by Matt at Dynamic that at 500awhp that the stock MAF couldn't keep up and at 496awhp on the dyno that held exactly true which was the most acurate piece of information I have had yet. I have been told that the stock ECU is crap and I have to get rid of it, but I see some people making great power and saving them a few bucks from going with a stand alone system. If it needs bigger injectors I wouldn't think twice about ordering them but I'll see where the 680's get me before I start guessing at where I need to be with injectors. I use to be the one bagging on imports, but honestly they impress the hell out of me now and even though I miss ripping the tires loose on a rwd muscle car i wouldn't trade this import for one. |
#226 (permalink) |
Background Guy
cobill,
I suggest you go to Bandimere on the 6th (IIRC). There should be a few 3si guys there and it would be a good chance to see what everyone else is running and how well it works. There should be a few different setups. -Rogue
'86 944 Turbo (951)
E-85 Fuel Convert Powerhaus K27DR Turbo MAF Translator Pro - MAP Conversion! With Knock Monitoring! Motronic Enhanements Custom Chip By Hally! Old Dyno Corrected: 390 RWHP, 417 RWTQ @ +5200ft See my build-up here! '02 GSX-R 750 Stock w/ Yoshi slip-on |
#227 (permalink) | |
I'm running 13t's and my 680's are maxed out with the boost at 18psi and base FP set a 50 psi.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
#228 (permalink) | |
"Keep the corn on the table, not in the tank" |
#229 (permalink) | |
Pro xfercase destroyer
What does this have to do with E-85 again?
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) ![]() |
#230 (permalink) | |
30. That is without uping the timing that you can do with E85. Quote:
And I can see why E85 would scare someone in the Alky injection kit selling business, but trying to debunk E85 is kinda silly. It's pretty proven to actually give MORE power even before tuning in more timing. It's cheap. And some are getting MORE power out of it than they do on straight race gas. You can't claim that with Alky inj. Sure alky can be great on top of pump gas. But it's no match for E85..I mean cmon..... (I have an aquamist kit on my car myself so I am not an alky hater) |
