#201 (permalink) | |
Your getting 700AWHP from 16g's when running e85 I did not know 16g's were good for that much to the wheel regardless of fuel. WOW!Well I was going to ask what injectors and pump should I run with my 15g's, but seeing that you are running 680's and a hot wired 255 with a b-a-p, it seems like I will be OK. I have 550cc RC's and a 255 with a hot wire and the b-a-p. But let me ask none the less, will that be enough to maximise the 15g's? |
#202 (permalink) |
Play that Funky Music
I would be a little skeptical of a dyno that showed 700AWHP out of 16Gs. Without a little spray...
AEM Factory Trained Tuner
SLTT-10.9 @ 140MPH Stock NA motor and NA heads/Cams T4 AWD 9.21 @ 154.98 T2 FWD 10.19 @ 140.31 T4-159.23 MPH Ran on 6G72 3.1L! T4-995AWHP Uncorrected 6G72 3.0L C16 T2-820FWHP 3.1L 27psi C16 91VR4 Red-17Gs w/supporting mods-sold 93SLTT/T2 91VR4 Pearl White-sold 91VR4 Black-sold 92VR4 Sandstone-sold 94VR4 Green-sold 93VR4 Pearl White-sold 91VR4 Black-5027s-3.0L-Stock heads and Cams- 625AWHP 557AWTQ uncorrected 24psi 102 octane Daily Driver 3SX Performance 3SX Performance Service Email |
#203 (permalink) | ||
est. sept, 2000
i really question 700 awhp on e85 with just 680s and a single walbro. thats just not enough fuel when running alcohol. that is roughly equivelant to someone running 900+ awhp on gas (matt ran out of fuel with 720s and the pressure bumped around there)
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#204 (permalink) | |
and totally agree with running 700AWHP on 16Gs plus using E85 on 680 injectors and a single pump. I currently have two walbros and 1000CC injectors so I should be good for a bit. I could even bump up the pressure if needed. |
#206 (permalink) |
$162.11 shipped ($7 for shipping) for E95; $2.95 a gal. does not seem too bad. Have you found cheaper?
High Performance Fuels and Additives |
#209 (permalink) | |
est. sept, 2000
