Old 09-24-2007, 09:51 AM   #11 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
Default Re: E85 Powered VR4?
so do I have to modify anything in the car besides fuel pump and injectors to run E85 on my VR4?
a2j is offline   Reply With Quote
Old 09-24-2007, 10:47 AM   #12 (permalink)
New User
NotUrSistersMX5 is an unknown quantity at this point
ive heard you also have to reinforce older fuel systems as it eats out the fuel lines easier and stuff? but i hope not. youll get slightly less good mpg too right?
id love to run e85 with my cars... but i dont have the supporting EMS to do so >.<
NotUrSistersMX5 is offline   Reply With Quote
Old 09-24-2007, 08:39 PM   #13 (permalink)
eldos1's Avatar
eldos1 is an unknown quantity at this point
some say that because of most unleaded running 10% ethanol, most fuel systems are safe for e85. The gas in e85 helps keep your fuel system from drying out. True, it will be harder on components, but most should last the life of the car. I also read that you should change your fuel filter with in a few weeks, because of sludge in the tank coming loose. I guess it's like running system cleaner all the time.
There are fuel system additives clamming that they help coat the fuel system for protection also.
eldos1 is offline   Reply With Quote
Old 09-25-2007, 06:52 AM   #14 (permalink)
Large Member
SilverBullet's Avatar
Trader Rating: (8)
SilverBullet Level 1SilverBullet Level 1
So it'd be possible to run E85 just by upgrading the fuel system to larger injectors and high flow pump/lines, and adding a fuel controller?
SilverBullet is offline   Reply With Quote
Old 09-26-2007, 11:16 AM   #15 (permalink)
a2j
a2j's Avatar
Drives: Red Car
what if not to upgrade? just for daily normal driving? or on highway?
Old 09-26-2007, 11:58 AM   #16 (permalink)
Member since May 2001
Nater3kgtVR4's Avatar
Drives: 91' 19T VR4
Trader Rating: (11)
Nater3kgtVR4 is an unknown quantity at this point
So What would be better? Switching to E85 or staying with 91+Methanol to run higher Boost? How much more Octane is the E85?
Nater3kgtVR4 is offline   Reply With Quote
Old 09-26-2007, 07:35 PM   #17 (permalink)
eldos1's Avatar
E85 is 100 to 105 Octane and you can pull it right out of the pump.
Today it's still $2.09 in Denver. Whats the price for the 91+Methanol option?
Old 09-27-2007, 12:42 AM   #18 (permalink)
coz
Drives: 3000GT
coz is an unknown quantity at this point
ive been running e85 since 2004, no fuel related problems so far.
11,7 sec. with td04HL 16T 7cm2, aem ems, 720cc, port/polish, etc..
...2.16 in. inducer on its way...
coz is offline   Reply With Quote
Old 09-29-2007, 04:00 PM   #19 (permalink)
a2j
a2j's Avatar
Drives: Red Car
did you do any modifications to your car?
Old 09-29-2007, 07:06 PM   #20 (permalink)
kihtay's Avatar
kihtay is an unknown quantity at this point
Just FYI- it is alot harsher on the fuel filter and it'll blacken the oil sooner.
kihtay is offline   Reply With Quote
