Old 04-05-2008, 08:36 PM   #171 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
Default Re: E85 Powered VR4?
Originally Posted by vr4_rider View Post
Damn, 720cc? You skipped 680cc..hhehehe.
The FPR must be bumped up quite a bit to get the 560cc to flow around 720cc, eh?
T
i skipped them cause they only flow around 650 and really arent that good of an injector. im sorry.
that is why i said 560s with an afpr. good injector and if you do end up needing more bump the pressure up a bit.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 04-06-2008, 03:26 PM   #172 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
Originally Posted by ver fer View Post
I am using 680's. If I get mine out next weekend I'll let you know if the are enough.
don't forget. I didn't buy injectors yet. so I need some info.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump.
Working on: Driver mod.
E85 powered VR4
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
Old 04-08-2008, 08:47 AM   #173 (permalink)
ver fer's Avatar
ver fer Level 1ver fer Level 1
The way the weather is looking I don't think the car will be leaving the garage this weekend.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces Falken GR Beta FK-451
ver fer is offline   Reply With Quote
Old 04-08-2008, 09:34 PM   #174 (permalink)
a2j
a2j's Avatar
Drives: Red Car
it better get better for the weekend. cuz I want to be at Road America.
Old 04-23-2008, 09:44 PM   #175 (permalink)
a2j
a2j's Avatar
Drives: Red Car
after installing safc. does ecu still gonna try fixing a/f ratio if it will be too rich or lean? cuz I know that it can do that up to 10%. so will it still do that with safc, or now I'm on my own?
Old 04-24-2008, 07:52 AM   #176 (permalink)
ver fer's Avatar
Sorry, it's early, but that makes no sense.
Did you get injectors yet?
Do you have straight E-85 in the car right now?
Old 04-24-2008, 08:36 AM   #177 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (15)
mjannusch Level 1mjannusch Level 1
The stock ECU will still try to adjust your fuel for stoich at low loads, but you need to get your S-AFC dialed in well enough so that the fuel trims don't float around as you drive. You'll need to watch the trims on the logger to determine if the tune is being affected by the ECU or not. Try to keep the trims as close to 100 as possible.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'91 3000GT VR4 (Project for 2008)
mjannusch is offline   Reply With Quote
Old 04-24-2008, 12:59 PM   #178 (permalink)
a2j
a2j's Avatar
Drives: Red Car
thank you. thats what I needed.
Old 04-30-2008, 08:17 PM   #179 (permalink)
a2j
a2j's Avatar
Drives: Red Car
for 560cc what should I set my safc?
I was thinking 30% at Lo. too much?
Old 04-30-2008, 08:33 PM   #180 (permalink)
NG '03 6th Floor Crew
lethal_vr4's Avatar
Drives: 92 VR4/ 01 Lightning
Trader Rating: (57)
lethal_vr4 Level 2lethal_vr4 Level 2lethal_vr4 Level 2
Each car is slightly different depending on exact mods. I'd suggest tuning from a O2 sensor, preferably a wide-band.
Web log: http://apps.blackflagracing.com/Blog/
The Armada
'93 Sandstone Gray 3000GT VR-4
2006 3SI Ride of the Year
2007 All Mitsu Cookout, 1st Place 1st Gen 3/S
'92 Fiji Blue 3000GT VR-4
2004 All Mitsu Cookout, 1st Place 1st Gen 3/S
2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier.
BLACK FLAG RACING
'92 Emerald Green Pearl Stealth RT/TT
3.5L, 15Gs, AEM EMS
lethal_vr4 is offline   Reply With Quote
