#161 (permalink) | |
Driving While Ukrainian
ok, so if 450cc on E85 = 360cc on 93. than I'll get 550cc.
I think that will be plenty for 15 psi for now.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump. Working on: Driver mod. Paint job!! finally. E85 powered VR4 Dream car: F40 (LM) Quote:
#162 (permalink) | |
220K club
I believe that only , is it Buna type seals? are the type that are safe for alcohol based fuels and I am not sure what Mitsu uses in the factory for our cars. Viton seals aren't as resistant. BTW, found the VIN on the Flex fuel truck: 1FTPX14V 0 (0 is a number) 6FB37113 |
#164 (permalink) | |
Keith
Heavily Modded 05 EVO RS (550 wheel HP on Dynapack AWD dyno) on E-85 along with a 96 VR-4 Spyder.
#165 (permalink) |
NG '03 6th Floor Crew
Sure, buy a FPR and turn up the fuel preasure... Not the most elegant solution out there but it would work reasonably well... I'd still recommend some Denso 560's out of an Evo and a decent fuel/timing controller like the EMU. You might was well do it right the first time.
Web log: http://apps.blackflagracing.com/Blog/
The Armada '93 Sandstone Gray 3000GT VR-4 2006 3SI Ride of the Year 2007 All Mitsu Cookout, 1st Place 1st Gen 3/S 2008 All Mitsu Cookout, 1st Place 1st Gen 3/S '92 Fiji Blue 3000GT VR-4 2004 All Mitsu Cookout, 1st Place 1st Gen 3/S 2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier. BLACK FLAG RACING '92 Emerald Green Pearl Stealth RT/TT 3.5L, 15Gs, AEM EMS For Sale |
#166 (permalink) |
USMC
Hey, Lethal.
what do you recommend for injectors for 13Ts and a FMIC? T
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//IPS Single Shot Magnaflow//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger Turbos: 13Tx2 Current Problem(s): Cherries in the rear view mirror In the Process: Nothing Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel... |
#167 (permalink) |
est. sept, 2000
for exclusive e85 use youre going to want either 560s+afpr with the pressure bumped or 720s.
97 VR4 12.417@111.16 9b time. full weight almost BPU
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#170 (permalink) |
I am using 680's. If I get mine out next weekend I'll let you know if the are enough.
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces
