#151 (permalink) | ||
Driving While Ukrainian
and if you don't know what you're doing but want to know, do it yourself and pay the price.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump. Working on: Driver mod. E85 powered VR4 Dream car: F40 (LM) Quote:
#153 (permalink) | |
Woot!
Comes out to 468cc ish for the additional fuel. I am going to be running some E85 but a mix. Multiple tunes, straight 93, 50/50 mix and straight E85 depending on what I am running that day. But 93 for daily driving. Just remember it is not going to save you much money, it is only going to allow you to have higher octane fuel for a similar cost to pump fuel. Draw back is that you will be using more fuel. Don't think that you are going to save all this money switching to E85. It has been proven over and over again that E85 does not really save you much in fueling. But for us and other boosted applications you get high octane fuel that would normally be $7-13 a gallon for similar cost of 87 oct. -John
1995 Dodge Stealth R/T TT, Dark Green ext, Dark Int, 1 of 20 available to the US.
Mods: 13T turbos, FMIC 3" in/out, Spec Stage 3 clutch, RPS Billet Aluminum Flywheel, Gutted front and rear precat, test pipe, MSD 8.5mm SC Wires, 3rd Gen lifters, EGR Delete, 3SX EGR Block off plates, Blitz DD BOV, Hotwire Walbro 255 Fuel pump, Map ECU, Dual Pillar pod w/ AEM Wideband and AEM Tru Boost, Halo Hybrid Data logger, Supercar Engineering 1/2 billet aluminum Shift fork, fresh 1/2/3 friction rings, custom solid front and rear engine mounts, 3" Straight pipe exhaust single out. Looks: DCC Conversion, White face glow gauges. Sound: Infinity components up front, infinity 10" sub in back with Smokin' VR4 corner sub box, Pioneer HU. Myspace Must go faster project underway. |
#154 (permalink) |
The worst thing about E-85 is that it cuts into the sales of water/meth injection kits..... Oh, wait.....
Keith
Heavily Modded 05 EVO RS (550 wheel HP on Dynapack AWD dyno) on E-85 along with a 96 VR-4 Spyder.
#155 (permalink) | |
est. sept, 2000
the savings depends on location. here E85 is about $1/gallon cheaper than 87
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#156 (permalink) | |
220K club
But getting back to the issue: A water/meth system that uses 25% meth when under mid to high boost is much more efficient at lowering AIT's and cylinder temps, allowing a few extra degrees of timing without Knock at higher rpms and loads. The water/meth injection is best used for cooling the combustion charge and thus allowing slightly leaner AFR mixtures for better power without raising the potential for Knock. Re: cleaning with water/meth injection, brief jaunts into the injection spray time ( under high boost) cleans and keeps clean the intake valves and combustion deposits on the pistons are less likely to build up for which if they do, will only cause hot spots leading to Knock and/or the most feared pre-ignition potential. Meth/water injection though isn't used to raise the octane per se but it does have the effect of lowering the volatility of the fuel so Knock potential when compared to 93 octane gasoline is reduced at higher cylinder temps. I tried E85 in my stupid useless flex fuel Ford F-150 V8 and mileage went from 19 mpg to 13 mpg and oh boy_ I saved 10 cents a gallon for E85 on that loss of mileage? Bah_ Best idea: Take Al Gore's Nobel prize award away because his goofy movie was a predicated hoax, take his fuel hogging jet away, and wake people up to the fact that man made global warming is a myth designed to bolster special interest groups to profit off of people's fears, and we wouldn't have to discuss E85 Ok_ any Iowa farmers can now feel free to flame away..
'92 R/T TT 236 K mileage club
AEM EMS, Twin TD-O5 MHI EVO 16G, Electronics: AEM ems, FJO dual WBO2, GaugeTech AEM ems display, custom made EL type main gauge faces, [/size] |
#157 (permalink) | |
est. sept, 2000
they have other (and better) options for ethanol production but the corn growers cry about it so it never happens. |
#159 (permalink) | |
I don't run E-85 to save the planet, I run E-85 for the ability to push 30+ psi of boost in my EVO with a healthy timing curve and zero knock ![]() Keith |
#160 (permalink) | |
est. sept, 2000
plus...you dont run E85 to save fuel. thats a common misconseption. as keith said....you run it to take advantage of the octane. these standard E85 cars out there are a cruel joke on the owners. those of us with the ability to tune in the extra fuel and timing to take advantage of it....no joke. |
