#131 (permalink) | |
est. sept, 2000
great info from the 90s. i used to feel the same but after some research and experience i feel differently as far as its use as a fuel. as for reliable supply...yes. something needs to be used other than food crop. flex fuel vehicles have sensors and larger injectors/computer tuning to be able to switch between the 2 fuels. pretty much all fuel systems from the late 80s can handle alcohol containing fuels.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#132 (permalink) | |
est. sept, 2000
man you just dont listen or learn do you. DONT PUT E85 IN ANY CONCENTRATION IN YOUR CAR UNTIL YOU GET A LARGER FUEL SYSTEM AND A WAY TO BOTH TUNE AND MONITOR YOUR AFR PROPERLY!!!!!!! |
#133 (permalink) | |
Dan
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002 1-815-315-4823 www.labontemotorsports.com sales@labontemotorsports.com |
#136 (permalink) |
Yes one should ask if I am sure Viton is being used, since I did not even spell it correctly
You can read more on DuPont's website about the automotive use of Viton http://www.dupontelastomers.com/Products/Viton/auto.asp We source a pump for our water-meth system that has EPDM internals. Much more resistant to alcohols. Well I don't have to read this whole thread to know this point was also missed Our cars have what is called a wet pump. All the internals are exposed to the fuel. For gasoline that is not an issue since electrically it is considered an insulator. Ethanol is electrically conductive. So you can't use a wetpump or you are asking for problems. |
#137 (permalink) | |
est. sept, 2000
edit: this is going to be my last post in here until it gets technical again. i dont like arguing when ive seen first hand how something runs and there are countless evos and dsms running around her eon ethanol. i also question your arguments based on E85 and ethanol as a fuel cutting into your business. im sorry. Last edited by 91vr4n00maxima : 02-12-2008 at 05:08 PM. |
#139 (permalink) | |
Driving While Ukrainian
ok, than my next question is:
if I'll go with SINGLE supra pump. with injectors should I use for e85? would 550cc be ok? or should I get 660cc? if I need 30% more fuel that I might run out of pump before injectors.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump. Working on: Driver mod. E85 powered VR4 Dream car: F40 (LM) Quote:
#140 (permalink) | |
est. sept, 2000
specifically post 103 yes a single supra will be enough until you upgrade turbos. |
