Old 02-10-2008, 01:52 PM   #121 (permalink)
USMC
vr4_rider's Avatar
Drives: '93 Vr4; '06 675cc
Trader Rating: (10)
vr4_rider is an unknown quantity at this point
Default Re: E85 Powered VR4?
Originally Posted by a2j View Post
alright... today I tried WOT with regular (93) gas and I had 96 o2s. so I guess 86 is lean and I need bigger injectors for e85.
You went WOT on your setup and you had .96V, so...
Base on what you said in your quote, what makes you think you need bigger injectors. I am not saying you don't (you definately do if your on stockers); I was curious what about your quote made you want to get bigger injectors.
Trung [1993 Pearl Black VR-4]
Appearance//1999 Front end//ground controls w/ adj. rear control arms//18x9 5Zigen 5ZR wrapped in 245 front, 275/35/ZR18 Falkens//DR Racing Black lugnuts
Mods//GReddy EBC Spec-II//Greedy Type-S BOV//Unorthodox UD pulley//ATR Downpipe//IPS Single Shot Magnaflow//255 Walbro pump//GReddy Profec Spec II EBC//JET tuned ECU//AutoMeter Boost gauge//HKS Turbo Timer//Gutted Hi-Flow DynoMaxx CC//Vac Reduction//EGR Block off//PRO-M 80mm MAS and MAF-T Tuner//EVO 8 560cc injectors //Shriver's datalogger
Turbos: 13Tx2
Current Problem(s): Cherries in the rear view mirror
In the Process: Nothing
Want to Trade/Buy: Cams and springs, non-OEM clutch and flywheel...
vr4_rider is offline   Reply With Quote
Old 02-10-2008, 02:17 PM   #122 (permalink)
Pro xfercase destroyer
mjannusch's Avatar
Drives: 2005 Toyota Prius
Trader Rating: (15)
mjannusch Level 1mjannusch Level 1
We're discussing running E-85, which requires about 25-30% more volume fuel flow than on gasoline. He's got enough injector for gas, not enough for E-85.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56)
'91 3000GT VR4 (Project for 2008)
mjannusch is offline   Reply With Quote
Old 02-10-2008, 03:19 PM   #123 (permalink)
USMC
vr4_rider's Avatar
Trader Rating: (10)
^^I know
It was just the quote he made and I wanted to know if the car was fuel cutting, or something else. I was just curious if the car felt different that was all..I shoulda just asked that instead...lol.
T
Old 02-10-2008, 03:41 PM   #124 (permalink)
mjannusch's Avatar
Trader Rating: (15)
Probably not enough pump to start with if that hasn't been swapped out already. I don't think you can even hit enough airflow with stock turbos to hit fuel cut unless there's a boost leak somewhere. Honestly, I wouldn't even try to run E-85 on stock injectors/pump - there's just not enough headroom for the additional fuel volume needed at higher RPM. Maybe at stock boost levels, but if you are running that low of boost then there's no reason to go E-85 in the first place unless you can get it extremely cheaply somehow (at least 30% cheaper than gasoline).
Old 02-10-2008, 05:17 PM   #125 (permalink)
a2j
Driving While Ukrainian
a2j's Avatar
Drives: Red Car
a2j is an unknown quantity at this point
ok, yeah.
I think I need bigger injectors because I'm running lean on e85 on stock ones at WOT. and pump also. or at least hotwire it.
I did not feel any diff on how my car was climbing those rpms on e85. but these is one thing (I don't think I have it when on regular fuel) I think I hit fuel cut when in first gear at about 3000rpm for about 1 sec or so.
other than that. if feels the same.
1993 3000GT VR4.
________________________
Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump.
Working on: Driver mod.
E85 powered VR4
Dream car: F40 (LM)
Let me tell you little bit about my Honda. Its got like 6... 700 horsepower.
a2j is offline   Reply With Quote
Old 02-10-2008, 06:56 PM   #126 (permalink)
est. sept, 2000
91vr4n00maxima's Avatar
Drives: slow 97 VR4
91vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 791vr4n00maxima Level 7
so you were running E85 on a stock fuel system?
poor engine. go back and read my posts on page 11 and rethink that.
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98
03 cobra vert. 4 mods=118mph traps
91 stealth TT. td05 18G, heads/cams, 3000lbs
91vr4n00maxima is offline   Reply With Quote
Old 02-10-2008, 09:45 PM   #127 (permalink)
a2j
a2j's Avatar
Drives: Red Car
poor engine? why?
I don't think that stock fuel system can't supply enough of e85 for normal driving. and logger didn't show anything really bad. yeas I was getting little bit of knock but nothing that looks scary. (besides 123% IDC)
Old 02-11-2008, 01:19 PM   #128 (permalink)
mjannusch's Avatar
Trader Rating: (15)
(besides 123% IDC)
That right there isn't a good sign.
Seriously do it right and stop experimenting on the stock fuel system. At some point it'll cost you a motor. Besides, you should be adding in timing for E-85, and running that high of IDC is greatly reducing your timing advance. At least get a good fuel pump and some 550's and some sort of fuel controller before playing with this more.
Old 02-11-2008, 06:37 PM   #129 (permalink)
dlabonte's Avatar
Drives: 1994 VR-4
Trader Rating: (16)
dlabonte Level 1dlabonte Level 1
Sorry I don't have time to read though this entire thread and apologize if this was already covered.
E85 is a dead end street. Its the talk on Capital Hill, why? Farm Subsidies. There is not enough farm land in this country to make enough E85 to supply the demand of fuel we use, let alone a need for 1/3 more.
The 3S is not a flex fuel vehicle, so you are killing your fuel system overtime running ethanol.
Run pump gas and -20 window-washer fluid all day long and make the power you would get with C116 race gas for way less. Can be done safely with water-methanol injection and our new IFS-10 injection failsafe.
Best regards,
Dan
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002
1-815-315-4823
www.labontemotorsports.com
sales@labontemotorsports.com
dlabonte is offline   Reply With Quote
Old 02-11-2008, 09:07 PM   #130 (permalink)
a2j
a2j's Avatar
Drives: Red Car
I know its not a good sign. same as knock. but its not like we all drive WOT all the time. I don't. especially right now.
and I put e85 only with some other fuel (50/50 or so) 93 or 91.
