#101 (permalink) | |
Driving While Ukrainian
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff:Free_boost, cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, 0.025'' gaped spark plugs, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch. Working on: Driver mod, fuel pump hotwire. E85 powered VR4 Wanted: Wideband A/F, A-Pillar Gauge pod, Walbro pump. Dream car: F40 (LM) Quote:
#103 (permalink) | |
est. sept, 2000
im going to be doing 550s in my 97 to replace the 450s and run e85. with the proper correction this will give me a 450ish cc correction factor, slightly more timing, and the fuel my near stock car will want for e85
97 VR4 12.417@111.16 9b time. whats next?
95 mark viii. 14.35@98 03 cobra vert. 4 mods=118mph traps 91 stealth TT. td05 18G, heads/cams, 3000lbs ![]() |
#104 (permalink) | |
#105 (permalink) |
est. sept, 2000
for a lightly modded vr4 i would reccomend 550s for e85 use. maybe even a 13g car but might need a slight pressure bump up top. 550s and a fuel computer. 450s without a fuel computer (the ecu should be able to tune enough for them on e85) i would still reccomend an afc on both so you can go back to gas if necissary. |
#106 (permalink) | |
#108 (permalink) |
Knock and O2's
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces Falken GR Beta FK-451
