#91 (permalink) | |
Wrks on car btwn classes
#92 (permalink) |
Cone filter, fuel pump, fuel system from 3sx, EVO IX BOV, MBC, Y pipe, down pipe, test pipe, IPS mid pipe with 3" electric cutout valve, and gutted rear pre-cat.
Keith
Heavily Modded 05 EVO RS (550 wheel HP on Dynapack AWD dyno) on E-85 along with a 96 VR-4 Spyder.
#93 (permalink) |
Wanted: Traction Problems
this sounds cool.
anyone see any problem using a meth injection with E85? so far the pros and cons of E85 are.... Pros Higher octane means more power by allowing more boost/timing Cons have to get aftermarket fuel pump, injectors, and fuel controller lower gas milage (should cost about the same but less miles per tank) can be hard to find the % mixture might not be constant at the pump causing unpredictable tunes I dont know, I might have to drive around town to see just how many gas stations carry E85. ![]()
PTE 780cc injectors for sell
++++++++++JUNE 2007 RIDE OF THE MONTH+++++++++++ ![]() Slideshow1..........Slideshow2..........My Photobucket..........My ImageStation.........MOD LIST Questions about the silver car?.....Rear message board info.....Turbo oil cap info.....nicest ass |
#94 (permalink) |
NG '03 6th Floor Crew
If you are running straight E85 there really is no need to add meth injection.
Web log: http://apps.blackflagracing.com/Blog/
The Armada '93 Sandstone Gray 3000GT VR-4 2006 3SI Ride of the Year 2007 All Mitsu Cookout, 1st Place 1st Gen 3/S '92 Fiji Blue 3000GT VR-4 2004 All Mitsu Cookout, 1st Place 1st Gen 3/S 2005 NG Quick 8 AWD Unlimited 1/4 Mile Qualifier. BLACK FLAG RACING '92 Emerald Green Pearl Stealth RT/TT 3.5L, 15Gs, AEM EMS |
#95 (permalink) | |
http://e85vehicles.com/e85-stations.htm
#96 (permalink) | |
Driving While Ukrainian
just 4 everybodys information:
I did hit fuel cut on high rpms in e85 with WOT 5500-7000 rpms. its really sucks up there but otherwise it just like on normal gas.
1993 3000GT VR4.
![]() ________________________ Was bored, had to do stuff: Cross drilled/slotted rotors, S-Tein springs, BOV, intake, exhaust, Datalogger, S-AFC, AEM TruBoost, 560cc, XTD Stage 3 clutch, hotwired 255lph fuel pump. Working on: Driver mod. Paint job!! finally. E85 powered VR4 Dream car: F40 (LM) Quote:
#98 (permalink) |
Pro xfercase destroyer
Yeah, stock fuel injectors aren't going to cut it with E85 due to how much additional fuel you need. The stock injectors are marginal on a standard BPU setup, and worse when you tell the ECU you want even more fuel. 550cc injectors are probably the best match if you don't intend to go too crazy with the boost, or aren't upgrading turbos.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) |
#99 (permalink) |
What do your O2's look like?
'94 vr4 - gutted precats-no main cat/ cheap-ass catback w/ebay fartcans/ custom dp/ hotwired walbro pump/ 13T's/ E-manage/ PTE 680cc injectors/ Blitz sbc i-d/ SBC DXD clutch/ Unorthodox flywheel/PST CFDS/18" Fittipaldi Forces Falken GR Beta FK-451
#100 (permalink) | |
