Old 08-19-2006, 07:47 PM   #1 (permalink)
Running on 6 cyl. again!
FaceGarden's Avatar
Drives: the ladies wild.
FaceGarden is an unknown quantity at this point
Default Custom climate control interface - lets work together.
Hey everybody,
So I've had this idea for a while now, and I'd like to get us together to figure it out. I want to decode and document the climate control signals that come from the climate control button/display unit to the climate control computer, and make that information avaliable to everybody.
The reason why i want to do this is to give us more options for dash mounting things. Imagine, for example, how nice it would be to give the climate control a smaller display and fewer, smaller buttons, to free up that space for a few more gauges, without having to resort to things like blocking off vents or using up the cubby hole underneath the stereo. You could even move the controls elsewhere, freeing up that space for a nice large touchscreen for a carputer, dvd player, or gps unit. Ultimately, you could even write a computer program that provides the climate control buttons onscreen, eliminating the need for a separate control panel althogether, and providing a very nice factory-esque integration.
The possibilities are really endless, but even the simple ability to build a smaller controller to provide more room for gauges would be a boon.
At least, i think so, do you guys agree?
If so, lets work together to figure out the control scheme. I've pulled out my climate control unit to start playing with it, but I don't have an o'scope, so if anything ends up being beyond the abilities of a voltmeter (and a cheap one at that), I won't be able to do it all.
It would also be easier for someone who had an extra display and computer lying around, as I'd like to keep mine installed most of the time, so if any of you have those, get testing!
Anyway, i've been playing around with it today, and here's what i have found so far (on my 91 vr4):
There are two connectors on the back of the display/button panel (i'll just call it the panel from now on), one is 12 pins and one is 16 pins. With only the 12 pin connector connected, the display does not light up and the unit will not beep when buttons are pressed, but vents and fans respond to button presses as if everything is ok. In other words, the 12 pin connector is for the buttons, and by following traces I've found that the buttons are pretty much just hooked up directly to pins on the connector. I've found the two pins that connect the off button, for example, by following the traces, and I intend to do that for all the buttons.
The other connector (16 pins) seems to recieve signals from the climate control computer. When only the 16 pin connector is plugged in, the display lights up and correct climate control information is displayed, but no button presses have any effect.
This means a couple of things: First of all, it looks like no matter what it would be really easy to make a custom button set to control the thing. The stock buttons are large and take up a lot of space, and some are redundant. On the redundancy, for example, you don't need one switch for in pulling in outside air and one for recycling air, you could make that a button that toggles the two. Same with the ac/econ buttons. You could also remove the off and defrost buttons and make it so that pressing mode cycles through those options as well. Some of that would require a microcontroller, but it would be pretty simple, and if didn't want to consolidate switches, just use smaller ones, the hookup would be even easier.
Also, by looking at the control PCB, i can see that the only traces that go beyond the display are for the buttons. That means that if you made a new button panel or whatever, you could literally saw the sides off the PCB and just use the display, or drill holes in the pcb and mount the gauges directly in it, on either side of the display, assuming you find a place for your buttons. Sawing the sides off of the display would shrink the PCB from 9 inches wide to just 3.75" wide, giving you 5 1/4 inches of new space!
However, if we do figure out the interface for the display, we could eliminate that as well and replace it with a more compact display, with anything as small as a two digit temperature display and a couple of status LEDs, or anything you can think of.
So I'm gonna keep working on figuring out the button interface, and if any of you have some ideas on how to grab the signals from the climate control computer to the 16 pin connector, lets get that going too. For now though, I'm off to dinner and a party.
Oh, and check out some pics of the insides of the unit and the newly created 9"x8.5" opening created when the climate control and stereo are removed.
-Taylor
FaceGarden is offline   Reply With Quote
Old 08-22-2006, 03:52 AM   #2 (permalink)
FaceGarden's Avatar
Default Re: Custom climate control interface - lets work together.
Ok, I figured out how the buttons are wired up by following the traces... When i have some time I'll take my notes and put them in an electronic file to post up here. There are a couple more wires on that connector i wanna follow, but hey, at least I'm making progress! After that it's the display connector to tackle.
I wanna just reiterate more concisely too since my last post was so long: figuring this stuff out would give us SO many more options for mounting things in our dash, giving us way more freedom to do what we want with our cars and make our aftermarket addons look more factory. To me that sounds really good, but i haven't seen any buzz here yet...
-Taylor
Old 08-22-2006, 04:51 AM   #3 (permalink)
m3kgt_99's Avatar
Drives: 2000 CAVALIER
m3kgt_99 is an unknown quantity at this point
Sounds like you are heading in a good direction, but I don't have electronic climate control. Mine is all manual or else I would help you here
CARS ARE LIKE LEGO'S FOR GROWN-UPS
1999 30000gt: SOLD
1998 Ford Explorer XLT 5.0 AWD: FOR SALE $4,500
2000 CAVALIER: 189,000 miles and still ticking
More Pics on Cardomain
m3kgt_99 is offline   Reply With Quote
Old 08-30-2006, 04:53 PM   #4 (permalink)
FaceGarden's Avatar
Just a quick update: I still haven't put my diagrams in the computer yet, but I did verify that they're correct: I took a switch with a 1.5k resistor (that's the resistance the diodes on the board provide) and plugged it into a couple of different spots on the car's connector. Just as i thought, i was able to control the climate control functions with that button connected to the proper terminals.
I've had to put my climate control back to make my car presentable for girls, but when time permits I'll pull it out again and see how the climate control talks to the display. Till then, I'll still post a diagram of the button circuits when i get a chance.
And if anyone else wants to comment on what they think of this, I'd be all ears...
-Taylor
Old 08-31-2006, 02:55 AM   #5 (permalink)
m3kgt_99's Avatar
I am following you here. Sometime, I might want to convert to a digital control if you set something up.
Old 08-31-2006, 08:00 AM   #6 (permalink)
twinblown's Avatar
Drives: Sole Survivor
Trader Rating: (9)
twinblown is an unknown quantity at this point
I'd like to help also but your post specifically applies to the 1G digital climate control unit and is not like the 98-99 ones; I know some features changed in the late ones and the connectors are different.
twinblown is offline   Reply With Quote
Old 08-31-2006, 11:09 AM   #7 (permalink)
L_P
Woot!
L_P's Avatar
Drives: '95 Dodge Stealth TT
Trader Rating: (29)
L_P Level 2L_P Level 2L_P Level 2
Once you get this figured out you can build a controller and then create a simple peice of software to allow a carputer to control it, that would rock.
Then that space will be opened up for other items.
Another good option is creating a low cost effective boost controller through the carputer.
Good luck on your findings this will take a lot of work, but may be well worth it, and well marketable.
L_P is offline   Reply With Quote
Old 08-31-2006, 04:22 PM   #8 (permalink)
FaceGarden's Avatar
Yeah, I'd love to make an EBC out of the thing too. I've been meaning to make a microcontroller-driven one, and i still could, and just have it relay the data to the carputer for display or logging or whatever.
But yeah, i was wondering if the 98-99 climate control was different... Hopefully the interface is still similar... Anyone have any pics of a unit?
-Taylor
Old 09-02-2006, 05:47 AM   #9 (permalink)
FaceGarden's Avatar
Ok, i did a quick diagram of the button interface with the 12 pin connector... I just installed the program today so I don't know how to fix a couple of things, but I'll get there... Anyway, that connector is really supposed to be 12 pins, not 16, and the switch is triple throw. The buttons are presented to you just as they look on the dash, and the connector is layed out as if you were looking at the back of the climate control button thing... which actually means the connector you'd be interfacing with is mirrored from that... But yeah, i need to tweak it, i just wanted to get something out there... Now I'm going to bed.
-Taylor
Old 09-03-2006, 09:42 AM   #10 (permalink)
DaleR's Avatar
DaleR is an unknown quantity at this point
Ooo i fancy playing around with some PIC chips and a max232 and interface it with a computer to control the climate control.
Good work btw m8!
DaleR is offline   Reply With Quote
