Old 03-27-2007, 10:20 PM   #1 (permalink)
GCtech Industries
GCtech Industries's Avatar
Drives: vr4
GCtech Industries Level 2GCtech Industries Level 2GCtech Industries Level 2
Default Billet 3.0L crank questions
What material are they machined from? I know some people here in Mexico that can custom CNC one but I need to know what material to buy.
thanks
GCtech Industries is online now   Reply With Quote
Old 03-27-2007, 11:31 PM   #2 (permalink)
aka maharba
Abraham's Avatar
Drives: 92 SL
Trader Rating: (14)
Abraham Level 1Abraham Level 1
Default Re: Billet 3.0L crank questions
I googled "billet crank material" and the first one is this
LINK for this quote:
Billet Cranks
. . . A billet crank starts as a solid chunk of high-grade steel bar (typically 4340 material) . . .
en que parte de Mexico te encuentras?
Wheels/brakes/Suspension: ---------------- exhaust:
Hawk HPS Brake Pads
-------------------fdf---2.5" test pipe
R1 concepts cross drilled and slotted rotors
-- 2.5" cat back (angled out)
Megan Racing "Street Series" Coilover Kit ----Misc.:
Adjustable control arms -------------------vb--Short throw shifter
adjustable toe arms
Soon to come:
TT Conversion w/AEM UEGO, AEM Ttru-boost, APEXi AFC II, solid motormounts, Dattalogger (hand held halo), etc...
Abraham is offline   Reply With Quote
Old 03-28-2007, 08:45 AM   #3 (permalink)
GCtech Industries
Drives: vr4
Queretaro
Gracias
Old 03-28-2007, 09:54 AM   #4 (permalink)
Drives: 99 VR4
Trader Rating: (88)
SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7SHiVeR-91VR4 Level 7
4340....VERY hard metal.
Why billet 3.0L when at the same time you can bump out displacement?
If you are making a setup, you might as well make it a stroker.
Let us know how the prices compare down there.
SHiVeR-91VR4 is offline   Reply With Quote
Old 03-28-2007, 11:22 AM   #5 (permalink)
Paternus Expectus
Damon's Avatar
Drives: 95/*99 Stealth TT
Damon Level 2Damon Level 2Damon Level 2
I agree w/ Shiv, if you can get good pricing down there then go w/ a stroker.
I got two speeds...
Faster than you... and KICKING YOUR ASS.
1995 Dodge Stealth RT/TT - Black/Tan Leather (1 of 10)
'99 Front end conversion with a thing or two...
Damon is offline   Reply With Quote
Old 03-28-2007, 01:41 PM   #6 (permalink)
Drives: 99 VR4
Trader Rating: (88)
It's going to cost the same no matter what.
Development costs and the first production one will be highly expensive (up here around $10k)
But even after that you're still looking at 4-5k up here for the crank by itself, then you add all the forged parts and that's why Ray is at the price he's at.
If you can get the prices down man, it would be incredible...I'd be in for one real quick.
Old 03-28-2007, 02:12 PM   #7 (permalink)
GCtech Industries
Drives: vr4
Im working with some guys here that fabricate all sorts of things I gave them the material type the question is can they build one on a 5 axis cnc or they gonna need a special machine to build cranks ?
Due to labor I can get prices lower here ,(I dont about the material)but I need to get an idea of prices since the first unit is coming out of my pokets, I was thinking on using standar Chevy rods that are available at very low cost and there is a wide variaty of brands even on aluminum..
I have a metting with them these weekend I definitly keep u post..
3.5 or high displacement suggestions are welcome
these are the guys Im working with http://www.ciatec.mx/english/
thanks
Gilbert
Old 03-29-2007, 07:07 AM   #8 (permalink)
Drives: 99 VR4
Trader Rating: (88)
Larger rod bearing surfaces would be nice, as well as a better oiling design and 3.5L - 3.6L stroker design.
300M is even harder, but I'm not sure about use in a crank.
Old 04-01-2007, 05:58 PM   #9 (permalink)
Go get bent
LUSTFUL's Avatar
Drives: Just a NA
LUSTFUL is an unknown quantity at this point
Not true neccesarily. 4340 can be very very soft, in fact I took rockwell B measurements today of 70/72 on 4340. It is extremely hardenable though, which typically allows for 4340 to acheive the martensitic reaction, thus making it hard. hardenable is just the ability to achieve the martensitic transformation, not how hard it can be.
4340 is a common material for cranks, I have also seen some rods made out of it as well
'93 Dodge Stealth ES: BPU and a bit more maybe
Hey bois duz dis ebay chip work make mah whip teh fasterest?
LUSTFUL is offline   Reply With Quote
Old 04-02-2007, 07:13 AM   #10 (permalink)
Its Z06 Time now...
SneekyTT's Avatar
Drives: 1991 Stealth RT TT
Trader Rating: (11)
SneekyTT is an unknown quantity at this point
full 3.5 stroker kit for less then $4500 would satisfy me...
Rolls are for fat bitches... Ya dig?!?
-2001 Chevy Corvette Z06 - 12.30@114 1.75 60ft BONE STOCK
SneekyTT is offline   Reply With Quote
