#11 (permalink) |
Senior Member "Go Pig Go"
Jim using Windshield washer fluid would be consider a water injection kit...even though it has 50% meth in it. Its also 50% water....cheap as distilled water but with the added benifits of having meth in it (well 1/2 meth)
I have the SMC alky kit..same benifits of running more boost from higher octane and cooler charge. also..new kit has a 1/2 gallon tank...very very very easy to install and you use denatured alky in it. 7.99 a gallon at lowes or home depot. Trevor is a great example of a member using it with great sucess and you can get a complete kit for 375 shipped (well i did) its usually 399.00 + shipping Use the 10gph nozzle instead of the 15gph nozzle that comes with the kit.....but steve at SMC will send you a 10gph for free. also....beneift...in car tunibility...controls are almost exactly like the Pro-pain kit Dynamic racing sells.
1995 3000GT VR4 (Sold 10/08/06) Daily Driver: 2005 Honda Accord EX V6 w/navigation 2008 Acura MDX w/Technology Package |
#12 (permalink) |
Snake Eater!
"Propane injection you can definately run shit loads of boost, but there are hardly any cooling effects."
Propane comes out of the bottle at -60F if I remember correctly?!?!
Mike T.
1992 Silver VR4 Future mods (not in any order)... Stage 2/3 Heads, Rear Sway Bar, CFDS, LSD, Rebuilt tranny AGAIN (thinks to Mitsu), Clutch, CF Hood, Propane (already bought along time ago), Pre-Cat Eliminators, AEM Stand alone, Repainted, Big Brake Kit, Rims... think I could get close to 500WHP out of that on DR500s?http://www.penguinhosting.net/~matt/public/picture2/mycar/vr-4/ Vipers Beware! |
#13 (permalink) |
Meet the twins
I'm trying to decide on propane or water/alcohol injection for my 10:1 TT setup. Knock comes a lot sooner on 10:1 with pump gas. I've been considering the IPO propane kit. Yes, propane does come out around -60F and is around 115 octane. I believe IPO hit 11's at 23 PSI or something on pump gas and propane. Although, it is kind of scary knowing you have a tank of highly explosive gas in your trunk. You might want to add that and the temperature and octane ratings of propane into the encyclopedia.
1998 VR4 - Red - 1 of 231
15g's | PTE 550's | Walbro 255 | Apexi SAFC w/ Boomslang Harness | Maximal Performance Solid F/R Mounts | Stillen Downpipe | MSD Superconductor 8.5s | JIC Y-Pipe | Old school ProBoost MBC | EVOScan Logger (logging knock on OBDII baby!) | Kazera KZ-A 18x8.5's | Yokahoma AVS ES100 Tires 1/8: 8.1 @ 89 MPH, 1.9 60' (soft launch on stock clutch) - 16 PSI/rich tune & leaking stock y-pipe coming soon: more runs with MORE BOOST! ------------- 1990 Mustang GT - not stock - Gone but never forgotten..... ------------- 1992 Mitsubishi 3000GT SLTT - Formerly the SLSC - My first love (15g 10:1 TT Conversion) - Parting Out ------------- Old setup (worn 9b's, broken motor mounts, M&S tires, 6 psi) 1/8: 9.3 @ 85 MPH |
#14 (permalink) | |
Team Negro #001
the thing with the propane and it's temps is that when it LEAVES the bottle it's that temp. It then has to travel approximately 17 ft from MY tank to the bay, so the cooling just isn't there anymore. Maybe if you had a system where the propane line was only like 2 feet you could do it (maybe mount the tank in the passenger foot area?!?!?! You speak of highly explosily gas, but you fail to realize that the gas tank sits about 10 inches from the rear of the car and is made from some of the THINNEST metal. You can take a scredriver and drop it end first on a gas take from about 10 inches away and puncture the thing. With this in mind take any colisoin in mind. The gas tank will go WAY before the propane will. Propane tanks are made to be abused. Ever see how thick they are and the consice deisgn that goes into every single one??? It actaully makes me wish that that much thought was put into the gas tank. Blowing up from propane should be FAR from a worry unless you shoot at the tank with a shot gun shell on a normal basis ![]() |
#15 (permalink) | |
glehv@umich.edu
The cooling effect of propane discussion should not go any further. It's colder than ambient air due to significant pressure drop threw the release nozzle. And the air being injected into your engine is much hotter than ambient due to the compression undergone in the turbos. Heat Transfer 101 -there is no way that the ambient air, which is already cooler than the air going through your y-pipe (post compression air), can heat up the propane to a temperature higher than that in the y-pipe! Now on to the danger of the propane cylinder. True, every car has a gas tank, but did you ever notice that you are partitioned from that tank by STEEL. In the 60's the first Mustangs had the gas tank as the floor of the trunk with no steel fireshield between the tank the the back seats. In some rear collisions people were burned alive due to explosions that ripped through the cloth of the back seats and into the front of the car. Later, FORD closed off the trunk floor with sheet steel and this problem was no longer an issue. It is the same for the propane tank that so many people install in the rear of the car; it has no fireshielding between it and the passengers. In order to make it safer, or at least as safe as a gas tank it is imperative that at the least it be separated from the passenger compartment by sheet metal or placed outside of a vehicle. Carrying a bomb next to you is very different from carrying one between you and a steel barrier.
1997 3000GT VR-4
TD05 Big 16G's, JAC-Engineering Manifolds, O2's and Intercooler Piping, PTE 780cc Injectors, MSD DIS-4 Ignition System, MSD Knock Alert, LM1 Wideband Air/Fuel Ratio Meter, Aquamist 1S Alcohol/Water Injection System, Phantom Roadworks Exhaust and Downpipe, RPS Stage III Clutch, Blitz SBC-ID, Arc2 Fuel Controller w/ Arm1 A/F Ratio Gauge, Supra Fuel Pump, 3SX Motor Mounts, HKS SSQV, HKS TT Type 1, Apexi 60mm Electronic Boost Gauge, Apexi 60mm Electronic EGT Gauge, Autometer A/F Ratio Gauge (ultra-lite), Hawker Energy 13.5lb. SLA Battery, White Face Gauges, RVM Racing Front and Rear Strut Tower Bars, Dave Best Polished Plenum, Valve Cover, IC Pipes and Spark Plug Plate, SSR GT1 Wheels. E-mail: glehv@umich.edu |
#16 (permalink) |
Pro xfercase destroyer
If this is a guide to preventing/reducing detonation, please add:
Timing Retard strategies/products: MSD DIS4 / DIS4-HO - can retard timing based on boost pressure GReddy e-Manage - can set retard based on up to 16x16 timing map EFI Systems PMS - can adjust timing based on 16x16? timing map or manifold pressure AEM EMS - full timing control Turbo upgrades with larger turbine sections: TD04H/TD04HL/TE04H-based turbo upgrades (DR500, DR650R, "true" 15G, GT368SX, etc) - larger exhaust turbine reduces hot exhaust gas reversion into cylinder during end of exhaust stroke and start of intake stroke where the cams overlap. TD05/TD06 turbo setups (14B, 16G, 18G, 20G) - larger exhaust turbine and higher A/R (larger exhaust housing with more flow area) further reduces exhaust gas reversion and backpressure. Garrett turbo setups (DR-1000R, etc) - Generally will see further improvements on exhaust side over the TD05 setups. Greater choice of housings/wheels and better aerodynamics in general.
-Matt
'95 3000GT Spyder VR4 (11.838@117.56) '93 3000GT VR4 (Project for 2009) '91 3000GT VR4 (Only a shell of its former self) |
#17 (permalink) | |
Snake Eater!
#18 (permalink) | |
Me Tarzan..u Jane
![]() Rich Passion Red '95 Stealth R/T TT 3Si # 802 Tag: RUQUIKR More Pics and Mod List "This year will go down in history. For the first time, a civilized nation has full gun registration. Our streets will be safer, our police more efficient, and the world will follow our lead into the future." - Adolf Hilter, 1935 - |
#20 (permalink) |
Trogdor strikes again!
Good info here...any additional comments?
chris
1992 3000GT VR4
K&N Intake, LS6 MAF and MAFT, DN Performance Y pipe, EK2 downpipe, Blitz SS BOV, Joe P MBC, Autometer Boost and Air/Fuel Gauge, Fuel Pump Hotwire, DSM 450cc injectors, EK2Fuel Rail Adapter, EK2 EGR blockoff plates, MSD Superconductor Wires, Shiver's Pocketlogger, Seattle Short-Throw Shifter Midnight Haze Black Face Reverse Indiglo Gauges, H4 Headlamp Conversion, OZ Wheels, EBC Greenstuff Pads, 3SX Stainless-Steel Braided Brake Lines, M-Spec Vacuum Reduction Kit, Redline Leather Shift Boot and E-Brake Boot, Greddy polished shift knob, 1600 watt audio system (Alpine CDA-9807, 2 10" Infinity Perfect subs, Smokin' VR4 custom dual 10" subwoofer enclosure, Kenwood Excelon KAC 810D, Lightning Audio digital capacitor) Needs to be installed: Maximal Performance solid motor and tranny mounts, Autometer EGT gauge, 255lph fuel pump, Test pipe, Topline Engineering Ground Wire Kit |
